Official Samsung LNxxA630 Calibration/Settings Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 800 Old 08-13-2008, 11:22 PM - Thread Starter
trilidar's Avatar
This is about as close as I'm going to get it. I went back, scrapped everything and completely started over. Green and yellow are a little undersaturated, but it's marginal
Calibration: ColorHCFR 2.0.1 with an Eye-One Display LT on a Sony PlayStation3 over both HDMI and component.
Samsung A630 HDMI
Average gamma: 2.21
Mode: Movie
Backlight: 3
Contrast: 92
Brightness: 47
Sharpness: 2
Color: 41
Tint (G/R): G50/R50
Detailed Settings
Black Adjust: Off
Dynamic Contrast: Off
Gamma: 0
Color Space: Custom
Flesh Tone: 0
Edge Enhancement: Off
xvYCC: Off
Color Space
Red: R: 70 / G: 0 / B: 0
Green: R: 20 / G: 75 / B: 0
Blue: R: 13 / G: 0 / B: 70
Yellow: R: 58 / G: 58 / B: 0
Cyan: R: 28 / G: 55 / B: 55
Magenta: R: 66 / G: 0 / B: 75
White Balance
R-Offset: 24 / G-Offset: 25 / B-Offset: 23
R-Gain: 35 / G-Gain: 25 / B-Gain: 29
Picture Options
Color Tone: Warm2
Digital NR: Low
DNIe: Off (greyed out)
HDMI Black Level: Low
Film Mode: Off
Blue Only Mode: Off
Auto Motion Plus 120Hz: Low
Samsung A630 Component
Average gamma: 2.2
Mode: Movie
Backlight: 3
Contrast: 91
Brightness: 47
Sharpness: 5
Color: 44
Tint (G/R): G49/R51
Detailed Settings
Black Adjust: Off
Gamma: 0
Color Space: Custom
Flesh Tone: 0
xvYCC: Off
Color Space
Red: R: 60 / G: 0 / B: 0
Green: R: 20 / G: 62 / B: 0
Blue: R: 13 / G: 0 / B: 65
Yellow: R: 55 / G: 50 / B: 0
Cyan: R: 25 / G: 54 / B: 50
Magenta: R: 55 / G: 0 / B: 62
White Balance
R-Offset: 25 / G-Offset: 25 / B-Offset: 24
R-Gain: 35 / G-Gain: 25 / B-Gain: 30
Picture Options
Color Tone: Warm2
Digital NR: Low
HDMI Black Level: Low (greyed out)
Film Mode: Off
Blue Only Mode: Off
ColorHCFR.zip 9.8212890625k . file
trilidar is offline
post #2 of 800 Old 08-14-2008, 04:04 AM
MastaMind's Avatar
This set definitely has my attention. Just getting in on the action...and a friendly bump for a fellow Indy native.
MastaMind is offline
post #3 of 800 Old 08-31-2008, 01:01 PM
teamvernia's Avatar
Quoted: 56 Post(s)
Liked: 27
Thanks for the settings. Gonna try these out now. I'll post mine later as well. Though I used DVE and not a colorimeter. BTW, which size television did you calibrate? I have the 40 inch. And one more question. Any idea which settings would work best with an HD antenna signal?
teamvernia is offline
post #4 of 800 Old 08-31-2008, 08:32 PM
teamvernia's Avatar
Quoted: 56 Post(s)
Liked: 27
Well I just tried out the settings. Over HDMI, they look very crisp actually but some of the colors do seem pretty desaturated. I wonder if different size TVs in the series calibrate differently. The component settings look awful with my 360, though. That could certainly be the source, though. I actually used DVE to get my settings which I quite like. I wonder if your colorimeter would like my settings at all, or if they are TOTALLY off. It would be interesting to find out. Any, I'm running a PS3 through HDMI and used these settings.
Mode: Movie
Backlight: 3
Contrast: 95
Brightness: 44
Sharpness: 1
Color: 52
Tint (G/R): G50/R50
Detailed Settings
Black Adjust: Off
Gamma: 0
Color Space: Custom
Flesh Tone: 0
xvYCC: Off
Color Space
Red: R: 36 / G: 0 / B: 0
Green: R: 0 / G: 46 / B: 0
Blue: R: 0 / G: 0 / B: 39
Yellow: R: 48 / G: 52 / B: 0
Cyan: R: 0 / G: 44 / B: 42
Magenta: R: 38 / G: 0 / B: 41
White Balance
R-Offset: 25 / G-Offset: 25 / B-Offset: 25
R-Gain: 25 / G-Gain: 25 / B-Gain: 25
Picture Options
Color Tone: Warm 2
Digital NR: Off
Film Mode: Off
Blue Only Mode: Off
Auto Motion Plus 120Hz: Off
I used the DVE color filters to get the color space settings and could be totally off, but I think it looks good. The yellow just looks a tad green, and of course I don't have the equipment to calibrate the grayscale. These settings also hold over nicely for the antenna as well as the Xbox 360 through component, though I do have to turn the sharpness up to 3 over component, otherwise the image is blurry. I hope these settings help everyone. BTW this is for the LN40A630. I love the TV, but I just noticed my TV has a defect. Lines run through the image every once in a while. Anyone else having an issue with this?
