SunBrite TVs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-19-2020, 08:23 PM - Thread Starter
Liked: 0
SunBrite TVs
Hi all,
I'm looking at installing an outdoor TV for my back rooftop deck. I'd install it underneath a pergola, but would definitely be subject to the elements (sun, rain, snow, etc.). So, I've eliminated the possibility of using a normal TV and have narrowed it down to either the Signature or Pro line of the SunBrite line. Is anyone familiar with the differences in the two, and can recommend one over the other? As referenced, the only shade will be a pergola, so will more or less be receiving direct sunlight. I'd love to go with the cheaper Signature option, but given they're both expensive I want to make sure whatever I get will work. Thanks
dougdon is offline
Reply Outdoor Theaters
