Lighting automation: new home: X10/Power line or wirelesss? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-26-2010, 10:51 AM - Thread Starter
mesasale's Avatar
We are building new home and wondering which one should I go with for lighting automation? I read that X10 has some issues and not reliable. Also it's not two way.
Should I go with wireless solution of Zigbee or Zigwave? How about Power line method? is it reliable and secure?
mesasale is offline
post #2 of 6 Old 08-26-2010, 12:47 PM
Neurorad's Avatar
Quoted: 279 Post(s)
Liked: 155
Lots of lighting discussions over at cocoontech.com forums.
Seems like most people there go with UPB. Several manufacturers offer UPB products, including HAI and SimplyAutomated.
I've chosen Lutron Radio RA2 to use in my home. I'm still in the process of spec'ing it so can't give you any firsthand experience.
UPB is more DIY friendly than RA2.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 6 Old 08-26-2010, 01:19 PM
Anthony A.'s Avatar
ra2 is probably the most robust wireless solution currently on the market. with new construction, i would go with hardwired though. depends on your budget and how many lighting loads you have, but a lutron homeworks 4, centralite, vantage system is bulletproof. UPB is decent, but is not 100%. when i say this, i mean that each scenario is different and some users experience nothing but headaches while others have perfect systems. i didn't want the hassle of a 50/50 draw with UPB, so i went homeworks 4 and it is even more solid than i ever expected.
Anthony A. is offline
post #4 of 6 Old 08-27-2010, 04:39 AM
jkv
jkv's Avatar
Since you are building and if the walls are still open, you may want to consider a hard-wired lighting control system.
Riverside Cinemas
jkv is offline
post #5 of 6 Old 08-30-2010, 08:42 PM
snow11shore's Avatar
Yes if your walls are open go with hard wired. Vantage or Homeworks if you have enough in your budget. Centralite if you can't spend extra for digital controls.
snow11shore is offline
post #6 of 6 Old 08-31-2010, 07:48 PM
ChrisWiggles's Avatar
Liked: 25
If you are building absolutely put wires in the wall.
Doing a wireless system in a new construction is, IMO, stupid.
ChrisWiggles is offline
Reply Home Automation
