Subwoofer hum, possible ground issue? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-17-2016, 06:06 AM - Thread Starter
Liked: 0
Hello guys, new to the forum and I'm hoøing I could get some help with my subwoofer.
So straight to the problem, the subwoofer hums all the time if I disconnect the rca cables from the headunit the humming stops. And another facenating thing is if I brigde the rca ground on the headunit somewhere on the frame of the headunit the humming stops. Does anyone of you have any idea on whats going on?
Rollv is offline
post #2 of 5 Old 04-18-2016, 06:02 PM
Dropkick Murphy's Avatar
Quoted: 75 Post(s)
Liked: 90
Try grounding your head unit and amps to the same location on the frame.
Dropkick Murphy is offline
post #3 of 5 Old 04-20-2016, 03:20 PM - Thread Starter
Liked: 0
Don't have long enough wires to do that Gonna do some more troubleshooting in the weekend. btw added a picture to show the really bad "fix"
Rollv is offline
post #4 of 5 Old 04-20-2016, 03:24 PM
TornadoTJ's Avatar
Quoted: 1950 Post(s)
Liked: 626
This happens all the time in live audio. It is usually caused by one of the outlets being out of phase with the other, or some sort of fault in the ground (third prong). We use these so that we can float the ground and if necessary reverse the way it is plugged in.
http://www.amazon.com/Coleman-Cable-.../dp/B002HGUQYK
Outlaw subs ship with only a two wire cable. It's a pretty common issue.
TornadoTJ is offline
post #5 of 5 Old 05-01-2016, 09:13 AM - Thread Starter
Liked: 0
Been out today an looked at the car, humming is still there. Ive changed the ground locations and nothing changed. I discovered anotherthing tough, if I disconnect the rca plugs from the amp it got another type of humming. This rly has me scraching my head.
Rollv is offline
Reply Car Audio, Video, and Nav
