Motion sensor with e-mail notification - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-09-2019, 06:31 AM - Thread Starter
cowboyzx6's Avatar
I currently have several POE cameras on property and they have built in motion detection with e-mail or SMS notification. However, they are very prone to false alarms.
I would like to incorporate another solution. My thought was something that if you "cross" the line/path it would detect and send an alert? I guess something similar to the concept of a garage door opener sensor. Anything along those lines anyone can recommend?
cowboyzx6 is offline
post #2 of 3 Old 12-09-2019, 06:22 PM
smoothtlk's Avatar
Quoted: 305 Post(s)
Liked: 95
ELK M1 Gold. Connected to myServer for the notifications. I can't remember if the ELK will send an email on it's own.
I am sure there are simpler solutions, but that's how we do it.
smoothtlk is offline
post #3 of 3 Old 12-10-2019, 07:16 PM
ClayliketheDIRT's Avatar
Liked: 24
newer lillin cameras have trip wire alarms instead of motion allowing you to send emails and such
ClayliketheDIRT is offline
Reply Home Automation
