Phillips Hue Leds strip noise - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Chaendler
post #1 of 2 Old 05-28-2019, 07:38 AM - Thread Starter
Liked: 1
Hi guys,
Does the AC-DC transformer of the led strip emit an annoying high-pitch noise when you set the leds at maximum power?
thanks
popalock likes this.
Chaendler is offline
post #2 of 2 Old 08-13-2019, 01:32 PM
Liked: 1
Pretty much any AC transformer can whine if there's some kind of issue with the electronics. There's a pretty good explanation of why that happens, here. If it only happens at full power you might want to do run some diagnostics to make sure there's no serious issue lurking.
MDmrs is offline
Reply Home Automation
