Alarm.com IP Backup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-12-2019, 11:47 AM - Thread Starter
BIC2's Avatar
Quoted: 94 Post(s)
Alarm.com IP Backup
Alarm.com recently started offering cellular communicators with IP backup. It's hooked to my router with Ethernet cable. Oddly, there are no active data lights at the Ethernet port. It's the only one the alarm installer has installed so there's no reference point. The monitoring service said they could see both the cellular & IP signals were good.
Nonetheless, I'm not comfortable without any data lights at the port. Tried different ports, not the issue. In the picture, you can see the other three have one or two steady or blinking lights. The top white cable has no lights. Any thoughts on this? Thanks.
BIC2 is offline
post #2 of 4 Old 06-12-2019, 12:44 PM
FlyingDiver's Avatar
Quoted: 230 Post(s)
Liked: 65
Probably means the communicator doesn't power up the port unless it's using it. Not totally unreasonable if it's trying to use as little power as possible.
Did you watch the lights while they were testing it?
FlyingDiver is offline
post #3 of 4 Old 06-12-2019, 01:11 PM - Thread Starter
BIC2's Avatar
Quoted: 94 Post(s)
No, wasn't really watching the lights while calling the monitoring company but they didn't test it per se, they said they could see it was communicating. Guess the only way to really test it is disconnect the cellular modem and see if it communicates. Unfortunately, the installer doesn't know if that's possible.
BIC2 is offline
post #4 of 4 Old 06-12-2019, 02:38 PM
Quoted: 230 Post(s)
Liked: 65
Does the communicator have a SIM chip you can remove? That would disable it.
Reply Home Automation
