Lutron question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-09-2018, 10:33 AM - Thread Starter
Lic265's Avatar
Lutron question
Hi
I have a room with a legacy Lightolier system. 4 keypads with buttons for scenes, all hard wired together that can each control 4 separate lighting loads on dimmers.
Can I use the Lutron dimmers and multiple Pico remotes to achieve the same thing?
Other options?
G
Lic265 is offline
post #2 of 2 Old 04-11-2018, 06:53 AM
Quoted: 115 Post(s)
Liked: 35
Originally Posted by Lic265 View Post
Hi
Other options?
G
The answer you your question is yes, but I'm not sure what's involved because I'm not sure how your current system is wired. I saw this a couple days ago, but hoped someone with actual Lightolier knowledge would chime in. Wherever the actual load bearing device is will be where the new Lutron and then you can use Pico's or SeeTouch controllers as you please.
If you make a wiring diagram it might be easier to give more specific feedback.
James Babin - System designer myEasytek
Last Post: Low Voltage Wiring Guide
JT Babin is offline
Reply Home Automation
