Which company now has the consumer/DIY option - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-13-2019, 08:16 AM - Thread Starter
goodguy19's Avatar
Hello all. I remember reading about it and tried searching all over and can’t find it. I remember seeing that either Control4, Savant or Crestron within the last couple years offers a consumer or DIY version where you don’t need a dealer. I think it had some limitations but wanted to look into it. Any help would be appreciated.
Thank you!
goodguy19 is offline
post #2 of 5 Old 08-13-2019, 01:01 PM
Quoted: 75 Post(s)
Liked: 26
Control 4 has the Composer HE (Home Edition) which allows you to do some programming, but doesn't allow for installing new devices onto the system - maybe that's what you are thinking about? I think Crestron has something similar.
A few years ago Savant launched a DIY remote - I believe it was creatively called the "Savant Remote" which was basically their version of a Harmony Elite (Touchscreen RF remote to a hub which only communicated with devices over IR). It was by all accounts a disaster and they pulled it from the market.
I stand to be corrected, but in the professional grade HA world the only system I know of that officially offers (almost) the same level of access to DIYer is Lutron Radio Ra2, and of course that's just lighting and HVAC controls.
freeoscar is offline
post #3 of 5 Old 08-13-2019, 01:07 PM
ezlotogura's Avatar
Quoted: 251 Post(s)
Liked: 108
C4 also offers When/Then which is basic programming via a WebUI which requires 4sight which is $100/year. But yes, you can do even more with Composer HE which is $149 and comes with 1 year of 4sight too. You can do any programming as mentioned above - you just cannot add/bind new hardware into a project.
ezlotogura is offline
post #4 of 5 Old 08-13-2019, 07:05 PM - Thread Starter
goodguy19's Avatar
Thanks for the info!
post #5 of 5 Old 08-17-2019, 01:49 PM
Bigus's Avatar
Quoted: 594 Post(s)
Liked: 558
CQC and allonis myserver seem to be the most robust platforms that fully support the diy community.
Bigus is online now
Reply Home Automation
