OFFICIAL Samsung 4k HU8550 and HU9000 thread - Page 666 - AVS Forum | Home Theater Discussions And Reviews
 4752Likes
post #19951 of 22221 Old 07-21-2015, 08:21 PM
Quoted: 23 Post(s)
Liked: 6
The update was about 5 minutes. It completed but tv didn't power off then on after completing update. Is that normal ?
NUGUY is offline
post #19952 of 22221 Old 07-21-2015, 08:29 PM
Mnat0712's Avatar
Quoted: 220 Post(s)
Liked: 80
After my update it did reset but i still unplugged it for 10m
Hu8700 owner
Mnat0712 is offline
post #19953 of 22221 Old 07-21-2015, 09:03 PM
jacko15's Avatar
Quoted: 153 Post(s)
Liked: 145
My golf chip 60hu8550 is still on version 2240. I have auto update turned off. It never prompted me to update to 2250, although the update did show in the menu. Version 2260 has been available on the Samsung website for almost a week now, but only showed up on my update menu today. Tonight, while viewing shows on my DVR, the tv screen has prompted me twice to do the 2260 update. I've read here that some weren't real happy with the 2250 update, so I avoided it. Now the tv keeps bugging me to update to 2260. Does any know what improvements, and, or, unwanted "upgrades" come with version 2260? I've read some advertising came with 2250. I don't consider that an improvement for anyone except Samsung.
pilotart likes this.
jacko15 is offline
post #19954 of 22221 Old 07-21-2015, 09:15 PM
DemonFlame5's Avatar
Originally Posted by Hazama View Post
Ahhh yes. Welcome. As odd as this may sound, unplug your tv for a minute and then plug it back in.
I tried it. It didn't work. Waited until the red light was gone but nothing.
Originally Posted by pilotart View Post
Dimensional Optics also has a lower cost version without the case and side shades.
This can often fix 'issues' and after you 'un-plug' from power (or turn off your Surge Protection strip), Work that five-way Switch located on rear (Flush mounted lower 'stage-right' side) until the Red LED no longer Flashes. This helps remove the 'residual' electric charge in some of the components and help TV 'forget' what it was doing wrong.
This has often been reported successful and should most certainly be tried before the trouble of a 'Re-Set'.
As I wrote in my post above, I have not had to do a 'Power-Down' fix since turning off the "Samsung Instant On" (Menu>System>General) last November. Seems like turning your computer completely off once in a while, compared to putting it 'to sleep'.
Art
What is a Re-Set?
DemonFlame5 is offline
post #19955 of 22221 Old 07-21-2015, 09:58 PM
p5browne's Avatar
Quoted: 3991 Post(s)
Liked: 3166
FW updates are a hit and miss re Off/On. 99% turn Off. 95% don't turn back On.
Surprises the heck out of me when I get that odd turn back On!
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #19956 of 22221 Old 07-22-2015, 02:27 AM
pilotart's Avatar
Quoted: 651 Post(s)
Liked: 502
I'm still on Golf 2221 with "Auto Update" off, 2240 is there if I "Check for Updates", but my system is completely working perfectly. Thought it was 2240 that changed the 'Smart Hub' screen.
With a New Product, many Firmware ("software") Updates are really needed to remove genuine 'Bugs', but after that has been done, Updates can add features (or capabilities, like adding SEK3500) that you may or MAY NOT want. A good rule (often quoted by Samsung Support) is never 'Update' unless You Want or Have a Need to do it. There is always risk (or unwanted changes) to be concerned with.
It's never showed a 'Nag Screen' to update, hope it doesn't.
Just got a New ChannelMaster DVR+ (and Love it!) that was a lot of work in my Router to Block its Nag Screens for updating. It came loaded w/115R (a 'secret' Firmware) and I like it and won't Flash it until I want to.
Reset's (had to do two of them, but being new), were no big deal. Reset takes DVR+ back to original Firmware and there is also a 'trick' to get it to USB Flash back to an earlier Firmware. I got the preferred 16 GB version, allowing good use for some of my Samsung UHD-Packs
No way to go back on Samsung TV's Firmware (software updates), absolutely only forward for them
I did set the 8550's IP Address to block FTP's, but don't have a specific URL to block connections to their download site like I did for the DVR+. DVR+'s Other connections (like TV Guide and Streaming are still allowed), but it does not even know an update is available now.
What is a Re-Set?
After removing your power it speeds its discharge to 'work' that little five-way switch on back-side of set until red LED quits blinking. Or just wait a lot longer to give its power back, TV's store lots of electrons after power is removed.
Reset is found in Menu>Support>'Self Help' (my TV's not on yet) and then at bottom of list you will see "Reset". This will restore your TV back to Factory Defaults, losing all settings you have selected Good news is that it will keep your WiFi log on intact.