post #5 of 800 Old 09-01-2008, 04:21 PM
thestinger's Avatar
Mode: Movie
Backlight: 3
Contrast: 95
Brightness: 44
Sharpness: 1
Color: 50
Tint (G/R): G50/R50
Detailed Settings
Black Adjust: Off
Gamma: 0
Color Space: Custom
Flesh Tone: 0
xvYCC: Off
Color Space
Blue: R: 0 / G: 0 / B: 38
White Balance
Picture Options
Color Tone: Warm 2
Digital NR: Off
Film Mode: Off
Blue Only Mode: Off
Thanks for the suggestion of the calibration. I have the 52 inch. I like your settings but feel the colors are a bit off.
I don't know what you mean by lines running through it. Could you post a video somewhere to show it maybe?
thestinger is offline
post #6 of 800 Old 09-01-2008, 08:33 PM
teamvernia's Avatar
Quoted: 56 Post(s)
Liked: 27
The tv started doing the line thing again. It's hard to decribe but it was very disconcerting, so I swapped it out for a new tv, same model, though. Anyway, I agree with the setting being slightly off. It's too saturated for network TV, but looks good for my PS3 and Xbox 360. I messed up on the previous post. Color should be 52 instead of 50, and blue in color space should be 39 instead of 38. That may make a bit of difference. I hope another person with experience calibrating can post another batch of settings. I'm mainly concerned about the color space, since I'm happy with my brightness, contrast, sharpness, and gamma settings.
post #7 of 800 Old 09-02-2008, 12:34 AM
mike171979's Avatar
Quoted: 43 Post(s)
Liked: 36
I am currently using the Cnet.com settings they get for the 650 panel, which should be basically the same panel as our 630, except ours doesn't have the super shiny clean panel.
--Picture menu
Mode: Movie
Backlight: 3
Contrast: 93
Brightness: 44
Sharpness: 0
Color: 52
Tint: G50/R50
Detailed settings submenu
Black adjust: Off
Dynamic contrast: Off
Gamma: +3
Color space: Auto
Flesh tone: 0
Edge enhancement: Off
xvYCC: Off
White balance submenu
R-Offset: 25
G-Offset: 26
B-Offset: 25
R-Gain: 24
G-Gain: 23
B-Gain: 14
Picture options submenu
Color tone: Warm2
Digital NR: Off
DNIe: [grayed out]
HDMI black level: [grayed out]
Film mode: [grayed out]
Blue only mode: Off
Auto motion plus 120Hz: Off
NOTE: On our 630 sets, HDMI Black Level and Film Mode are NOT GRAYED OUT, I have them set on Black Level: Low and Film Mode: Auto
mike171979 is offline
post #8 of 800 Old 09-02-2008, 12:53 PM - Thread Starter
trilidar's Avatar
Mine's a 46in.
Please recheck my original post (later today) for ColorHCFR files.
tril
trilidar is offline
post #9 of 800 Old 09-02-2008, 01:46 PM
teamvernia's Avatar
Quoted: 56 Post(s)
Liked: 27
Sounds good. BTW, is there a reason you are calibrating from standard rather than warm 1 or 2? Is the out of box grayscale closer from that setting? And can you please post which firmware you are using? It could explain why settings are different.
post #10 of 800 Old 09-02-2008, 02:48 PM
teamvernia's Avatar
Quoted: 56 Post(s)
Liked: 27
Well I think I settled on some settings I like. I tried out Zerog6's settings from the 750 calibration thread and tweaked the brightness/contrast/sharpness/gamma settings to my liking. His grayscale/color/tint/color space settings seem really nice actually, and I like them better than what I was able to achieve with DVE. The yellows look less green and the greens look less lime green. Here is what I'm using now.
