Cheapest Way for Remote Control of Lights - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-29-2019, 06:25 PM - Thread Starter
Liked: 0
My shop is in a separate building about 100' from the house. A wifi extender delivers a good enough signal such that I can watch HD video via Roku in the shop. That is my only connectivity.
Occasionally, I forget to turn off one of more of the three lights inside the shop. Our schedule in the main house is that we never notice a light being left on in the shop until we are getting ready for bed. Also, it seems this only happens when it is cold, rainy or snowing, and windy. My enthusiasm for going over to the shop is at a low ebb.
Is there an inexpensive way for me --- via an app on the phone, I suppose, or even via my PC --- to control those light switches from the main house and thus avoid my trips in the rain and wind and cold?
Curmudgeon10 is offline
post #2 of 7 Old 11-29-2019, 07:24 PM
smoothtlk's Avatar
Quoted: 305 Post(s)
Liked: 95
There are cheaper ways but Lutron Caseta and a Pico remote kit would be a good start.
smoothtlk is offline
post #3 of 7 Old 11-30-2019, 04:00 PM
Deane Johnson's Avatar
Liked: 25
How about some sort of protocol for the lights that can be run by a programmable hub. Then you can set them to automatically get an "off" command every night at a certain time. It could be a very simple system. I don't have a recommendation, but there's got to be something very simple available since you have somewhat of a wi-fi signal.
Deane Johnson is offline
post #4 of 7 Old 12-01-2019, 06:47 AM
DanPackMan's Avatar
Quoted: 488 Post(s)
Liked: 1238
There are a number of low cost wireless switches and plugs that fit your bill, they can be controlled from your phone, just get on Amazon and search "wireless smart plug" and "wireless smart switch".
I have used the Jinvoo (app) compatible plugs with good results.
DanPackMan is online now
post #5 of 7 Old 12-05-2019, 01:10 PM
alucard_x's Avatar
Quoted: 25 Post(s)
Liked: 25
I use Sengled for this. However, there may be cheaper alternatives.
alucard_x is offline
post #6 of 7 Old 12-05-2019, 01:15 PM
Liked: 0
I would go with the Lutron Caseta kit - has an app. These products will be around for a long time and Lutron provides support. I tried some cheap amazon wifi light dimmers - those companies come and go and constantly change their products - try to replace one of those switches or add new ones 2-3 years from now. The ones we bought are nowhere to be found anymore -had to buy some off ebay -some no name wifi off amazon.
1touchdesigns is offline
post #7 of 7 Old 12-06-2019, 08:30 AM
ckronengold's Avatar
Quoted: 318 Post(s)
Liked: 127
if your wifi is good enough to stream, its good enough to turn off a light.
TP-Link wifi light switch is nice and cheap and reliable.
https://www.amazon.com/Kasa-Smart-Li.../dp/B01EZV35QU
Video: Epson 6050 / Panny DP-UB420 / OPPO-103
Audio: Marantz 7010 / MartinLogan Motion 40 (LR), 50XT (center), M2 (surrounds)
Streaming: nVidia Shield / Roku Ultra / Chromecast Ultra
NAS: Synology 1515+ Server: Ubuntu 18.04, i7-8700 CPU
HTPC: Win10 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
Reply Home Automation