A 'Smart Hub' reset means you will need to re-enter any Log-In for your Amazon, You-Tube, Netflix, etc. and would expect that to be the same after a complete reset.
It's a lot of work if you have had the TV for a while and adjusted everything the way you wanted it, to start that all over again. First thing I would re-set is "Auto Update" Off (default is On). My only reset was from entering Service Menu and reset is automatic when you leave, since there had been an Update I was holding back from, it immediately Updated and you would Never want to try and stop that process. It turned out fine.
There is also a "Reset" Command within Service Menu and Samsung can Remotely reset it as well, while you are on Service Telephone Support. I don't know if those resets are any different than the one in your Support menu.
Mine has always 'rebooted' after updates and never failed to come back on. Firmware Flashes have always seemed to be quite quickly done. I assume it's because the file was already downloaded and primed to go. If it had to wait for a 1.7 GB Download, that would take a while.
It used to be recommended (mid 2014) to do a reset following an update. I would only do it for suspected problems that a Cold start didn't fix. But I would leave it 'Cold' overnight first
Art
Last edited by pilotart; 07-22-2015 at 02:44 AM. Reason: add thought: "unwanted..."
pilotart is offline
post #19957 of 22221 Old 07-22-2015, 06:25 AM
jacko15's Avatar
Quoted: 153 Post(s)
Liked: 145
It seems Samsung has started pushing the "nag screens" to my set even though I haven't updated the firmware in quite a while. They really want me to move to 2260. My set is working fine, and the pq is great, so I figure it's for their advantage. I only do a limited amount of streaming, but I do like using the web interface when watching sports. If it continues, I'll close the network connection. The nag screens are stupid! I've registered online, they could just send me an email.
jacko15 is offline
post #19958 of 22221 Old 07-22-2015, 07:06 AM
pilotart's Avatar
Quoted: 651 Post(s)
Liked: 502
@jacko15
They've got advertisers to please with "Numbers".
Hard to imagine what they would put in an email as a 'reason' to Flash with an update.
You might try setting your Router for no FTP's to TV's IP Address. That's what I did, don't know if it will help, but you wouldn't miss any 'streaming' with it.
I will report if I get any "Nag Screens".
Art
pilotart is offline
post #19959 of 22221 Old 07-22-2015, 07:11 AM
jacko15's Avatar
Quoted: 153 Post(s)
Liked: 145
Thanks Art. I wonder if anyone else is getting the "nag screens".
jacko15 is offline
post #19960 of 22221 Old 07-22-2015, 07:17 AM
CUTiger78's Avatar
Quoted: 26 Post(s)
Originally Posted by player002 View Post
65 is panel lottery. stay away from QS04 rest are fine..
Sorry to hear that. I've had a UN65HU8550 QS04 for 2 months now and I'm real happy with it. I guess I just don't know what I'm missing.
CUTiger78 is offline
post #19961 of 22221 Old 07-22-2015, 12:09 PM
chekhonte's Avatar
Quoted: 145 Post(s)
Liked: 55
Hi guys. This morning I turned on my TV and got no image coming from my computer.
I Tried some HDMI ports and only 3 seems to be able to display my PC.
I can only get my pc to display on hdmi 3
I tried my ps3 and it won't work on any of the ports.
I tried my ps4 and it will work on all ports.
I also tried a bunch of HDMI cables and get the same results.
Have any of you encountered this on a un65hu8550 tv?
I contact samsung and sent in a service request and hopefully they'll be able to fix it but if for some reason they can't I'm hoping that the one connect box will give me some options.
Has there been any word on if and when the oneconnect will come out for this model?
chekhonte is offline
post #19962 of 22221 Old 07-22-2015, 12:56 PM
PJL99's Avatar
Quoted: 513 Post(s)
Liked: 338
What troubleshooting have you tried? Have you reset the TV?
The SEK-3500U has been out for several months and there is a dedicated thread for it: https://www.avsforum.com/forum/166-lc...ution-kit.html . I have it connected to my UN65HU8550FXZA. It has significantly improved the TV.
PJL99 is offline
post #19963 of 22221 Old 07-22-2015, 01:50 PM
Quoted: 182 Post(s)
Liked: 37
So I installed update 2160 on my 8700 and I am able to finally turn amp back up to 10/10 without the studder! Yay crossing my fingers hoping it's a permanent fix.
robjwilkins is offline
post #19964 of 22221 Old 07-22-2015, 02:06 PM
chekhonte's Avatar
Quoted: 145 Post(s)
Liked: 55
Yeah, I tried to do a reset and the problem persisted unfortunately.
