Harmony Elite Hub remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-31-2019, 09:58 PM - Thread Starter
Liked: 0
We have two Yamaha AV receivers located in the same cabinet, one operates gear in the cabinet room, the other operates the system (some of which is in the same cabinet) for another room.
The Harmony Hub for the second room is located in the second room, with an IR feed back to the AV receiver and a Foxtel box.
To prevent the remote in the cabinet room operating both AV receivers, the Remote ID on the receiver the for the other room was changed from ID1 to ID2, and that does the trick for the room in question.
The problem is that the Harmony Hub in the other room can no longer communicate with the AV receiver with the changed ID. It communicates well with the Foxtel unit in the same cabinet.
How do I get the other room remote to communicate with the changed ID receiver?
Geoff Houghton is offline
Reply Home Automation
