IR to RS232 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-09-2019, 11:32 AM - Thread Starter
Dave T's Avatar
Quoted: 73 Post(s)
IR to RS232
I would like to be able to turn off my Marantz processor in response to the “off” IR code sent by my DIRECTV remote. So I want some kind of device that I could learn the DIRECTV IR code, and in response from seeing that IR signal it would send the RS232 command to the marantz.
Can anyone recommend such a device?
Dave T is offline
post #2 of 4 Old 12-09-2019, 06:14 PM
smoothtlk's Avatar
Quoted: 305 Post(s)
Liked: 95
Yes, it's called a good automation controller.
That's today probably more than you wanted to hear.
smoothtlk is offline
post #3 of 4 Old 12-10-2019, 02:37 PM
AV_Integrated's Avatar
Quoted: 1677 Post(s)
Liked: 1213
Can't you program the remote to do the Marantz? Not sure which model remote you have, but some DTV remotes do support controlling the Marantz products directly.
https://www.directv.com/DTVAPP/content/remote_codes2
You could also ditch the DirecTV remote in favor of a universal remote which you can program to do everything.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is offline
post #4 of 4 Old 12-18-2019, 02:09 PM
sbarnesvta's Avatar
Quoted: 27 Post(s)
I have used products from these guys in the past with some success.
http://www.celadon.com/Industrial/IRC38/IRC38.html
SBTS-Inc.com
- Certified Crestron Master Programmer and DM T-4K, D-4K, E-4K, DM-NVX Certifications.
- RTI Programmer/ Driver Developer
- Rational Acoustics Smaart Certified
- QSC QSYS Lvl 2 Certified Programmer
sbarnesvta is offline
Reply Home Automation
