Vantage Design Center 3.8 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-07-2018, 10:29 AM - Thread Starter
jpooton's Avatar
Hello,
I have a Vantage Q-Link system that I'm looking to start migrating to Infusion (pick up new MC & mounting block on eBay, rest is compatible). My Q-Link hardware was wired/installed by a local dealer who's long gone. However, I did all the system programming/automation work anyway, with their Q-link software he gave me (and I was able to keep updated until it was discontinued).
Anyway, long story short, I'm trying to get my hands on the newer Vantage Design Center software for the Infusion MC. So far I've failed. In older threads people contacted Vantage dealer support which I have twice now and either that's a black hole or they just don't want to respond. Searching the net has also resulted in nothing. I've done programming/system design for years, so I really don't need hand holding -- just the software.
Does anyone have any thoughts or a copy they could help me out with ?
Thanks..
-James
jpooton is offline
post #2 of 9 Old 05-09-2018, 10:17 AM
westcojack's Avatar
Quoted: 17 Post(s)
I sent you a pm
westcojack is offline
post #3 of 9 Old 06-06-2018, 08:21 AM
dzone's Avatar
Liked: 0
Originally Posted by westcojack View Post
I sent you a pm
Hi westcojack,
I'm in the same boat - trying to upgrade an old Q-Link system to InFusion and also find or write a driver to integrate it with a Crestron 3-Series controller. Any help much appreciated!
Thank you,
Rick
dzone is offline
post #4 of 9 Old 09-03-2018, 03:24 AM
Liked: 0
I am also in the same situation and I have no way of finding the software
I have version 3.6.2.11 but I need a more updated version.
Anyone can help me?
marcorossi is offline
post #5 of 9 Old 12-01-2018, 02:24 PM
ptr727's Avatar
Quoted: 12 Post(s)
Hi, I just replaced some incandescent T10's with non-dimmable LED's, and I need to change the power profile to relay and instant on and off.
I'm also looking for the latest Design Center, anybody willing to share, would be much appreciated?
ptr727 is offline
post #6 of 9 Old 08-15-2019, 06:37 PM
Liked: 0
IS anyone able to share the software? I am in a similar predicament.
DisadVantaged is offline
post #7 of 9 Old 12-09-2019, 08:14 AM
Liked: 0
I sent you a pm
I am in the same boat - any way you could share the software?
cbel is offline
post #8 of 9 Old 12-14-2019, 10:49 PM
Liked: 0
I too am in the same boat. Any guidance would be appreciated.
TandLDad is offline
post #9 of 9 Old 12-15-2019, 07:01 AM
smoothtlk's Avatar
Quoted: 305 Post(s)
Liked: 95
Did the folks looking for vantage software buy homes with the system? Or was there a dealer / installer that hasn't been helpful?
Have you tried another dealer?
The software I am sure is dealer only and I am sure it's against Vantage policy and agreement to distribute their software to unapproved users.
I suspect that's not new info to the folks looking to find the software.
the other way around it is some automation controllers have bidirectional integration with vantage. So, the vantage system becomes a lighting system (its core strength) and the automation controller is what manages all. Some automation controllers cater to DIY where you get access to the configuration tools.
smoothtlk is offline
Reply Home Automation
