Outdoor projector mount? How do you do it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-13-2020, 03:33 PM - Thread Starter
My_Oozing_Eye's Avatar
Question Outdoor projector mount? How do you do it?
Ive got a nice patio area under my already finished deck. The deck faces east, so it gets dark pretty quickly in this area. I’d like to mount the projector by having it hang off the deck, it will be about 15 feet from the wall ... which would be fantastic. My thought is I would leave it there for the summer... but ... I’m not finding any examples of people doing this?
Ideally it would have back, side and top panels. Be large enough to hold the projector, an Apple TV and a surge projector. I would then run one power line to the box. For audio I have found connecting Sonos speakers through the appleTV works well.
Do you all use tripods? Or bring your projector out each time?
Ive looked at quick release mounts... but then you have to mess with the wiring each time?
Thanks for any help or Ideas!
Beauty is in the eye of the Beer Holder!
My_Oozing_Eye is offline
post #2 of 9 Old 06-13-2020, 03:37 PM - Thread Starter
A couple comments:
Ill move the lights out of the way.
The screen will be mounted above the garage door. It is a manual pull down.
On the wall on the left side is a box. I will run power from that box up to the bottom of the deck and over the the location of the projector mount.
Just to the left of the garage door is a table. I have a Sonos speaker there now. I will either run sound from there, or, mount Sonos speakers on the wall just above (or on the sides) of the screen when I get it installed.
post #3 of 9 Old 06-13-2020, 05:26 PM
b curry's Avatar
Quoted: 1294 Post(s)
Liked: 833
There are outdoor projector enclosures made specifically for this purpose.
The inexpensive ones typically have some kind of fan and filter designed to keep some air flow around the unit to help dissipate lamp heat. These sell for a few hundred dollars.
The better units contain both cooling and heating systems designed to provide the correct environment and control moisture year round. These sell for one to a few thousand dollars.
The thing with leaving a unit outdoors is that it is subject to temperature swings, condensation, and bugs that like to find quiet dark places and none of that is good for a projector.
I mount my outdoor unit on a VisualApex adjustable projection stand and bring the projector back inside for storage. It's cheaper and safer.
https://visualapexscreens.com/collec...list=grid-view
Here's some enclosures to get you started. And then there is always DIY.
https://www.deertv.com/products/smal...nt=51191997011
http://www.video-walls.co/
b curry is offline
post #4 of 9 Old 06-13-2020, 08:34 PM
j2048b's Avatar
Quoted: 17 Post(s)
Honestly from the edge of the balcony id make my own to cover the projector, so u could just mount it under the balcony directed directly where the screen is going to go.... Then put up small surrounds and other speakers to make it sound the best you can... Possibly also make a faux wall from the beam on the balcony to the wall where the garage door is mounted and it would be an open concept towards the grass and away from the balcony
Then in that small dirt open area to the right, id put in 2 outdoor subs berried into the ground and open a couple sections of the faux wall and place covers on them so the bass fills ur now functional out door theater
Sent from my Pixel 3 XL using Tapatalk
j2048b is offline
post #5 of 9 Old 06-14-2020, 09:46 AM - Thread Starter
Thanks for the reply. I like the DeerTV box... but will need to figure out a way to mount from my deck. It appears they are made to be mounted on tripods.
post #6 of 9 Old 06-14-2020, 09:50 AM - Thread Starter
Thanks! I’m not sure I follow your faux wall idea. But putting some speakers in the area to the right is a good idea!
post #7 of 9 Old 06-14-2020, 10:06 AM
j2048b's Avatar
Quoted: 17 Post(s)
Put up a fake, faux, temporary, wall that runs from the beam under the balcony and run jt and connect it right next to the garage door.... That way the sound has a smaller area to cover and doesnt get spread around to much, then add the in ground subs.... Just my opinion.... The wall will help to keep the sound situated and directed more imo
j2048b is offline
post #8 of 9 Old 06-14-2020, 12:24 PM
b curry's Avatar
Liked: 833
If you look at the spec's/instructions for the DEER unit, you'll find that it has VESA 100 x 100mm mounting holes both top and bottom. So, it will accept any standard projector mount located on the top or bottom.
If you look carefully at the picture, you'll see 4 mounting holes caped off on the top of the unit. A standard projector mount would attach there.
It's also shown on the drawing.
b curry is offline
post #9 of 9 Old 06-16-2020, 08:58 AM - Thread Starter
Thanks for replying again b curry. I’m a bot embarrassed that you had to do the research for me!
Reply Outdoor Theaters
