Remote activation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-26-2020, 07:11 AM - Thread Starter
Liked: 0
Remote activation
Hello,
I have a Sony HW65ES projector built into a lift. I want the projector power to turn on automatically when activating the lift. I have a domotica system that's programmable (Gira). In the manual I read that functionality via ethernet is only available when the unit is turned on. Is this correct? Would I need to use RS232? Please advice.
[email protected] is offline
post #2 of 2 Old 03-26-2020, 03:40 PM
smoothtlk's Avatar
Quoted: 338 Post(s)
Liked: 107
Most sony devices support power on via IP that we have integrated.
Do you have the ethernet control protocol? You will need that to code your integration. Within that doc you should see a powerOn.
smoothtlk is offline
Reply Home Automation
hw65es