I tried connecting all 4 of my devices to different ports and hdmi 3 seems to be the only one that will work with all of them. The ps4 will work on hdmi 1 and 3 but nothing else will work. It's odd. Every now and then I'd get a no display message saying that this resolution is not supported with my computer outputting a 4k signal but unplugging the hdmi and plugging it back in would fix it.
It's really strange.
Thanks for the info on the oneconnect. I'll be sure to really check it out.
post #19965 of 22221 Old 07-22-2015, 02:11 PM
Hamlet00's Avatar
Quoted: 47 Post(s)
75-inch dilemma in the Summer of 2015
I always like to buy latest tech, and I never thought that I would be buy a year old TV, but it looks like Samsung is leaving me with no choice. I want a 75 inch and I do not want a curved screen for various reasons (gimmick, overpriced, need to sit in sweet spot, etc).
Sammy did not produce the JS8500 in 75 inch size or that would probably be the no-brain choice for me. The flagship is curved and way overpriced while the lower tiered model (JU6500) looks less compelling than last year's HU8500 (especially if paired with one-connect). For one thing, I don't like the look or build quality of the bezel and stand compared to the HU8500.
My conclusion is that buying last year's HU8500 for the current price of about $3k (and possibly adding a one-connect) is the best choice at this time given my wants and preferences. Unfortunately, I have not seen the JS models in stores yet so I cannot know how noticeable the difference in picture quality with it's upgraded panel technology (Nano-crystal Color) that I would be missing.
Curious to hear other thoughts.
Ted99 likes this.
Hamlet00 is offline
post #19966 of 22221 Old 07-22-2015, 04:46 PM
chekhonte's Avatar
Quoted: 145 Post(s)
Liked: 55
I saw it a while ago and the biggest difference to the casual eye was much better view angles. The older model isn't horrible but if I got a a few feed from the edge the edge closest to me would start to wash out pretty noticeably. I Have a flat screen from the same year and it has the same problem but since it isn't curved it has better viewing angles. If that sounds like it would bug you then I wouldn't get, that's a huge tv to set up and return. My 65 inch is 100lb with the base screwed in. I could barely set it up by myself.
To the naked eye the viewing angles was the only difference I could make out. The picture quality is solid on both when viewed straight on. I can't comment if the newer model has the problem of uneven light splotches when you crank the brightness up like on my model. I've never needed the brightness that high so it hasn't been a problem for me as setting the backlight brighter doesn't cause the same effect.
post #19967 of 22221 Old 07-22-2015, 04:57 PM
p5browne's Avatar
Liked: 3166
Hurry up and finish the Page!! In case no one noticed it, but this is Page `` 666 `` !!!
UN65KS9800 - Mine
p5browne is offline
post #19968 of 22221 Old 07-22-2015, 04:59 PM
ray0414's Avatar
Quoted: 12479 Post(s)
Liked: 11667
Originally Posted by hamlet00 View Post
i always like to buy latest tech, and i never thought that i would be buy a year old tv, but it looks like samsung is leaving me with no choice. I want a 75 inch and i do not want a curved screen for various reasons (gimmick, overpriced, need to sit in sweet spot, etc).
Sammy did not produce the js8500 in 75 inch size or that would probably be the no-brain choice for me. The flagship is curved and way overpriced while the lower tiered model (ju6500) looks less compelling than last year's hu8500 (especially if paired with one-connect). For one thing, i don't like the look or build quality of the bezel and stand compared to the hu8500.
My conclusion is that buying last year's hu8500 for the current price of about $3k (and possibly adding a one-connect) is the best choice at this time given my wants and preferences. Unfortunately, i have not seen the js models in stores yet so i cannot know how noticeable the difference in picture quality with it's upgraded panel technology (nano-crystal color) that i would be missing.
78" flat js8600, $7900
75Q9FN*55C8OLED*Galaxy S10+ *Ub820 fed into Oppo 203* XB1X* 4k Denon X4200
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
ray0414 is online now
post #19969 of 22221 Old 07-22-2015, 05:13 PM
jacko15's Avatar
Quoted: 153 Post(s)
Liked: 145
Are you standing on your head?
jacko15 is offline
post #19970 of 22221 Old 07-22-2015, 05:15 PM
Quoted: 532 Post(s)
Liked: 238
anyone else update to 1120 with no issues?
tv: Samsung 55HU8550
avr: Pioneer VSX 824
subs: Polk PSW108, Definitive Technology Pro-sub 800
l/r: Klipsch R28Fs, c: Infinity Beta C360 rear: cheapo Sharps
mars5l is offline
post #19971 of 22221 Old 07-22-2015, 05:21 PM
Hamlet00's Avatar
Quoted: 47 Post(s)
That's another option (though pricy), thanks. I missed that one somehow.
