4K 160P 10bit Video Example - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By markr041
post #1 of 6 Old 09-09-2019, 03:25 PM - Thread Starter
markr041's Avatar
Quoted: 1231 Post(s)
Liked: 426
Yes, 4K 160 fps and 10bit, with widescreen crop.
Ungermann and Cloudstrewn like this.
markr041 is online now
post #2 of 6 Old 09-10-2019, 02:21 AM
Cloudstrewn's Avatar
Quoted: 85 Post(s)
Liked: 36
https://youtu.be/SlAWSKgeByA
This is a game-changer isn't it. Starting to make Sony and Panasonic offerings look rather ordinary.
The picture mostly looked clean, but around 3:20 the greenery was noisy. Did you use different settings here?
Presumably you have an external monitor, do you power camera and monitor off a single battery?
Cloudstrewn is offline
post #3 of 6 Old 09-10-2019, 05:35 AM - Thread Starter
markr041's Avatar
Liked: 426
Yes, the camera is remarkable. Yes, I noticed the noisy trees in that clip too; I will check if the metadata gives me a clue as to why. I do not recall any different setting, and the scene is sunlit.
I do not use an external monitor for any of the videos I shot with this camera - no need. The on-camera lcd is sufficient for me. I use focus peaking (which works using AF) and focus magnification (MF) for focus. So, my "rig" is camera + lens - a compact ProRes and RAW 4K video shooter with relatively high DR, at high speeds.
post #4 of 6 Old 09-13-2019, 08:04 PM - Thread Starter
markr041's Avatar
Liked: 426
The Crosswalk: Walking as Ballet
Wait for the skateboarder at the end. This is one clip.
post #5 of 6 Old 09-14-2019, 02:34 AM
Quoted: 85 Post(s)
Liked: 36
Noise in the detailed green areas is much less evident here than in the previous 160p video. Did you use noise reduction in camera or in post here?
post #6 of 6 Old 09-14-2019, 06:36 AM - Thread Starter
markr041's Avatar
Liked: 426
Yes, here I used Neat video to reduce noise. Did a good job. Easy.
Reply Camcorders
