Firmware Hack And Firmware updates LG LH/LF Series - Page 15 - AVS Forum | Home Theater Discussions And Reviews
post #421 of 720 Old 07-06-2010, 06:03 AM
pbc
pbc's Avatar
Quoted: 437 Post(s)
Liked: 217
RCA universal remote :
RCA RCR3273N RCR3283N RCR412SN RCR412BN RCR4383N RCR4258N RCR4358N RCR4373N RCR4383N RCR461 RCR612N RCR473N RCR812N RCR815N
code to program : 11265
Press the GUIDE button
Has anyone tried the above remotes on a newer LD450 (or 350/550) series? I purchased an RCA 6473N (none of the above remotes were available but this remote ist he exact same as the 4373N except it controls 6 devices vs 4) and the Guide button did nothing (didn't even light up IIRC).
My DIY Subs ... https://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #422 of 720 Old 07-09-2010, 09:04 AM
felixarmando's Avatar
Originally Posted by Georgie3 View Post
There is another service menu. Press Enter-Enter on TV and remote. Same password (0000). The keys might be called Ok instead of Enter on your set (on the remote it's the round button in the middle of the arrow keys). Tool option 3 is in there on my set, 42LH40.
Be careful in there! Change only the DivX setting or you may kill your set. I've also changed the Tuner Option setting safely to improve my broadcast reception. Settings take effect (almost) immediately upon change, no need to press any kind of enter key, so even cycling through parameters to see what's available can be very risky.
G
Hi I have TV 47LH30 and sometimes reboot the TV playing ts files , What I can do?
felixarmando is offline
post #423 of 720 Old 07-10-2010, 02:34 PM
Georgie3's Avatar
Yes, this happens on my 42LH40. It's worst for movie files (avi/mkv) with MPEG4 encoding, but still happens occasionally for .ts MPEG2 files. I think it is affected by the number of different on-screen menus which are shown before/during/after playing a movie. The basic idea to prevent reboots is to minimize the number of menus you use before and while playing movies. Here's what I do for most reliable playback:
- Before playing a movie power cycle the TV (turn it off and on again), then go straight into the USB menu.
- Navigate to your movie and start playing
- While playing avoid the FF/REW buttons and anything that pops up a menu (for example Energy Saver).
- To navigate around the movie use forward/back cursor to jump a few minutes in either direction, this seems to cause fewer reboots than FF/REW.
- After playing a movie power cycle the TV again before doing other things like watching TV channels or another movie. Especially if the menus are starting to look corrupted, your TV will probably reboot soon by itself anyway.
When I follow these instructions my TV never reboots during .ts (MPEG2) movies, even 1920 x 1080 HD, and playback smoothness and PQ are at their best.
Good luck,
G
Georgie3 is offline
post #424 of 720 Old 07-12-2010, 01:46 PM
napalmique's Avatar
Anyone knows of any compatibility issues between LG 32LF2500 and Toshiba Stor.E Art 500 GB HDD ?
I own this unlucky pair
The marriage started well, the TV was able to read from the HDD, but at some point it just refused, it doesn't even try to access it when they connect via USB, nothing shows up on the screen.
The HDD works JUST FINE when connected to my pc or laptop or digital cable receiver.
I have been formatting and repartitioned the drive several times and in several ways and combination, but no luck. I even tried a different USB cable.
The HDD has its own power source.
I had a somehow similar issue with a 8GB Corsair Voyager flash drive, when I was connecting it to the USB port, the TV would try to read it but give up and let me know it failed. But that got fixed after reformatting the stick using HP flash drive formatting tool.
napalmique is offline
post #425 of 720 Old 07-13-2010, 12:30 AM - Thread Starter
Devil-Strike's Avatar
Originally Posted by Anilo View Post
Can i activate Bluetooth on 32LH3000? I asking because i found this where is 32LH3000 with bluetooth,USB so it look like sucesfully hacked.
