Alexa TV Control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-04-2020, 07:09 PM - Thread Starter
mccoady's Avatar
Quoted: 13 Post(s)
Alexa TV Control
My wife is in a nursing home and would like to be able to turn off and on her tv using her Echo Dot... what are my options to do this starting with the least expensive?
Her tv isn’t the latest but does have an HDMI input.
mccoady is offline
post #2 of 10 Old 02-05-2020, 09:00 AM
smoothtlk's Avatar
Quoted: 317 Post(s)
Liked: 97
To narrow you in,
Without knowing what TV she has, we assume it can be controlled via Infrared.
So you would need a controller that integrates with Alexa and can be configured to send the proper On and OFF IR commands for that particular TV.
I will take a stab that SmartThings hub maybe with a GlobalCache IP to IR device.
I haven't done the research to know if SmartThings hub supports GC.
Our controller does the above but it would be more expensive but certainly would work.
smoothtlk is online now
post #3 of 10 Old 02-05-2020, 09:19 AM
function12's Avatar
Quoted: 44 Post(s)
Liked: 35
Alexa will also work with the Logitech Harmony remotes. The drawback is going to be WiFi. Alexa is going to need WiFi and so will the Harmony remote. If the Wifi goes down or the change the passwords. The system won't work.
function12 is offline
post #4 of 10 Old 02-05-2020, 09:54 AM - Thread Starter
mccoady's Avatar
Quoted: 13 Post(s)
Smoothtlk I'm familiar with the SmartThings Hub since I have one at my home but don't know anything about GlobalCache IP to IR devices.
function12 I think going the Logitech route can get pretty expensive as I have a Harmony Hub and Elite remote at home... as far as WiFi that's not really an issue as far as I am concerned.
I'm looking for a solution in the $100 range if possible and yes her Samsung TV is controlled via Infrared.
mccoady is offline
post #5 of 10 Old 02-05-2020, 11:33 AM
smoothtlk's Avatar
Quoted: 317 Post(s)
Liked: 97
The Smarthings hub (a Samsung product) might even control her TV via IP (not IR). That is even better. Find out here TV model number.
post #6 of 10 Old 02-05-2020, 11:39 AM - Thread Starter
mccoady's Avatar
Quoted: 13 Post(s)
It'll be several days before I am able to look at it but it's just a cheap Samsung I imagine a few years old the nursing home just happened to have to loan out.
mccoady is offline
post #7 of 10 Old 02-05-2020, 12:01 PM
smoothtlk's Avatar
Quoted: 317 Post(s)
Liked: 97
Might be better to buy a new Samsung TV that integrates out of the box.
post #8 of 10 Old 02-13-2020, 07:16 PM
bluewaves's Avatar
Quoted: 33 Post(s)
Liked: 34
You can get just a Harmony Hub that should interface with the Alexa and be able to control the TV
https://www.bestbuy.com/site/logitec...?skuId=1483019
bluewaves is offline
post #9 of 10 Old 02-14-2020, 07:36 AM - Thread Starter
mccoady's Avatar
Quoted: 13 Post(s)
Yeah I picked one up a couple of days ago but haven't had a change to install it.
mccoady is offline
post #10 of 10 Old 02-18-2020, 10:13 AM
NickTheGreat's Avatar
Quoted: 530 Post(s)
Liked: 404
I don't use it for much other than turning on or off, but the Harmony/Alexa route works well for me. Even my 4 year old can do it!
NickTheGreat is offline
Reply Home Automation
