Linear Actuator Installation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-25-2019, 05:31 PM - Thread Starter
Liked: 0
I"m looking for help in selecting and installing linear actuators. wiring these to a remote control system seems simple enough. Selecting the right lengths is important because the shorter stroke allows me to install these more to the side but forces the location closer to the hinge. Requiring a lot more force. a longer stroke that would seem safer and require less overall force would need to be positioned in the stairwell and would not look so good.
Question is how do I calculate the force needed for the shorter stroke mounted closer to the hinge?
ID:	2632250   Click image for larger version
David Ashworth is offline
post #2 of 7 Old 10-29-2019, 03:24 PM
function12's Avatar
Quoted: 42 Post(s)
Liked: 35
You might reach to the guys at www.frightprops.com Linear actuators are used all the time in the Halloween Haunt business.
function12 is offline
post #3 of 7 Old 10-29-2019, 03:33 PM
ScottAvery's Avatar
Quoted: 729 Post(s)
Liked: 213
Just make sure you get one of these to open it:
https://www.gentlemandoorautomation....06/batman.html
ScottAvery is offline
post #4 of 7 Old 10-29-2019, 04:21 PM
Deane Johnson's Avatar
Liked: 25
Originally Posted by David Ashworth View Post
I"m looking for help in selecting and installing linear actuators. wiring these to a remote control system seems simple enough. Selecting the right lengths is important because the shorter stroke allows me to install these more to the side but forces the location closer to the hinge. Requiring a lot more force. A longer stroke that would seem safer and require less overall force would need to be positioned in the stairwell and would not look so good.
I recently installed a linear actuator to lift a bridge scene across the room entrance to my model railroad. Very different than your installation, but I did get to learn a little bit about LAs.
The one thing I did to determine my lift requirement was to purchase an inexpensive digital scale like this one. Probably way too light for what you're doing:
https://www.amazon.com/Dr-meter-Elec...2386283&sr=8-5
My load was much different than yours, much lighter, but I needed the same information you're needing. It strikes me the load requirement you have back toward the hinges is going to be rather immense. If you think about those huge railroad bridges that lift much the same way as your stairs, they have huge counterbalance on the back so the lift requirement is greatly reduced. I'm thinking you're going to need to figure out a way to move the LA out closer to the raised end, which will, of course, increase the complexity of the actuator to provide the amount of travel you need. I'm running about 60" of travel on mine. I'd want an actuator rated for about twice what the bridge appeared to need.
Here's the company I ended up purchasing from:
https://www.firgelliauto.com/collect...near-actuators
Once you decide how far out you can place an actuator, you might even be able to use a bathroom type scale with a pole of some sort resting on it and holding the bridge up about half way. I would think that might begin to give you an idea of the force required to lift the bridge. It would be pretty generalized. You'll likely need to think about using two actuators, one on each side to share the load.
I'm certainly no expert on this, just someone who had a need to figure out the same solutions on a different type structure.
Deane Johnson is offline
post #5 of 7 Old 10-29-2019, 07:38 PM
smoothtlk's Avatar
Quoted: 292 Post(s)
Liked: 93
That is beyond a standard linear actuator. That is more in line with a hydraulic cylinder / pump that is needed.
Looks like the stairs are a couple hundred pounds. And then the leverage factor if you put the lift mid span.
How are you going to ensure water doesn't enter the lower level?
smoothtlk is offline
post #6 of 7 Old 10-30-2019, 02:09 PM
ScottAvery's Avatar
Quoted: 729 Post(s)
Liked: 213
Also consider a considerable counterweight to reduce/eliminate the static load and lower the force required to move it. An arm sticking straight back in the closed position, high up the ramp close to the hinge, on one or both side edges, should end up about vertical when the door is opened. If it is heavy enough the arm could be short enough to remain over the concrete wall and not interfere with ingress/egress.
The same could be accomplished with ropes and pulleys, chains and sprockets, or one side of a garage door spring.
post #7 of 7 Old 10-31-2019, 08:27 PM
smoothtlk's Avatar
Quoted: 292 Post(s)
Liked: 93
Harbor Freight has a 2500 lb electric cable winch on sale for $50
You might be able to use that with some pulleys to bring the stair up.
Reply Home Automation
linear actuator
