Which mid range 1080p cam has best image stabilization? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-05-2015, 12:09 AM - Thread Starter
mikek753's Avatar
Question Which mid range 1080p cam has best image stabilization?
hi,
Which mid range 1080p cam has the best image stabilization?
Any recommended for under $500 with 20x+ zoom?
No, tripod can't be used, just handheld
the low light isn't important.
any links for IS test results would be great
tnx
mikek753 is offline
post #2 of 8 Old 03-05-2015, 12:56 AM
Terfyn's Avatar
Quoted: 136 Post(s)
Liked: 41
I find the Panasonic HC-V750 the best. It has "hybrid" OIS which is a mix of mechanical and electronic stabilisation. I find it perfect for handheld videoing. IMO it is better than the Sony system.
Zoom is 20x optical going to 50x Intelligent ( no picture degradation) and 1500x top!!
Terfyn is offline
post #3 of 8 Old 03-05-2015, 05:49 AM
Quoted: 35 Post(s)
Liked: 4
HC-V770 has been recently released so worth checking out.
Sookgoo Shin is offline
post #4 of 8 Old 03-05-2015, 11:52 AM - Thread Starter
mikek753's Avatar
thanks for the reply
looks like V770 adds only HDR, which sounds cool.
however, can HDR work in 1080/60p mode?
I need 60p only. I don't need 24p at all.
So far I don't see much price discount for V750 vs new V770 as I hoped
mikek753 is offline
post #5 of 8 Old 03-05-2015, 03:32 PM
Dr 120fps's Avatar
Quoted: 18 Post(s)
Sonys BOSS is superior hybrid OIS.
Dr 120fps is offline
post #6 of 8 Old 03-05-2015, 06:16 PM
fishywishy's Avatar
Quoted: 17 Post(s)
which sony model under $500 has the BOSS system?
if you got steady hands, even the panasonic v250 with 50x can be steady
fishywishy is offline
post #7 of 8 Old 03-05-2015, 09:39 PM
Terfyn's Avatar
Quoted: 136 Post(s)
Liked: 41
I speak as I find.
Terfyn is offline
post #8 of 8 Old 03-06-2015, 12:32 PM - Thread Starter
mikek753's Avatar
no, my hands are not steady as I stop to start filming after ether run or ski or bicycle or etc activity, so my HR is way above 120
no, so far I don't see any sony cams with boss under $500. there are in $800+ range only
mikek753 is offline
Reply Camcorders
