Video Editor for HC-X920 Panasonic Movie Camera - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-24-2020, 08:39 AM - Thread Starter
Liked: 0
I have a Panasonic HC-X920 movie camera. Would say that I am still in beginners class. Using the HD Writer program cutting and pasting is easy with the AVCHD files that the camera makes.
I would like to try different speeds of slow motion. The camera's shutter/frame rate can be adjusted. But the HD Writer does not support speed changes. Seems somewhat confusing to buy a video editing program that will handle AVCHD files and have support for and give good speed control.
Looking at "Magix Movie Edit Pro Plus" program to fill my needs.
Would this Program be a good choice for AVCHD files or what would you recommend? Thanks
123penn is offline
post #2 of 2 Old 05-24-2020, 09:25 AM
Ungermann's Avatar
Quoted: 809 Post(s)
Liked: 123
Originally Posted by 123penn View Post
Looking at "Magix Movie Edit Pro Plus" program to fill my needs. Would this Program be a good choice for AVCHD files or what would you recommend? Thanks
Why don't you download a free trial and decide for yourself?
Ungermann is offline
Reply Camcorders
