Replacing X10 with hand remote to modern equip - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-17-2019, 04:09 PM - Thread Starter
Velvis's Avatar
Question Replacing X10 with hand remote to modern equip
I currently have an X10 system that controls a porch light and outdoor post light and a living room light.
However the system has been failing and I want to replace it with modern equipment.
Is there any modern system that has or supports a hardware handheld remote similar to the X10 remote? I am aware of using a phone, but would like a solution as close to possible to the existing solution. It is for an elderly woman and using a phone would prove difficult.
I have thought of putting two the caseta remotes together back to back but that would only provide control of two lights but it may be my only option.
I figured I would reach out here and see if there maybe something I am not aware of.
Velvis is offline
post #2 of 4 Old 12-26-2019, 06:34 AM
PJL99's Avatar
Quoted: 532 Post(s)
Liked: 362
Insteon components would work fine. There is a "palm pad" like controller that could be used to control the switches. No hub is required for this type of direct control.
PJL99 is offline
post #3 of 4 Old 12-26-2019, 09:00 PM
e268's Avatar
I has X10 for a long time, and eventually the remote stopped working. I replace all my x10 with insteon and has been very reliable.
e268 is offline
post #4 of 4 Old 01-07-2020, 11:19 AM
westcojack's Avatar
Quoted: 17 Post(s)
X10
Why not just combine the porch and post lights together, its probably a better solution for an elderly person anyway?
westcojack is offline
Reply Home Automation