(HDMI using PS3)
Mode: Movie
Backlight: 3
Contrast: 92
Brightness: 44
Sharpness: 1 (3 for Xbox 360 over Component)
Color: 50
Tint (G/R): G50/R50
Detailed Settings
Black Adjust: Off
Gamma: 0
Color Space: Custom
Flesh Tone: 0
xvYCC: Off
Color Space
Red: R: 30 / G: 0 / B: 1
Green: R: 26 / G: 46 / B: 0
Blue: R: 9 / G: 0 / B: 41
Yellow: R: 60 / G: 48 / B: 0
Cyan: R: 30 / G: 47 / B: 56
Magenta: R: 38 / G: 0 / B: 58
White Balance
R-Offset: 28 / G-Offset: 25 / B-Offset: 21
R-Gain: 25 / G-Gain: 25 / B-Gain: 29
Picture Options
Color Tone: Warm 1
Digital NR: Off
Film Mode: Off
Blue Only Mode: Off
Give these a try and see what you think.
post #11 of 800 Old 09-02-2008, 07:52 PM - Thread Starter
trilidar's Avatar
As promised, check my original post for ColorHCFR file.
Overall, I'm really happy with these settings. Grey scale and color are almost perfect, D65 and luminance values are almost spot on across the entire IRE scale and gamma doesn't fluctuate wildly.
The CIE 'triangle' is as good as I can get it (without sacrificing luminance delta E in the colors). If someone knows how to get it any better, I'm all ears.
tril
**Please disregard my original ColorHCFR file (it was before I completely re-did everything)**
trilidar is offline
post #12 of 800 Old 09-02-2008, 08:39 PM
EMahn's Avatar
I'm not entirely certain this is the right thread to post this in, but it is a question about settings on a LN52A630. I recently upgraded my TV. I am going through various basic settings, but one has me stumped. On my previous set, there was an aspect ratio setting that would display 4:3 (SD) content and stretch it to fill the whole screen (eliminating side bars), but did it in such a manner as to mostly avoid distorting the image and minimized cropping of the image (it stretched less in the middle and more at the sides where you don't notice it as much).
On the LN52A630, under the Picture > Picture Options > Size menu, the choices are (and what the effect is on 4:3 SD content):
16:9 (Picture is distorted - "fat faces")
Zoom1: (Zooms in and cuts off part of the image)
Zoom2: (Zooms in and cuts off more of the image)
Wide fit: (Option unavailable when viewing SD)
4:3: (Displays the image without distortion or cropping, but there are bars on the sides)
Just Scan: (Option unavailable when viewing SD)
So far I am unable to reproduce a similar aspect ratio setting that I had on my old set. Is there something that will achieve what I am looking for or do I need to settle for bars on the sides?
Thanks for any assistance.
-E
EMahn is offline
post #13 of 800 Old 09-03-2008, 04:54 PM
Apophis906's Avatar
Well these are the settings I found to work well enough right now for watching HD and SD tv with my cable box.
(HDMI using SA 8300HD)
Mode: Standard
Backlight: 5
Contrast: 98
Brightness: 46
Sharpness: 3
Color: 52
Tint (G/R): G50/R50
Detailed Settings
Black Adjust: Off
Gamma: +3
Color Space: Custom
Flesh Tone: 0
xvYCC: Off
Color Space
Red: R: 40 / G: 0 / B: 0
Green: R: 0 / G: 50 / B: 0
Blue: R: 0 / G: 0 / B: 41
Yellow: R: 48 / G: 57 / B: 0
Cyan: R: 0 / G: 46 / B: 48
Magenta: R: 41 / G: 0 / B: 46
White Balance
R-Offset: 26 / G-Offset: 25 / B-Offset: 25
R-Gain: 16 / G-Gain: 25 / B-Gain: 21
Picture Options
Color Tone: Normal
Digital NR: Off
DNIe: Off
Film Mode: Off
Blue Only Mode: Off
Mongol General:"What is best in life?"
Conan:"To crush your enemies, to see them driven before you, and to hear the lamentations of their women."
Apophis906 is offline
post #14 of 800 Old 09-12-2008, 04:29 PM
syndicatedragon's Avatar
Which settings to use using the TV's internal ATSC tuner??
syndicatedragon is offline
post #15 of 800 Old 09-17-2008, 06:32 AM
techsharp's Avatar
I am going to try the settings posted by Trilidar today. One question - how come use the movie mode instead of standard? It looks like movie mode dims the screen more.
Looking forward to trying these out and thanks for posting them.
techsharp is offline
post #16 of 800 Old 09-17-2008, 09:47 AM
Stereodude's Avatar
Quoted: 4229 Post(s)
Liked: 2988
It doesn't have to. You can adjust it to be just as bright as the other modes. It's probably used because it lets you into warm1 and warm2.
