Outdoor Alexa - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-10-2020, 02:08 PM - Thread Starter
Liked: 0
Outdoor Alexa
Im looking for an outdoor Alexa solution.
Not interested in music playback, speaker quality etc. as i have regular outdoor speakers Im looking for something I can have out by my pool so that I can use voice control from pool to operate music, Jandy pool effects etc.
Im not seeing any Alexa outdoor options anywhere
Any advice would be appreciated
Matt Buczek is offline
post #2 of 5 Old 02-11-2020, 01:27 PM
sbarnesvta's Avatar
Quoted: 28 Post(s)
They don't make anything weatherproof with Alexa built in that I have seen.
They are cheap enough I just mounted one to the underside of my patio cover and it works great, been out there a couple winter seasons and it is still going strong.
You could also mount on in a weatherproof nema enclosure and open the door when you want to use it, but that might be a hassle for as cheap as they are.
SBTS-Inc.com
- Certified Crestron Master Programmer and DM T-4K, D-4K, E-4K, DM-NVX Certifications.
- RTI Programmer/ Driver Developer
- Rational Acoustics Smaart Certified
- QSC QSYS Lvl 2 Certified Programmer
sbarnesvta is offline
post #3 of 5 Old 02-12-2020, 09:29 AM - Thread Starter
Liked: 0
Thanks. Theres nowhere really underside of anything to mount it. I looked at the Nema Enclosures and Like them but not sure if Alexa would hear me from inside
post #4 of 5 Old 02-13-2020, 06:14 PM
bluewaves's Avatar
Quoted: 35 Post(s)
Liked: 34
Just take an Echo Dot and wrap a zip lock bag around it.
bluewaves is offline
post #5 of 5 Old 02-17-2020, 09:29 AM - Thread Starter
Liked: 0
Was hoping for something more permanent
Reply Home Automation
