Outdoor Theater on a Budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-09-2020, 07:38 AM - Thread Starter
jtedesco's Avatar
Hi All,
It has been a while since I visited these forums - about 13 years in fact! I'm looking to set up a home theater in my outdoor living room. This is a covered area, which receives very little direct sunlight during the day, but a decent amount in the evening, as the most exposed area faces west.
I'm looking to spend about $1K. I need:
-Projector - Must connect to fire stick, project bright enough for at least mediocre daytime performance (if this is possible)
-Screen - I can mount a pull-down screen - I'm thinking somewhere around 100"
-Speakers - I'd love to set up surround sound, but this isn't strictly necessary.
-Receiver
-Cable/Wiring
I'd appreciate any recommendations y'all can offer. I imagine maybe there are some wireless options? Not sure if that is a good idea though. Happy to answer any questions as I'm sure there is a lot I'm missing, since I'm new to this process.
Thanks in advance!
jtedesco is offline
post #2 of 3 Old 05-09-2020, 07:49 AM - Thread Starter
jtedesco's Avatar
I just remembered that I have a pair of Yamaha outdoor speakers which will probably help offset some of the cost here. I could definitely use those.
jtedesco is offline
post #3 of 3 Old 05-09-2020, 05:54 PM
b curry's Avatar
Quoted: 1294 Post(s)
Liked: 833
Originally Posted by jtedesco View Post
Hi All,
-Receiver
-Cable/Wiring
Thanks in advance!
If your needs are around a 100" display and you want daylight viewing, you're much better off going with a 75"-85" LCD TV.
b curry is offline
Reply Outdoor Theaters
