Date and Time Issue With Sony Handycam - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-29-2019, 12:31 PM - Thread Starter
Liked: 0
I have a HDR-CX550V which has worked great since I got it back in 2011.
However I noticed a few weeks ago while back up the videos that the files all showed dates with the year being 1999.
I went into the camera and sure enough the date had 1999 as the year. So I changed it to the correct date on the camera.
Last week we are on vacation at Disney World so we took a lot of videos.
I was backing up the files and at first noticed no problems.
But then I noticed for any videos taken after 10/23/19 the date again changed this time with the year 200.
Fortunately I was able to correct the dates on these files I knew when the change happened.
The camera battery pack was never empty and I did recharge it once to top it off.
Also from what I know there's an internal battery that's supposed to keep the date and time-but I figure this wouldn't been needed since the battery pack always had a charge.
Any idea what's causing this?
Shaun Streich is offline
post #2 of 10 Old 10-29-2019, 03:35 PM
Ungermann's Avatar
Quoted: 778 Post(s)
Liked: 122
What does the Operating Manual say regarding this?
Internal battery is likely a non-rechargeable galvanic cell. Check your Operating Manual.
Ungermann is offline
post #3 of 10 Old 10-29-2019, 07:38 PM
P&Struefan's Avatar
Quoted: 412 Post(s)
Liked: 146
It's likely the internal battery. I have the Sony CX500E, a generation older than yours and since I have rarely used it over the past few years I have always put a fully charged H or V series battery on it while it's not used. Both the time and date as well as most of the camera settings are set to the current date/correct preset values when the camera is used again. Once in a while it has been put away too long both the external and internal batteries ran out I had to change the external battery and reset the whole thing again. But once they have been reset everything worked perfectly fine. In your case, I suspect the internal battery maybe nearly worn out so it can't hold or pass through the charge to allow the timer to function properly. Your other settings might later be affected too but I have no idea how much this thing would cost to replace in your area.
P&Struefan is offline
post #4 of 10 Old 10-30-2019, 12:38 PM - Thread Starter
Liked: 0
That's the thing-the first time this happened I am certain the external battery had drained since the camcorder hadn't been used in awhile.
But for the trip last week I made sure the battery always had a charge so it was never empty.
I am just trying to remember if the date changed after I had plugged it back in to get the battery to 100% again. But again the battery still had some charge left.
post #5 of 10 Old 10-30-2019, 12:41 PM
Ungermann's Avatar
Quoted: 778 Post(s)
Liked: 122
post #6 of 10 Old 10-30-2019, 01:05 PM
Cloudstrewn's Avatar
Quoted: 78 Post(s)
Liked: 36
Unfortunately, low manufacturing standards were commonplace in the latter years of the Roman Empire.
(sorry)
Cloudstrewn is offline
post #7 of 10 Old 10-30-2019, 01:28 PM - Thread Starter
Liked: 0
(sorry)
Wah wah.
post #8 of 10 Old 10-30-2019, 01:29 PM - Thread Starter
Liked: 0
Only thing I could find was the mention of the internal battery for the date and time-but cannot find a part # for the battery.
post #9 of 10 Old 10-31-2019, 02:29 AM
spyker1212's Avatar
Quoted: 152 Post(s)
i have sony hdr550, cx700, ax53, ax100, ax200, gopro 4, 6, 7. soon 8 and max 360
does your hdr500 play memories folder still works? you can connect camcorder directly to computer and save from there.
if you remove the card and transfer files to computer. it will give you 0001, 0002 file number
use can download free software 'Bulk Rename Utility'
https://www.bulkrenameutility.co.uk/
can change date and time thru software. but be very careful when renaming cause it may mess-up you file order taken. experiment with dummy video first until you get use of the software
spyker1212 is offline
post #10 of 10 Old 10-31-2019, 11:32 AM - Thread Starter
Liked: 0
That's the software I used to correct the dates from the vacation I was on last week.
Unfortunately the ones from earlier this year I am not as certain which dates the videos were recorded on.
Reply Camcorders
