Sony RX0 ii 4K Anamorphic Test Video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-24-2019, 01:05 PM - Thread Starter
markr041's Avatar
Quoted: 1221 Post(s)
Liked: 417
I used the Moondog anamorphic adapter with a case that resulted in some vignetting, so I cropped in the sides a little here. With Moondog's own faceplate the results will be slightly wider and slightly higher resolution. The adapter gives you a widescreen POV but uses all of the sensor, unlike just cropping with upper and lower dark bands.
markr041 is offline
post #2 of 5 Old 07-03-2019, 07:04 AM - Thread Starter
markr041's Avatar
Liked: 417
Here is the Improved Anamorphic Result
Uses the Moondog faceplate and adapter (no vignetting):
markr041 is offline
post #3 of 5 Old 07-04-2019, 05:26 AM - Thread Starter
markr041's Avatar
Liked: 417
markr041 is offline
post #4 of 5 Old 07-06-2019, 09:50 AM - Thread Starter
markr041's Avatar
Liked: 417
markr041 is offline
post #5 of 5 Old 07-06-2019, 07:21 PM - Thread Starter
markr041's Avatar
Liked: 417
Anamorphic lens flare! "Stretch" limousine (how appropriate).
markr041 is offline
Reply Camcorders
