Official Samsung UNxxH6350 Owners Thread - Page 62 - AVS Forum | Home Theater Discussions And Reviews
 148Likes
post #1831 of 2454 Old 04-13-2015, 07:55 PM
Liked: 0
Originally Posted by sjm989 View Post
I have this same issue. I posted a question about it earlier in this thread but no one ever responded. To get the picture to come up, I have to toggle the inputs on my receiver. Would like to just hit one button like I did with all my other TV's.
It seems my issue is a known handshake problem between my Denon receiver and Samsungs Anynet+. They're not compatible I guess. I turned the Anynet+ off and so far no problems when I only turn the Time Warner dvr and my TV on. I no longer need to keep my Denon on 24/7. I'll update later. Good luck.
Ernest A is offline
post #1832 of 2454 Old 04-14-2015, 08:17 PM
ilmaestro's Avatar
Quoted: 16 Post(s)
My H6350's settings keep resetting when I switch to Netflix and back to the TV. The sound output setting in particular keeps resetting from "reveiver" to "speakers". Any ideas why this is happening?
ilmaestro is online now
post #1833 of 2454 Old 04-14-2015, 09:02 PM
dja2189's Avatar
Quoted: 153 Post(s)
Has anyone had any problems on there 55h6350 with edge light bleeding or flashlighting?
dja2189 is offline
post #1834 of 2454 Old 04-15-2015, 07:28 AM
dja2189's Avatar
Quoted: 153 Post(s)
Can anyone answer my question above!!!!!!!
dja2189 is offline
post #1835 of 2454 Old 04-15-2015, 04:57 PM
venus933's Avatar
Quoted: 2365 Post(s)
Liked: 1943
Yes folks have had problems with light bleed and some have had minimal problems. No one can honestly give you assurance that you'll be one of the later. You can control the panel version if you pick it up from a retailer as the version is listed on the box. TH01 is Samsung and UH02 is Optronics.
This review has a black uniformity screen shot of the size you're looking at which is pretty good. I will say your chances are probably better with the 55" than the larger sizes. I would recommend lightly buffering the panel with a microcloth as this may fix any slight clouding issues.
LG 65B8 - Primary
LG 55EG9100 - Bedroom
Sonos Playbase
MS Xbox One S (using strictly as a disk player)
venus933 is offline
post #1836 of 2454 Old 04-15-2015, 07:43 PM
dja2189's Avatar
Quoted: 153 Post(s)
Is the TH01 the better one? I appreciate the response, even though I just ordered the ju7100 lol hopefully it doesn't have any edge light bleed or clouding
dja2189 is offline
post #1837 of 2454 Old 04-15-2015, 07:45 PM
primetimeguy's Avatar
Quoted: 715 Post(s)
Liked: 465
I can definitely say the flashlighting seems to be a build quality issue on my 75 inch. I can squeeze and twist on the panel bottom corners and get it to go away but obviously the panel doesn't stay in that position. Not sure if I am changing the position of the LEDs or better fitting the bezel to the panel when I do this but it does seem like a more rigid or better aligned frame would help the issue.
primetimeguy is online now
post #1838 of 2454 Old 04-15-2015, 10:02 PM
dja2189's Avatar
Quoted: 153 Post(s)
Yeah I heard the 75 inch ones aren't very great. I saw my fathers 65 inch and it was perfect, no edge bleed or flashlighting at all. I would be getting a 55 inch and haven't heard any reviews on that
dja2189 is offline
post #1839 of 2454 Old 04-16-2015, 02:19 AM
theroys88's Avatar
Quoted: 195 Post(s)
Liked: 79
75" sets due to their size have light bleeding. Many folks have exchanged them several times looking for a better panel. I am not sure if OLED sets have these issues but I have not seen any of these types of complaints from owners.
theroys88 is offline
post #1840 of 2454 Old 04-16-2015, 07:25 AM
n3vino's Avatar
Unhappy
Originally Posted by theroys88 View Post
How do you like your set? give us your initial impressions?
This is a follow up to my first review. After three months of use, my UN55H6203, developed a pinkish tint. This was after the calibrations recommended on this thread. I called Geek Squad, (I have the protection plan), and he reset it back to factory settings, via remote. The tint was still there. He could not determine, what it was, so he ordered a main board, and placed a service call. They should be here on Saturday the 18th of April. What concerns me is that he had never seen that problem, and I'm afraid that they won't be able to repair it. Has anyone had this problem with any Samsung set? Does anyone know what the main board has to do with the quality or the calibration of the TV?
n3vino is offline
post #1841 of 2454 Old 04-16-2015, 04:27 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I've had my 75" about month now, when I first got it it had flashlighting in the bottom corners. Now it has none at all.
colour is offline
post #1842 of 2454 Old 04-16-2015, 06:45 PM
Quoted: 74 Post(s)
I have none either on my 75. Maybe it makes a difference how it's mounted? I'm using the 2 end stands that came with it.
Rex Steinkuller is offline
post #1843 of 2454 Old 04-17-2015, 05:35 AM
kes601's Avatar
Quoted: 23 Post(s)
Hil All,
I picked up the UN65H6350 last weekend and was really liking it the first couple of days, then it developed a stuck lit pixel (bright white) pretty much dead center on the screen.
Samsung is repairing it, I did not want to return it as it was the last one hhgregg had in stock. My question is, how exactly will they go about repairing this? He has ordered a part to do the repair, just curious what exactly it would be.
kes601 is offline
post #1844 of 2454 Old 04-17-2015, 06:50 AM
Quoted: 74 Post(s)
Not sure, but let us know what panel was in it and what the new panel is.
