need advice Kicker setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-01-2019, 11:52 AM - Thread Starter
Liked: 0
was thinking of buying a Kicker 46CXA1200.1T Amp mono subwoofer amplifier
600 watts RMS x 1 at 4 ohms (1200 watts RMS x 1 at 2 ohms)
1200 watts RMS +/-10% x 1 at 1 ohm
and pairing it with either a
Kicker Q-Class 41L7152
L7 Series 15" subwoofer with dual 2-ohm voice coils
or
Kicker Q-Class 41L7154
L7 Series 15" subwoofer with dual 4-ohm voice coils
it has been 20+ years since I had an aftermarket setup and my knowledge seems to have slipped away
I don't remember ever having dual voice coils in the past and I am unsure if I will either be under powering or over powering the speaker with this amp I wanted to do 1 sub in a sealed box and which speaker to get if either will work the 2 ohm or 4 ohm ... any assistance is greatly appreciated
Richard Doyle is offline
post #2 of 3 Old 12-09-2019, 02:58 PM - Thread Starter
Liked: 0
8 days later and not 1 reply .. obviously no one can answer my question
post #3 of 3 Old 01-14-2020, 08:13 AM
pbasil1's Avatar
Liked: 0
Most kicker amps are only 2 ohm stable, so if you you are going to use 1 sub, then you would want a dual 4 ohm voice coil to wire them in parallel to pull a 2 ohm load on the amp maximizing its power output.
But i will say this, if you are wanting decent sound quality, I would seriously consider somthing other than the L7. They have never had great sound quality, and have been built more for the SPL use. Go with a round cone. Something like the 42CWQ154, the same as the L7, but using a round cone.
pbasil1 is offline
Reply Car Audio, Video, and Nav