Hamlet00 is offline
post #19972 of 22221 Old 07-22-2015, 05:24 PM
chekhonte's Avatar
Quoted: 145 Post(s)
Liked: 55
I did when it first came out and nothing happened. Now 3 of my hdmi ports are misbehaving and showing 'no signal' with 4k devices. I don't think they're related but who knows.
post #19973 of 22221 Old 07-22-2015, 06:16 PM
Mnat0712's Avatar
Quoted: 220 Post(s)
Liked: 80
Can u unplug all ur hdmi cables and any other cables from the tv. Then unplug for 10 mins then turn tv on and plug cables back in. Let me know if that works.
Hu8700 owner
chekhonte likes this.
Mnat0712 is offline
post #19974 of 22221 Old 07-22-2015, 06:18 PM
Mnat0712's Avatar
Quoted: 220 Post(s)
Liked: 80
I updated and have noticed better motion and better overall local dimming and slightly better colors
Hu8700 owner
Mnat0712 is offline
post #19975 of 22221 Old 07-22-2015, 06:24 PM
heavyharmonies's Avatar
Quoted: 245 Post(s)
Liked: 326
If you want >70" and flat, there's not a whole lot of Samsung options right now.
JU6500 - $3499 street. No One Connect. 60hz panel - poor motion
JU7100 - $4499 street. One Connect Mini (so only the ports are upgradable, not the internal processing of the TV)
I think you're on the right track. For fully $1500 less than the 7100, you're getting a set that, while yes it is last year's model, supports the full One Connect, thus making the set more futureproof than either of the above. I would file that in no-brainer territory.
3 weeks ago I bought a 65-inch JU6500 with free soundbar/sub for $1999. I really didn't want to spend more than that. Well, a week into things it crashed, burned, fell over, and sank into the swamp. When I went back to the store to arrange a replacement, they had subsequently put all of last year's models on very nice clearance prices (which weren't there when I originally shopped). Long story short, I picked up a 75HU8550 for $2399. They're coming and swapping it in for the 6500 on Friday.
In retrospect, now that I've had a chance to do more research, the 6500 blowing up was the best thing to happen to me. For $400 more, I get 10" more diagonal size, a better quality panel, and futureproofing. Suchadeal.
Yes, I won't be able to play the content on the Video Pack until I get the OCB, but I'm willing to wait a little bit and add that down the line. At least you're not stuck with potential obsolesence.
"But I want to do community service; I want to teach the handicapped how to yodel." - Hudson Hawk
Samsung UN75HU8550 + SEK-3500U OCB, Samsung UBD-K8500 4K Blu-Ray
Martin Logan LX16 (x5), Klipsch RP-140SA (x4)
Elemental Designs A5-350 15-inch downfiring sub (x2)
Denon AVR-x4200w + Carver M-1.0t driving a 5.2.4 configuration
heavyharmonies is offline
post #19976 of 22221 Old 07-22-2015, 06:25 PM
doctorwizz's Avatar
Quoted: 752 Post(s)
Liked: 252
Did you enble HDMI UHD Color on each port?
doctorwizz is offline
post #19977 of 22221 Old 07-22-2015, 07:13 PM
chekhonte's Avatar
Quoted: 145 Post(s)
Liked: 55
Yeah, you can only turn in on with ports 1, 2 and 4. Three is grayed out an says something like unavailable. When I first got the tv all hdmi ports would display a 4k signal with out the uhd color enabled. This is definitely something new.
post #19978 of 22221 Old 07-22-2015, 07:38 PM
chekhonte's Avatar
Quoted: 145 Post(s)
Liked: 55
Hu8700 owner
Holy crap that worked. I unplugged the tv and all cables, took a shower and plugged everything back in and my ports are working. Crazy, I was only trying it because it couldn't hurt, I never expected it to work.
Thanks a ton. I was already missing my tv even before the repair people took it away from. I can cancle it now.
post #19979 of 22221 Old 07-22-2015, 07:46 PM
pilotart's Avatar
Quoted: 651 Post(s)
Liked: 502
Ok, I Think I did just see one, it was a thin line across top edge, which was gone before I could pick remote up to see what it was about.
(This was also while I was watching DVR...)
Absolutely nothing like the (now blocked from happening) DVR+'s Large Pop-Up that would not go away until after you had selected Dismiss with the Remote.
Art
pilotart is offline
post #19980 of 22221 Old 07-22-2015, 08:50 PM
Hamlet00's Avatar
Quoted: 47 Post(s)
Thanks for your thoughts, and congrats on such a nice deal, I'd have snapped that up and maybe even a few extras to sell to my friends .
Hamlet00 is offline
Reply LCD Flat Panel Displays
samsung u8550 , Samsung Un55c8000 55 Inch 1080p 240 Hz 3d Led Hdtv , un55hu9000 , un65hu9000
