Portable CRT black & white bad display. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-09-2019, 05:32 PM - Thread Starter
Liked: 1
Hi. Just got this mini black & white CRT TV to play stuff on the go but the display seems to be broken. The image is unaligned and has some kind of static.
Here is a video about it: https://youtu.be/X-j_Mvut7zk
So anyone know if i could fix it? Are the CRT tube unaligned and i just need to calibrate it?
Also i don't have the proper AV adapter to use wiht it, some people on reddit say this could be the cause of the problem but i find it unlikely.
Thanks for the help.
AngelBryan is offline
post #2 of 4 Old 02-10-2019, 10:10 PM - Thread Starter
Liked: 1
Here are some pictures detailing the problem: https://imgur.com/gallery/JfC0Nvt
post #3 of 4 Old 05-07-2019, 07:30 PM
Curt Palme's Avatar
Quoted: 40 Post(s)
Liked: 66
Bad electrolytic capacitors in the vertical section.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #4 of 4 Old 07-09-2019, 06:21 AM
Quoted: 12 Post(s)
Try adjusting vertical height and linearity controls on the back to see if that will bring it back.
If not you have a electrolytic vertical coupling capacitor that is bad.
old tv guy is offline
Reply CRT Projectors