Stereodude is offline
post #17 of 800 Old 09-17-2008, 09:49 AM
Stereodude's Avatar
Liked: 2988
One nice thing I noticed with the set is that the brightness and contrast controls really just set the black point and white point of the set. I wish more TVs were like that.
post #18 of 800 Old 09-18-2008, 08:19 AM
techsharp's Avatar
Well if you use the movie mode setting and the settings above, what would you change to make it brighter?
I tried the settings and it was almost like it was dark, I understand you use movie mode to get into the warm1 and warm2 settings, but once it is all set what do you change to make it brighter? If you change the contrast or brightness then you will not be using the settings above - so I am a little confused.
Also I use both HDMI and component - is there a way to save settings for both so you can change back and forth easy?
post #19 of 800 Old 09-18-2008, 11:32 AM
Stereodude's Avatar
Liked: 2988
You could turn up the backlight and turn dynamic contrast back on.
It seems to save settings based on input and resolution. So for example, you can have different settings for the internal tuner for 480i analog vs. 1080i digital HDTV.
post #20 of 800 Old 09-18-2008, 01:24 PM
techsharp's Avatar
OK great - I will give this a shot tonight - will let you know if I have any more ?'s.
post #21 of 800 Old 09-19-2008, 03:59 AM
techsharp's Avatar
I tried both those things, but for some reason it still did not look right. I will have to mess around w/ the settings more I guess.
post #22 of 800 Old 09-24-2008, 01:37 PM
JMannBR's Avatar
Hey guys,
I have just bought my first LCD HDTV and its the Samsung 630 46". I am pretty clueless at this point on how everything works. I have gotten my PS3 running through in HDMI and my HD Cable is currently running in component but I am switching my cable box this coming weekend to HDMI compatible. Does this mean I dont have to use any of these HDMI COMPONENT settings that have been posted here? Also, can someone please explain to me what the ColorHCFR.zip is? What do I do with it?
Can I use the same settings for everything if its all running through HDMI? Like the same settings for Playstation games, bluray and TV will all work under the same settings?
One last question for you guys, I read in some forums that you shouldnt mess with the settings for at least a week until a break-in period has passed otherwise it could shorten the TVs lifespam, is that true?
Thanks a lot in advance to whoever can answer this questions for me!
JMannBR is offline
post #23 of 800 Old 09-24-2008, 02:31 PM
jwc13ac's Avatar
Originally Posted by JMannBR View Post
Hey guys,
I wouldn't worry about a break in period, especially with an LCD.
As for the other questions, I'm not sure, but try all the settings and see what looks best.
_______
~ Joe
jwc13ac is offline
post #24 of 800 Old 09-26-2008, 09:06 AM
jmad's Avatar
Can't seem to open the zip file from the original post. Is this needed to complete the calibration?
Thanks!!
jmad is offline
post #25 of 800 Old 09-30-2008, 06:00 PM - Thread Starter
trilidar's Avatar
Bingo.
Generally, Warm1/2 gets you closer to D65 out-of-the-box. However, you don't have to start there. If the color controls are good enough (and the A630's are), you could start at Normal and still get very accurate results.
tril
trilidar is offline
post #26 of 800 Old 09-30-2008, 06:01 PM - Thread Starter
trilidar's Avatar
Thanks!!
No it is not.
The file is only useful if you'd like to load it up in ColorHCFR and 'check' my results. Otherwise: not necessary.
tril
trilidar is offline
post #27 of 800 Old 10-02-2008, 12:00 PM
teamvernia's Avatar
Quoted: 56 Post(s)
Liked: 27
Well I tried these settings again after resetting my TV and voila!!! they look great now. Apparently there is some type of bug that changes the default white space settings. Thanks a lot for these awesome settings.
post #28 of 800 Old 10-02-2008, 08:36 PM
teamvernia's Avatar
Quoted: 56 Post(s)
Liked: 27
One things though. My color filter shows that green and yellow are over saturated. I wonder if the AVE color filter is wrong. It also shows that a Sharp LCD is pusing green as well.
post #29 of 800 Old 10-03-2008, 12:22 PM
jmad's Avatar
Originally Posted by trilidar View Post
No it is not.
tril
Thanks for the reply. Think you hit it on the head with these settings- look great!
jmad is offline
post #30 of 800 Old 10-05-2008, 06:58 AM
applenut's Avatar
Any recommendations for OTA?
applenut is offline
Reply LCD Flat Panel Displays
