Dash cam plus rear cam combo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-26-2019, 10:04 PM - Thread Starter
Herve's Avatar
Quoted: 423 Post(s)
Liked: 79
My wife and I are looking for a small, inexpensive front and rear combo dash cam that records in 1080p. By "combo" I mean that there is a separate rear cam that is connected to the front cam via a cable and they both record to an sd card inserted in the front one.
Both front and read cams also have to be light because we of the Great White North have very cold winters and things stuck to the windshield have a tendency to pop off during the coldest weather. Therefore, the smaller and lighter the object stuck to the windows, the better.
There are lots and lots of inexpensive cams on ebay, but not much feedback or reviews of them.
Anybody have such a dash cam combo that they have found works well and would recommend?
Herve is offline
Reply Car Audio, Video, and Nav