VVV.cheap-lcd-tv.co.uk/32_LG_32LH3000_XD_Engine_Full_HD_1080p_Digital_Freeview_LCD_ TV_364_d
CHANGE VVV TO WWW
You can enable Bluetooth, but is not working because there is no BT module in it.
Devil-Strike is offline
post #426 of 720 Old 07-14-2010, 05:33 AM
humaxboy's Avatar
Originally Posted by sanmi69 View Post
it works on 22LD320
@sanmi69 -> which firmware was original, how did you come into servis menu ?
Do you use the latest 3.65 firmware ?
humaxboy is offline
post #427 of 720 Old 07-14-2010, 02:36 PM
khan4youuk's Avatar
hi guys, new to this forum. can you please guide me. i have lg 42lf7700 and URC7544. is it possible to activate usb with this remote. at the moment the remote is working with the tv i.e programme, vol, menu.
khan4youuk is offline
post #428 of 720 Old 07-15-2010, 12:52 PM
DocPanic's Avatar
hey guys...
got a question
user in german lg-board did downgrade from 3.40 to 3.15 with his 37LH3800, freed the usb and made upgrade to 3.55. upgrade went to 100%.
then tv turned off and is refusing to start again...
neither remote nor tv-buttons working.
just red led.
any help or bricked tv?
DocPanic is offline
post #429 of 720 Old 07-16-2010, 01:57 AM
faberga's Avatar
Hi, I can't help you.
But I did these step on my 37LH3000:
3.63->3.15-> hack->3.55->3.65-> OK!!
I had 3.63 firmware version. I downgrade to 3.15, hacked and than upgraded to 3.55 (because I read I could have problem to upgrade from 3.15 to 3.63).
Than I found the 3.65 on LG Spanish website and I upgraded from 3.55 to 3.65.
Everything is working perfectly!!
faberga is offline
post #430 of 720 Old 07-16-2010, 05:31 AM
Georgie3's Avatar
Originally Posted by DocPanic View Post
hey guys...
got a question
just red led.
You may be able to recover the TV using the serial port and instructions quoted in this post:
https://www.avsforum.com/avs-vb/showt...4#post18500964
Also read the followup posts by Parkdean & me to see how the problem was fixed. Try loading 3.40 or 3.15 to recover, not 3.55 since that caused problems.
G
Georgie3 is offline
post #431 of 720 Old 07-16-2010, 08:28 AM
DocPanic's Avatar
thx georgie... i will give it to the user (sounds dirty, but i hope you understand... i´m not so experienced in english...)
again: thx
DocPanic is offline
post #432 of 720 Old 07-16-2010, 12:41 PM
DocPanic's Avatar
okay, worked.
thx alot.
german translation already posted for other users...
DocPanic is offline
post #433 of 720 Old 07-17-2010, 04:30 AM - Thread Starter
okay, worked.
thx alot.
for the the people that don't read the first post, go do it. dont flash firmware if the tv is not listed.
post #434 of 720 Old 07-21-2010, 02:07 AM
Andrei Pavel's Avatar
I have a LG LH5000.
Everything works fine from the usb (I converted my DTS encoded mkv files to AAC and the audio is working now aswell), except from the fact that I cannot use my CUSTOM av mode settings. This is really frustrating because the factory av mode settings are really not to my liking and I can't even turn the 100hz processing off, which makes movies look like talk shows. Is there a fix for this issue?
Thank you in advance,
Andrei Pavel.
Andrei Pavel is offline
post #435 of 720 Old 07-22-2010, 10:16 AM
hajj_3's Avatar
Hi guys i have the UK model of the LG 26LH2000 and it has the v3.46 firmware on it. I have not seen v3.46 listed anywhere on this thread, can i downgrade it and upgrade it to v3.65? If it was bricked could i unbrick it? I have a pc with a serial port and a null modem cable. Would i need to do any soldering?
thanks.
hajj_3 is offline
post #436 of 720 Old 07-23-2010, 03:05 AM - Thread Starter
New firmware found V3.66 wil upload it asap, but i test is first on my lf2500 model.
