Camcorder: Video To DVD Problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-13-2019, 02:56 PM - Thread Starter
cssb's Avatar
Liked: 0
I doubt if the computer matters, but I’ll include it anyway.
iMac (Retina 4K, 21.5-inch, 2017)
3 GHz Intel Core i5
8 GB 2400 MHz DDR4
macOS High Sierra
Version 10.13.06
Camcorder: Panasonic HC-V770 (2018 HD)
Last week I purchased Wondershare Filmora 9 Video Editor.
Everything seems to be working fine. I hook the camera directly up to my Mac, & save any videos I'm interested in.
I'm able to edit, make GIFs, change speeds, add text, etc.
For YouTube, I edit the video, save it to MP4, & upload it. Works great.
The problem arises when I try to burn a DVD.
I ‘was able’ to do this in the past.
I had a Panasonic dmr-es20 home DVD player/recorder. I’d hook my camcorder, (at that time, an older non-HD Panasonic) directly to the DVD recorder, record the sections of the video I wanted, then finalize the disc. (those discs still play on the 2 units that I'll mention later)
But the Panasonic recorder has since died, so that's no longer an option.
Since iMacs no longer have a CD/DVD drive, earlier this year, I purchased an LG slim portable DVD writer. (Model SP80NB80)
I know the unit is working, because earlier this year, I used it to install TurboTax.
I have the YouTube video shown above, saved on my Mac. I drag it into the video editor, & click export.
At that time, the following pop-up window appears.
http://www.imagebam.com/image/bc4ad71275589234
As you see, there’s 14 formats available. I’ve exported the video in MP-4 - MOV - MPEG2 - & AVI & burned each one to DVD using the LG writer.
The MP4 & MOV versions playback flawlessly on the LG, the MPEG 2 plays with pixelation, & the AVI won’t play at all.
But when I try to play it in either of the following 2 devices, the message is the same. Unsupported Disc
Panasonic DVD Player:
http://tv.manualsonline.com/manuals/...vds68.html?p=5
Sony DVP-CX995V: About 11 years old.
ttps://www.sony.com/electronics/supp.../25921341M.pdf
My guess is that it has something to do with finalizing the disc, which I did back when I used the Panasonic DVD recorder.
I have no idea if the LG writer is capable of doing that or something similar, or how to go about it, if it was ?
Or maybe I'm doing something else wrong ?
cssb is offline
post #2 of 5 Old 07-14-2019, 10:41 PM
Ungermann's Avatar
Quoted: 775 Post(s)
Liked: 120
Welcome to the digital world, finally (because what you were doing with connecting your camcorder to a standalone DVD burner is not how it is normally done).
If you want to do a proper DVD-Video, you need to author DVD-Video, which is a bunch of files and a directory structure of a specific format, not just a single file burned onto a disc. The export screenshot that you posted has DVD menuitem on the top right, what does it do?
https://en.wikipedia.org/wiki/DVD-Video
Ungermann is offline
post #3 of 5 Old 07-15-2019, 01:10 PM - Thread Starter
cssb's Avatar
Liked: 0
My way of going about it may seem dated to you, but it worked.
All I see on the top right, is the bottom of the video window. Here’s a full screenshot without the export format pop-up.
http://www.imagebam.com/image/3dc07b1276795104
cssb is offline
post #4 of 5 Old 07-21-2019, 12:42 PM - Thread Starter
cssb's Avatar
Liked: 0
I figured it out. Using Wondershare Filmora 9 & the LG portable DVD writer, I was able to burn DVD-RAM.
They play perfectly on all the units I wanted them to.
cssb is offline
post #5 of 5 Old 07-21-2019, 04:32 PM
Ungermann's Avatar
Quoted: 775 Post(s)
Liked: 120
DVD-RAM, wow! Glad you figured it out.
Reply Camcorders
