How to use a trigger to start fan - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-07-2020, 07:24 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 8
I just purchased this fan for my AV receiver
https://www.amazon.com/dp/B009OWVUJ0..._rKIpEbZVSESZP
It plugs directly into an outlet for power. What would I need to connect this fan to my receiver via a trigger so the fan turns on when the receiver turns on. I'm not familiar with triggers or any components related to it at all...any cheap products out there that would do that for me?
Sent from my SM-G892A using Tapatalk
MisterCassera is offline
post #2 of 8 Old 02-09-2020, 01:35 PM - Thread Starter
Quoted: 42 Post(s)
Liked: 8
Anybody? Anything at all?
post #3 of 8 Old 02-10-2020, 08:02 AM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 344 Post(s)
Liked: 119
Since the fan is 110VAC and the trigger is 12VDC you will probably need a relay you can control with 12V that can switch 110V. Just perform a quick search for a 12V relay to control 110V. Many options to choose from for $10+.
kjfalls is offline
post #4 of 8 Old 02-10-2020, 08:04 AM
kjfalls's Avatar
Quoted: 344 Post(s)
Liked: 119
Another way is to plug it into the switched AC outlet on your receiver. It will power-up when the receiver is turned on.
kjfalls is offline
post #5 of 8 Old 02-10-2020, 11:28 AM - Thread Starter
Quoted: 42 Post(s)
Liked: 8
How would I connect the fan to something like this.
https://www.amazon.com/dp/B00MKWACVI..._06AqEbAFP4Y70
The fan only has an outlet to plug into a wall
post #6 of 8 Old 02-10-2020, 04:48 PM
kjfalls's Avatar
Quoted: 344 Post(s)
Liked: 119
The red and black are the input and you will need to put a 12V trigger plug end on to it. I think it’s a 1/8” plug with two sections. I can’t see the writing on the silver screws, but two are probably for the AC supply voltage and the other pair is for the load (fan). This is pretty heavy-duty for a fan. It can handle upto 250VAC and 30A.
kjfalls is offline
post #7 of 8 Old 02-11-2020, 01:24 PM
sbarnesvta's Avatar
Quoted: 28 Post(s)
It is a more expensive solution, but they have fan that have automatic temp sensors in them so they kick on when things get hot vs just when power is applied. They are surprisingly cheap and work very well. https://www.acinfinity.com/component...CABEgKCCvD_BwE
SBTS-Inc.com
- Certified Crestron Master Programmer and DM T-4K, D-4K, E-4K, DM-NVX Certifications.
- RTI Programmer/ Driver Developer
- Rational Acoustics Smaart Certified
- QSC QSYS Lvl 2 Certified Programmer
sbarnesvta is offline
post #8 of 8 Old 02-11-2020, 04:57 PM
Diesel~'s Avatar
I use something like this for a fan similar to yours.
Don’t have enough posts to post a link, but try adding a www+dot in front of amazon, below.
Smart Strip ECG-7MVR Energy Saving Surge Protector with Autoswitching Technology, 7 Outlet
amazon.com/dp/B0058DHO1W/ref=cm_sw_r_cp_tai_JW0qEbYN2H6KZ
Diesel~ is offline
Reply Home Automation
