another Comparison: Internal vs. External Recording - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-08-2019, 11:10 AM - Thread Starter
markr041's Avatar
Quoted: 1221 Post(s)
Liked: 417
Yet Another Comparison: Internal vs. External Recording
An external recorder allows one to record at higher bitrates and with better color - usually 422 sampling at 10bits versus 420 sampling at 8 bits. But can you actually see any difference?
The Sony RX0 ii outputs 4K 422 10bit video from its HDM port (according to Atomos). And you can simultaneously record to the sd card and externally - with the Ninja V you just use the record button on the camera and you get two recordings of the exact same scene.
The internal codec is XAVC S, 100 Mbps, 420 8bit. The recorder uses ProRes at 422 10bit 850 Mbps!
I shot using Slog2, so all the footage is graded - which is what the high-bitrate, high-bit codec is good for.
So, in the video you see the internal followed by the external version for each scene. and, yes, some scenes stress the codec: tree leaves moving in the wind, joggers, etc.
markr041 is offline
Reply Camcorders
