Spotify Recorder: Convert playlists into mp3-files - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-21-2016, 04:39 AM - Thread Starter
MikeEhrmantraut's Avatar
Liked: 0
Hey everybody,
currently I'm comparing some Spotify Recorder to extract and convert my entire playlists into mp3-files.
Because I would like to save them on CD for listen in my car.
Already found a software, which makes a good impression and could suits me, because a lot of stuff works automatically without processing after.
Its called audials tunebite: http://audials.com/en/how_to_record_...s/spotify.html
The problem is, that it is't freeware, so I have to pay. Before I would like to hear, if someone already gained experience and could give me some advice?
Thanks for help!
MikeEhrmantraut is offline
post #2 of 2 Old 03-12-2019, 11:52 PM
Liked: 0
export musconv playlist list
if music discovery is your goal then the musconv.com is top notch. Based on songs or artists you either upload from your Google music playlists or add as favorites on the site, musconv.com will recommend similar songs, albums, and artists that you can add or exile as you go.
Peter Wayn is offline
Reply Car Audio, Video, and Nav
converter , mp3 , music-streaming , recording , spotify recorder