European LH/LF and some LU models only.
http://members.chello.nl/devilstrike/LG_DTV_v3.66.zip Mirror: http://devil-strike.square7.ch/LG_Fi..._DTV_v3.66.zip
Changelog:
- When some specific JPEG photo is dispayed via USB , TV cannot display normal image due to NR(noise reduction)'s function error.
post #437 of 720 Old 07-23-2010, 03:55 AM
hajj_3's Avatar
which countries will the 3.66 firmware work on, my tv is a 26LH2000 UK PAL tv.
hajj_3 is offline
post #438 of 720 Old 07-23-2010, 05:10 AM - Thread Starter
European models only, so yes uk models also.
post #439 of 720 Old 07-26-2010, 02:42 AM
Maximusro's Avatar
Changelog:
Devil-Strike,
Great great work, thank you very much! I have 32LH5000.
Can you please tell me where did you find the changelog? I am sure everybody will install this upgrade with hope in there hearts that it will sort a lot of other issues, not just the single one above...
Maximusro is offline
post #440 of 720 Old 07-26-2010, 08:11 AM
VANTWP's Avatar
v3.66 work ok with my LG 47LH3000.
FW for LG LH-3/4/5000 EU series
v3.75
v3.67
v3.15
VANTWP is offline
post #441 of 720 Old 07-26-2010, 01:49 PM
bodhi100's Avatar
Hi, first post here so hope it makes sense...
I just got my T.V on Saturday, (offered as an alternative at Argos) :-)
I have read elsewhere that the Tesco (Technika) remote can allow the MKV option? I have tried what they said but not getting the service menu.
The remote is the TR41R 4-in-1, I press the 'setup' button, then 'TV'' then type in 0119, power off, power on and hold 'setup' and '-/--' button together. This doesn't do anything for me, has anyone else tried it or offer any advice? Thank you
bodhi100 is offline
post #442 of 720 Old 07-27-2010, 04:22 AM - Thread Starter
Originally Posted by Maximusro View Post
Devil-Strike,
Changelog whas already in zip file whene i found it.
post #443 of 720 Old 08-17-2010, 02:47 AM
cyborgdk's Avatar
Hi..
I just bought a LG 22LU5000, it had FW 3.55 from 'birth'.
I did the downgrade to 3.15 did the menu hack to get USB, upgraded back to to 3.55 via FW downloaded.
The 'issue' is that now I get pixel errors on some Digital DVBC channels , not on all but on some.. I did not have this problem with the 'original/virgin' FW.. Can there be differences even though the version I patched with has the same version no? (3.55)..
I tried upgrading to the latest 3.66 but with the same result..
I was considdering doing the revert to factory fw, but when i do the remote sequence i get the upgrade page, here it states that I am now on FW 3.66 and I am upgrading to FW 0.00.00 hmmm that does not sound right does it?
ps. I live in Denmark (dont know if there can be 'national' versions of firmware?)..
Other than that excellent hack :-) Strange that they did not leave this feature in the shelf product?
cyborgdk is offline
post #444 of 720 Old 08-18-2010, 11:08 AM - Thread Starter
If you have pixels or blocking check your coaxial cable, this can happen if lg did some changed to signal.
post #445 of 720 Old 08-18-2010, 11:55 AM
toby_as's Avatar
Hi
I have an 37LF2500. I did the the usb hack, thanks to this forum.
Now i upgraded to he 3.66 firmware, and i can not acces the ez-adjust menu "Wrong password" (i entered 0000 but no succes).
They changed the password?
