Any disadvantagesetting crossover too high - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-10-2019, 01:31 AM - Thread Starter
Quoted: 188 Post(s)
Liked: 65
Front speakers have specs down to 50hz frequency response on axis, so common recommendation would be setting 60 or 70hz as crossover. Any disadvantage of crossing it with subwoofer too high? I'm looking at 120hz. Because though speakers may be capable, i still want all that range to be handled by my subwoofer. So any downside of 120hz specified in receiver settings? I dont trust the receiver's software, so i dont want a suggestion of, just run the receiver's software and let it set it. im setting it manually.
Gerry1975 is offline
post #2 of 6 Old 08-10-2019, 03:00 AM
markmon1's Avatar
Quoted: 5050 Post(s)
Liked: 3282
The only issue is that the higher the frequency being played, the more directional the sound. A sub should be invisible in the room. I like around 80hz myself for theater. At 120 you may be able to tell where some of the bass is coming from. That's the main disadvantage. You'd ideally want the speaker best at playing the sound frequency to be the one to handle it.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #3 of 6 Old 08-10-2019, 03:39 AM - Thread Starter
Quoted: 188 Post(s)
Liked: 65
Why would localisation occur at 120hz, i thought that would start being an issue at little higher frequencies? And not like setting 120 will make subwoofer play everything 120 and lower, it will be gradual roll off from speakers.
post #4 of 6 Old 08-10-2019, 03:48 AM
markmon1's Avatar
Liked: 3282
I hear directional bass above 80. The lower the frequencies the more it disappears. Just test it yourself and see. That's the only disadvantage to running the higher crossover (you asked the question) so if it's a non-issue for you then great!
markmon1 is offline
post #5 of 6 Old 08-10-2019, 03:59 AM - Thread Starter
Quoted: 188 Post(s)
Liked: 65
I have the bowers diamond series bookshelf you have mentioned in your signature. What do you set? Now that i look at the specs, the low end is rated 42z. But i use them as fronts and listen music plus movies. Advantage setting higher is with music , in 2.1, higher crosover makes midrange more clean. 100-110 will do? receiver allows 10hz increments.
post #6 of 6 Old 08-10-2019, 04:18 AM
markmon1's Avatar
Liked: 3282
Sure try 100hz and see what you think. For music, I find the 805D3's are good down to about 60hz.
markmon1 is offline
Reply CRT Projectors
'm l
