Nest Doorbell Integration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-16-2019, 08:17 AM - Thread Starter
Quoted: 63 Post(s)
Liked: 9
HI All,
I'm having some trouble getting my Nest doorbell to work with the system I was intending.
I have a 12 channel multi-zone audio matrix with a PA input and 3.5mm input trigger, which is connected to a Niles DBi-2 Doorbell Interface.
When I connected the Nest Hello to the 0-30v Input on the Niles, I don't get any power at all. The Nest won't power up.
How can I get this working in order for the Doorbell to work and then send the trigger to the Niles unit?
Do I need to get a separate power supply for the Nest Hello?
Any help would be appreciated!
F
Falcon2915 is offline
post #2 of 6 Old 09-16-2019, 05:17 PM
AV_Integrated's Avatar
Quoted: 1648 Post(s)
Liked: 1197
You aren't connecting the Niles to the Nest directly are you?
The Niles doesn't have any power output on that 0-30v connection. That's a connection point for the existing doorbell transformer. See page 11 of the Niles manual. It shows the connection point. It may even allow for a 0v contact closure. But, it doesn't create usable voltage for a Nest from the Niles. You will need an external transformer to power the Nest.
http://resources.corebrands.com/prod...I-2_manual.pdf
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #3 of 6 Old 09-16-2019, 05:21 PM
torii's Avatar
Quoted: 3626 Post(s)
Liked: 2061
not a nest problem but I have arlo doorbell and the battery needs replaced every 3 weeks or less. biggest pain in my ass...
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #4 of 6 Old 09-17-2019, 02:34 PM
Liked: 1197
You are running v1.3 of the software right?
https://community.arlo.com/t5/Arlo-A...1643329/page/5
I wouldn't get any doorbell solution that needs a battery replaced to run. Most doorbells are two wire systems and even if I had to replace my chime or do something else with it (like Nest requires), I would do so just to ensure that it works when I needed it to work.
Changing batteries on my remote controls is bad enough.
post #5 of 6 Old 09-18-2019, 07:26 PM - Thread Starter
Quoted: 63 Post(s)
Liked: 9
Thank you for the response! I have been mulling it over and thought that might be where I was going wrong.
Thanks for confirming.
So if I get a suitable power supply for the nest I should be alright?
post #6 of 6 Old 09-18-2019, 08:55 PM
Liked: 1197
I would think so, but I bet you can call or email Nest directly to get an exact answer. I would just let them know that you have no pre-existing doorbell, so what should you do for a power supply. That has got to be a question they hear regularly.
Reply Home Automation