Can someone tell me the new pass?
toby_as is offline
post #446 of 720 Old 08-23-2010, 05:35 AM
sunsse's Avatar
I just wrote to LG asking for the newest firmware for my LG 42LH5000 and got this. Vers. 3.67
http://rs806.rapidshare.com/files/40...re_Upgrade.zip
Description says this:
Firmware upgrade for below models:
HD(50Hz): 32/37/42 LG2100
37/42 LH2000/10
FHD (50Hz): 37/42 LF2500/10
37/42/47 LH3000/10
37/42 LH3800
32 LH4000/10/20
FHD (LED 100Hz) : 42/47 LH9000
FHD (100Hz): 37/42/47 LH4000/10/20
32LH5000
FHD (200Hz): 32/37/42/47 LH4900
37/42/47/55 LH5000/10/20
42/47/55LH9000
FHD (LED 100Hz) : 42/47LH9000
sunsse is offline
post #447 of 720 Old 08-23-2010, 11:59 PM - Thread Starter
37/42 LH2000/10
37/42/47 LH3000/10
37/42 LH3800
32 LH4000/10/20
32LH5000
42/47/55LH9000
Thnx i update startpost, but wil first test on lf and lh models.
Changelog from 3.66 to 3.67
Updating Nand Flash of GP EU All model as running change YES
1. Under Russia specific CAM envirnment , when channel change ,TV state goes to NO-SIGNAL
2. Add Slovenia certification LOGO in E-streamer
3. When input change to USB photo , NR did not change with previous NR data
4. Passwd changed from 0000 to 0413 entering to service menu
5. Under USB photo data envirnment , some JPEG pattern did not printed. ? RSVOC
6. Under NVM uninitialized envirnment(only first power on) , during AC power on TV set getting LatchUP and reset. But after reset , it?s OK.
v3.67: http://members.chello.nl/devilstrike/LG_DTV_v3.67.zip Mirror http://devil-strike.square7.ch/LG_Fi..._DTV_v3.67.zip
post #448 of 720 Old 08-24-2010, 01:44 AM - Thread Starter
I have updated the startpost with new download link for v3.67 and also updated all the changelogs.
Again thanks sunsse for this firmware with history change list.
post #449 of 720 Old 08-24-2010, 11:32 PM
VANTWP's Avatar
v3.67 works fine with my 47LH3000 ZA
v3.75
v3.67
v3.15
VANTWP is offline
post #450 of 720 Old 08-29-2010, 11:39 AM
wakaru's Avatar
Perhaps you neither have a S60v3 Nokia Smartphone nor a Windows Mobile 5/6 device with IR port but, like me, you do have a PSP-1000 model.
There is a homebrew application for the PSP-1000 models that allows it to be used as a Universal Remote controller to reproduce the IR Hack.
The only requirements are:
-A PSP-1000 model on Custom Firmware (AKA unlocked). Newer PSP models will NOT work as they lack in the IR port. If your PSP-1000 is not unlocked, google "pandora battery" as this is a relatively simple process to do.
-The application Universal Remote v1.2. Remember this is a 1.5 Firmware application, therefore it needs installing into PSP/GAME150 in order to make work in Custom Firmware.
[http : // dl.qj.net/psp/homebrew-applications/psp-universal-remote-12.html]
-The winlirc compiled dump from the LG 105-201M service remote controller that includes the infrared impulses to open the EZ Adjust / IN-Start menu. [http : // w w w .pastebin.com/f4e0323b7]
For those interested I have prepared a ready-made pack with all that you need that can be downloaded from http : //www.multiupload.com/KH8VCSQODE
Just uncompress it into the memory card and execute it from the GAME menu of the PSP. Once loaded, press SELECT followed by SQUARE. This should load a profile that has every PSP button (D-PAD and Square, Triangle, Cross and Circle) already assigned to the EZ adjust command.
Press any of them while pointing the PSP to the LG TV and you should see the box to enter the password that will grant you access to the Service Mode.
Any questions just ask
wakaru is offline
Reply LCD Flat Panel Displays
Lg 47lh90 , Lg 55lh40 55 Inch Lcd Hdtv , Lg 42 Lh40 42 Inch Lcd Hdtv , Lg 47lh40 47 Inch 1080p 120 Hz Lcd Hdtv Gloss Black , Lg 42lh50 42 Inch 1080p 120 Hz Broadband Lcd Hdtv Gloss Black , Lg 32lh30 32 Inch 1080p Lcd Hdtv Gloss Black , Lg 32lh20 32 Inch 720p Lcd Hdtv Gloss Black
