TM700 - Noob really confused about audio Pops. Plug in external mic and loose 5.1? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-13-2011, 10:50 PM - Thread Starter
bob ross's Avatar
I guess this a two part question.
Love my Panasonic TM700 but I'm confused about the audio. Importing a RAW MTS file into audacity nets 6 channels. I gather this is from the internal 5.1 mic setup? Been reading around that it's not true 5.1, So... confused on this, how do you retain this "5.1" with just a external stereo mic?
I recorded a loud concert and my audio is FILLED with these "pops". From my understanding it is the circuitry protecting itself by clipping ranges that are too loud (?). Will an external mic help in this area?
Thank you for any suggestions and help.
bob ross is offline
post #2 of 5 Old 12-14-2011, 08:25 AM
Quoted: 88 Post(s)
Liked: 32
Did you lower the audio level before recording?
xfws is offline
post #3 of 5 Old 12-14-2011, 09:11 AM
Philip_L's Avatar
Quoted: 17 Post(s)
Liked: 30
It is 5.1 sound, the "not true" is because the microphones are very close together so you don't really get much separation between all the channels. "True" 5.1 sound is done in post production, for example on the Panasonic camcorder people speaking will be picked up by the left/right/centre and rear microphones and so will be heard out of all the speakers, with only a slight bias to the front and centre speakers, but 5.1 used correctly, the dialogue will usually always come out of the centre speaker and no others, so pinning the person and their dialogue right in the front of you.
With a stereo microphone it will only record 2 channel stereo sound.
As already suggested you need to turn the audio gain. Switch to manual mode and using the recording settings menu find the audio gain settings and turn it down. Even with this right down, you may still get popping if the sound is very loud as the condenser microphones are very sensitive and the noise is just shaking them! Imagine what it's doing to your hearing
Regards
Phil
Philip_L is offline
post #4 of 5 Old 12-24-2011, 12:29 AM - Thread Starter
bob ross's Avatar
I did not. This was basically me pulling the camera out of the box heading to a concert. I've been through the menus and have turned the input way down for future recordings.
Regards
Phil
I was wearing earplugs as I always do! What would you suggest for loud concerts that will go to BluRay? Still 5.1? Manual seems to suggest this is the "best quality".
Reading the manual isn't really clear on the Bass settings. Should I just leave it at 0dB? What is "Lowcut"?
Also assuming I'm in a club, should I turn off wind Noise Canceler? How would that effect non-wind loud recordings?
bob ross is offline
post #5 of 5 Old 12-29-2011, 01:29 PM - Thread Starter
bob ross's Avatar
Anyone?
Also another question. If I set audio input levels and I switch off manual mode, do those core settings retain?
When I'm recording, I want the shutter and iris to auto adjust. Will that put the audio back to "Auto" volume input levels?
Does that make any sense?
bob ross is offline
Reply Camcorders