A or M = AU Optronics (Chinese), T, U, or W = Samsung, and H = Sharp
32=TS01, 40=TS01, 48=TS01, 50=AH01, 55=TH01,UH02, 60=HS01, 65=AH01, 75=TH01
post #1845 of 2454 Old 04-17-2015, 07:16 AM
kes601's Avatar
Quoted: 23 Post(s)
Am I looking in the serial number for the panel designation or somewhere else?
kes601 is offline
post #1846 of 2454 Old 04-17-2015, 11:08 AM
Lost_Mind's Avatar
Quoted: 37 Post(s)
Usually on the white sticker on the skinny edge of product box. That's where mine was...
Like on the attachment or similar...
Samsung QN65Q70RA/SONY STR-DN1080/PS4/
Klipsch Cinema 12/Panamax 5300-EX/DirecTv HR54-700/
Harmony 665
"There is nothing more creative than the human mind in the process of self justification..."
Lost_Mind is offline
post #1847 of 2454 Old 04-17-2015, 12:40 PM
Quoted: 13 Post(s)
Liked: 3
This didn't work for me. I turned off the Anynet+ and still have the issue.
sjm989 is offline
post #1848 of 2454 Old 04-17-2015, 12:46 PM
Quoted: 13 Post(s)
Liked: 3
Meanwhile, in a galaxy far, far away...
The new SWTFA trailer on my 75" was pretty awesome!
sjm989 is offline
post #1849 of 2454 Old 04-17-2015, 07:33 PM
Randall.White's Avatar
Quoted: 354 Post(s)
Liked: 89
Is there any pictures of the 75's wall mounted?
Randall.White is offline
post #1850 of 2454 Old 04-17-2015, 08:35 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I don't have mine wall mounted and haven't decided if I will. But out of curiosity why would you need pics?
colour is offline
post #1851 of 2454 Old 04-17-2015, 08:57 PM
Quoted: 354 Post(s)
Liked: 89
Saw up above that someone said that they don't have light bleeding issues with using the stand. Was wondering if anyone wall mounted their tv and if that caused any issues with PQ.
Plus who doesn't like pictures!? lol
post #1852 of 2454 Old 04-17-2015, 09:03 PM
Quoted: 715 Post(s)
Liked: 465
I have mine on a stand that uses a wall mount. Can't say if it is because of the mount vs stand. Could be something with the pressure.
post #1853 of 2454 Old 04-17-2015, 09:10 PM
Quoted: 354 Post(s)
Liked: 89
I'm looking at either the 75" version or a 70" of a different brand. Trying to decide if the additional 5" is really worth it. I sit around 12' away and currently have a 64". I'd consider 80" but I really don't want to sacrifice too much PQ going from a nice plasma unit.
Thoughts? By the way, I don't live in a city where I can go demo any of these TV's. Everything is a hour or more away to even look at one. I'll be ordering it online, when I do decide which one I want.
post #1854 of 2454 Old 04-17-2015, 09:14 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I was one of them that posted that and mine is on a stand. I came from a 73" DLP so I just put it on the same console. Haven't decided if I wanted it wall mounted, if it causes light bleeding my decision is made.
colour is offline
post #1855 of 2454 Old 04-17-2015, 09:20 PM
Quoted: 354 Post(s)
Liked: 89
Whatever TV I go with, it has to be wall mounted. So if wall mounting this unit causes really bad light bleeding then it's out.
How noticeable is it with regular lighting on? is it only noticeable in the dark?
post #1856 of 2454 Old 04-17-2015, 09:20 PM
Quoted: 715 Post(s)
Liked: 465
I went from 70 to 75. At first it didn't seem much bigger but when I watched the first movie on it I got a better sense of being immersed in the movie.
post #1857 of 2454 Old 04-17-2015, 09:50 PM
Quoted: 354 Post(s)
Liked: 89
What TV did you come from and how far away do you sit?
I would be jumping up 6-11" so I think it'll look good whatever size I get. We taped off on the wall how big the 75" would be and I was REALLY liking the size lol
post #1858 of 2454 Old 04-18-2015, 04:54 AM
Quoted: 715 Post(s)
Liked: 465
I had a Vizio M series, 70 inch and sit about 11 ft away.
post #1859 of 2454 Old 04-18-2015, 08:02 AM
Quoted: 74 Post(s)
Liked: 39
Definitely go with the biggest screen you can afford....I went from a 58 inch plasma to the 75 inch Sammie, wow what a difference and I sit about 13-14 feet away.
iluvwahoo is offline
post #1860 of 2454 Old 04-18-2015, 11:00 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
Each time I buy a new TV I go bigger, 32" to 50", 50" to 65", 65" to 73". When I replaced my 65" RPTV I went with a DLP 65", what I didn't realize was the difference in depth made the TV look smaller, I exchanged it for the 73".
This time around I'm not ready to jump on the 4k bandwagon and didn't feel like sinking $200 into my DLP to be repaired. I was contemplating a 80" Sharp but according to my research they are almost guaranteed to get white pixels at some point. This 75" sits a few inches farther back than my 73" did but oddly the 2" size difference actually looks larger than 2".
With that said go with the 75" it will make a difference especially at larger viewing distances. I'm at about 13ft and even though I've lost that immersive feeling long ago coming from my 73" DLP to this 75" is a new and better experience for me.
colour is offline
Reply LCD Flat Panel Displays
