stay away from Control4 - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 95Likes
post #361 of 364 Old 09-24-2019, 09:23 PM
SMHarman's Avatar
Quoted: 419 Post(s)
Liked: 140
Originally Posted by Bigmoviefan View Post
Just updated my AppleTV and it no longer works with my Control 4. AppleTV remote works but the control 4 does not.
Did ATV add an allow IP control in their options or settings?
Sent from my E6603 using Tapatalk
SMHarman is offline
post #362 of 364 Old 09-24-2019, 10:19 PM
TrendSetterX's Avatar
Quoted: 420 Post(s)
Liked: 315
Your dealer used the wrong driver. The driver your dealer used is only certified to work with older AppleTvs and was never guaranteed to work with the current gen. Your dealer either needs to swap out for the correct IP driver or switch out to Jesse’s IR driver.
ezlotogura likes this.
Theater: Sony 75x940E | Yamaha 3060 | DirecTv HR54 | ATV4K | MP 4K HDBaseT Extender | SVS PC2000 sub | 5.1 surround
Networking: ASUS RT-AC68U (wireless disabled) | Ubiquiti AmpliFi HD Mesh Wireless with wired back-hauls
Automation & Lighting: Control4 & Lutron Homeworks Interactive
TrendSetterX is offline
post #363 of 364 Old 09-25-2019, 07:07 AM
ezlotogura's Avatar
Quoted: 253 Post(s)
Liked: 109
the correct IP driver will require an EA controller I believe and you need to be on 2.10.x and above. Otherwise as referenced there is an IR driver you can use if you do not meet these requirements.
ezlotogura is offline
post #364 of 364 Old 09-25-2019, 12:14 PM
Liked: 1
This is apart of the package though. Control4 is its own system.
MileHighAutomation is offline
Reply Home Automation
