Help with Panasonic CT-6000 front projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-01-2018, 11:33 AM - Thread Starter
Liked: 0
Help with 1980's Panasonic CT-6000 front projector
Hi,
I have this Panasonic CT-6000 projector from 1980.
Typical 3-tube projector furniture-type with mirror on the lid and screen.
I've been looking for the service manual in the regular sites where I use to find them with no luck. it seems like it is not a very popular unit.
Just in case, does any of you have this manual available?
The problem with it is that the focus changes with the contrast control por example, and also the focus changes according to how much white the image has. More white means more consumption so either the +B power supply has an issue or the HV power supply has a problem.
I need the schematics for it and the service manual would be great!
Any ideas about what can be causing the problem?
Thabks a lot in advance.
normende is offline
post #2 of 5 Old 03-01-2018, 11:40 AM - Thread Starter
Liked: 0
Here is a pic from Popular Mechanics Feb. 1980
normende is offline
post #3 of 5 Old 03-05-2018, 07:59 AM
Curt Palme's Avatar
Quoted: 41 Post(s)
Liked: 66
That looks like an old RCA or Hitachi chassis. I'd bet that Nordmende never made it, but relabeled one of the Japanese chassis. I'd google those brands to see if you can cross the model number. It could also be a Sony chassis, but I don't think so.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #4 of 5 Old 04-01-2018, 01:07 AM
Liked: 1
Had a couple of these with the focus problem. Its the high voltage focus resistors on the HV pack. I did make up a external mod that worked but that was many years ago. If I remember correctly I used the big stick resistor from a early Rank Arena TV.
Gregstv is offline
post #5 of 5 Old 02-12-2020, 10:39 AM - Thread Starter
Liked: 0
Just in case, do you have se service manual or schematics to help me working with it?
I wonder how you managed to get access to the terminal with the focus voltage.
The focus change only on bright contrast pic with a lot of white, when the crts have more consumption.
normende is offline
Reply CRT Projectors
