X10 update - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-19-2020, 02:35 PM - Thread Starter
Phillie14586's Avatar
X10 update
I have a light on the barn that I have connected to an X10 switch. In the house I have a remote and transceiver module. Then in the panel box I have a signal booster/phase bridge. It appears the booster/phase bridge has died. Those things run about $60. I was wondering if I need to spend that kind of money is there something newer out there. I checked and I do not have wifi in the barn.
Phillie14586 is offline
post #2 of 5 Old 02-19-2020, 05:25 PM
smoothtlk's Avatar
Quoted: 338 Post(s)
Liked: 107
No matter what you do, it will cost $60ish.
I would upgrade to Z-Wave. That will cost more for a Z-Wave controller and one or two switches.
Note that Z-Wave uses RF Mesh networking so each device repeats the signal to the next further device.
X10 though still working, is really dated technology. I still have a dozen devices but slowly replace them when they die.
smoothtlk is offline
post #3 of 5 Old 02-20-2020, 09:36 AM - Thread Starter
I just took a look at Z-wave and I am not sure it will work in my situation. The barn is about 100' from the house. The barn also has metal siding. What is the likelihood of an rf signal making it out of the house into a metal clad building 100' away?
post #4 of 5 Old 02-20-2020, 10:24 AM
FlyingDiver's Avatar
Quoted: 245 Post(s)
Liked: 71
For Z-wave? About zero.
FlyingDiver is offline
post #5 of 5 Old 02-20-2020, 08:07 PM
smoothtlk's Avatar
Quoted: 338 Post(s)
Liked: 107
You could look into UPB from SimplyAutomated. Uses powerline.
Reply Home Automation
