I moved but my marquee 8500 does not switch on - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By draganm
post #1 of 9 Old 08-21-2019, 12:04 PM - Thread Starter
enrico1967's Avatar
hello everybody,
I was using my marquee 8500 till few months ago. Everything was perfect. I recently moved, I made sure that the projector was carefully transported.
today I finished the setup but the loved CRT does not switch on. On the back I noticed the light STANDBY is on (Yellow light on).
The second light which says LVPS in light on RED color.
When I push the button "POWER" on the remote, the last light "C" switch on intermittent very fast both on remote and on CRT.
what is going on?
thanks in advance for your help
Enrico
enrico1967 is offline
post #2 of 9 Old 08-22-2019, 11:52 AM
draganm's Avatar
Quoted: 26 Post(s)
Liked: 29
Enrico
the LVPS = low -voltage power supply.
unplug machine, remove LPVS (2 screws once cover is off), clean Copper traces with cotton swab and isopropyl Alcohol, re-install.
http://www.curtpalme.com/Marquee_Teardown1.shtm
If still red light, LVPS might be bad.
Or,
step-2- something that LVPS is powering is disconnected, poorly connected. Look at red lights on front of LVPS, are any lit-up?
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #3 of 9 Old 08-22-2019, 02:26 PM - Thread Starter
enrico1967's Avatar
Or,
Thank you very much draganm!
Tomorrow I will try to disconnect, here is already night!
I am not sure I got it right the Step 2. looking at the PRJ from the front, under the lenses there is a red light on. There are 5 little gratings under the lenses, it is positioned on the second grating from left, practically in the middle of the first two lenses from left.
if LVPS is bad, is it possible to replace it?
really appreciated your help, I am not ready to part from my loved CRT and convert to the digital, me and my wife love watching movies on that machine!
Enrico
post #4 of 9 Old 08-22-2019, 04:16 PM
draganm's Avatar
Quoted: 26 Post(s)
Liked: 29
Enrico
So you have 2 red lights on?
Red light on back of machine labeled LVPS
Red light in front of machine ,on the LVPS itself, second from left
the 2nd from left light indicates a problem on the -85Volt rail. the only thing on that rail is the video neck-boards which slide onto the back of the tubes. These could have gotten knocked loose
I would start by pulling re-installing the LVPS, then check the Video neck boards (VNB's) . 3 of them under the gold covers, I would just push on them, evenly, and see if they go in further.
http://www.curtpalme.com/Electrohome...e_Layout7.shtm
Or, slide them back, clean pins with alcohol, re-install. Risky though , you have to be very careful, do not force, if you bend the pins tube is ruined.
I've attached a document talking about LVPS
File Type: pdf Marquee_Power_Supply_Troubleshooting.pdf (28.0 KB, 4 views)
draganm is offline
post #5 of 9 Old 08-23-2019, 10:40 AM - Thread Starter
enrico1967's Avatar
hello,
I removed the LVPS and cleaned the contact withs the with cotton swab and isopropyl Alcohol and re-installed.
the problem is not solved. Same lights are switched on.
I realized that I made a mistake regarding the red light on the LVPS (watching from the front): it is the 5th from the left (or the third from the right).
At this point I halted the the work on the the video neck-boards waiting your confirmation to proceed. Should I proceed or do somenting else?
I found out an incredible amount of dirt and dust. On the fan there where like 0.2 inch of black dust which i removed but the inside is clearly very dirty.
Is it advisable to open the LVPS and clean it?
thank you very much
enrico
post #6 of 9 Old 08-23-2019, 01:13 PM
draganm's Avatar
Quoted: 26 Post(s)
Liked: 29
5th from left is +5 volt rail, almsot every module uses it. Could be anything on the rail or the LVPS itself . The LVPS is 2 halves with 5 connectors in between them, not advisable to take apart .
This is what i would do. Remove top cover, remove the 2 gold covers over the vertical boxes. Lift up the boards an inch or 2, and slide them firmly back into chassis. This is the Horizontal deflection and focus,
if the machine still doesn't power up, replace the LVPS, they are cheap and plentiful used as people part these machines out all the time. You should be able to find one for 50 bucks, any 8500/9500 LVPS will work
If local parts, i would also grab the HVPS , they are the most likely to fail
http://www.curtpalme.com/forum/viewf...92e3ac51ec76ff
enrico1967 likes this.
draganm is offline
post #7 of 9 Old 08-24-2019, 03:17 AM - Thread Starter
enrico1967's Avatar
thank you very much, I tried but it did not work.
I will try to buy a LVPS.
unfortunately I moved to an island in Portugal named Madeira, I will spend more for transportation and importation fee than the LVPS...
really appreciated your help.
post #8 of 9 Old 08-24-2019, 09:17 AM
draganm's Avatar
Quoted: 26 Post(s)
Liked: 29
It is likely all the dirt trapped a lot of heat and cooked the power supply .
buy one from Europe, there shouldn't be any import taxes. There are quite a few of these machines in the EU
just post on the FS section at Curt's website " WTB, LPVS for Marquee in Europe"
draganm is offline
post #9 of 9 Old 08-25-2019, 11:14 PM
deronmoped's Avatar
Just leave the projector plugged in for a few days, it may fire up. I have a 9500 where the power supply would work, but only if left plugged in for extended periods of time.
CRT Videophile
deronmoped is offline
Reply CRT Projectors
