Sigma fp pocket size full frame cine/stills hybrid - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-11-2019, 07:58 AM - Thread Starter
jogiba's Avatar
Quoted: 801 Post(s)
Liked: 517
jogiba is offline
post #2 of 7 Old 07-11-2019, 01:28 PM
hatchback's Avatar
Quoted: 180 Post(s)
Liked: 86
Super exciting!!! It's claimed to be the smallest full frame mirrorless camera, with 24MP BSI-CMOS sensor and L-mount. More info:
https://petapixel.com/2019/07/11/sig...orless-camera/
https://www.cinema5d.com/sigma-fp-fu...ted-cine-mode/
hatchback is online now
post #3 of 7 Old 07-12-2019, 08:38 AM - Thread Starter
jogiba's Avatar
Quoted: 801 Post(s)
Liked: 517
With Sigma 35mm F1.2 DG Art lens
Sigma's new 35mm F1.2 DG DN Art is an ultra-fast semi-wide-angle prime lens for full-frame Sony, Panasonic and Leica mirrorless bodies. The lens, which Sigma claims can resolve over 50 million pixels, contains a total of 17 elements, including aspherical and 'SLD' glass. The minimum focus distance is 30cm (~11"), with a max magnification of 0.2x.
The 35mm F1.2 is fairly hefty, weighing over 1kg (2.4lbs) with a length of 136mm (5.4"). This is compared to the older 35mm F1.4 Art, which weighs 665g (1.5lb) and measures 94mm (3.7") in length. The filter ring of the new 35mm F1.2 is supersized too, at 82mm, thanks to that massive front element (see below).
The lens has an aperture ring that can be clicked or de-clicked, as well as a customizable AFL button. Build quality appears high, with a weather-sealed enclosure and a coating on the front element to repel oil and water.
The 35mm F1.2 DG DN Art lens will be available later this month, at an expected price of $1499 USD.
https://www.dpreview.com/news/871510...traffic_source
jogiba is offline
post #4 of 7 Old 07-12-2019, 03:48 PM
hatchback's Avatar
Quoted: 180 Post(s)
Liked: 86
Not exactly the travel camera+lens package I had in mind..
post #5 of 7 Old 07-12-2019, 11:38 PM
P&Struefan's Avatar
Quoted: 387 Post(s)
Liked: 137
True. In a typical production environment when you add on the rods, rails, mattebox, and follow focus mechanism (who is ever going to trust this contrast detect only AF in in any sort of professional work?), being small here doesn't count much anymore. As for casual use, is any small and compact L-mount zoom available to go with this? Does the back screen even tilt? No sensor based stabilizer? Then good luck to ever find a lens with a reasonable balance with the body that has a IS system in it.
I honestly don't think this camera can go very far.
P&Struefan is offline
post #6 of 7 Old 07-13-2019, 07:03 AM
Ken Ross's Avatar
Quoted: 7271 Post(s)
Liked: 8042
We'll be able to tell how good (or bad) it is when Hatch buys it and posts his first video from it! He does find it 'super exciting', so it won't be too long.
Current displays- LG 65C9, LG 77G7, LG 65B6
Ken Ross is offline
post #7 of 7 Old 07-13-2019, 06:27 PM
hatchback's Avatar
Quoted: 180 Post(s)
Liked: 86
My budget is tighter than it was a few years back, smartphone image quality has vastly improved, and high-end image quality improvements have slowed since I purchased my kit (AX100, D4, RX1). I'm least happy with my RX1 as a travel camera so think I would probably spring for a pocketable full frame camera with a 100 DxO score and a collapsible 28mm lens. I'd probably also spring for an AX100 replacement with significantly improved image quality.
Reply Camcorders
