**Official Samsung UHD Curved UNxxHU9000 Owners Thread ** - Page 314 - AVS Forum | Home Theater Discussions And Reviews
 3067Likes
post #9391 of 10272 Old 12-30-2015, 07:45 AM
Quoted: 4247 Post(s)
Liked: 5171
Has anyone here got their sets calibrated by ChadB or some other professional calibrator recently or had them come back for a "tune-up". If so, can you give us some feedback as it relates to the PQ of the HU9000.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G
Calman Ultimate, ISF Level III Certified
jrref is offline
post #9392 of 10272 Old 12-30-2015, 04:41 PM
mx6bfast's Avatar
Had a 55" ES 8000 and the panel needed to be replaced. Instead of replacing the panel BB gave me full credit for the purchase price about 2.5 years ago. Christmas Eve bought the 65" 9000 for a whopping $100 more.
It was just delivered and so far we are enjoying it. My other tv was calibrated and I will eventually get this one done. For the time being I plan on copying someone else's settings and then tweak as needed until calibrated.
Also we used Skype a lot on the other tv with the kids and my parents and we have already missed that feature. Is there a certain model that works well with this tv?
Grit N Grind
Glory Glory Man United
Go Cubs Go
mx6bfast is offline
post #9393 of 10272 Old 12-30-2015, 06:22 PM
p5browne's Avatar
Quoted: 3983 Post(s)
Liked: 3140
HU9000 comes with built in camera. Sorry, never use it. It stays in on the top of the set.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #9394 of 10272 Old 12-30-2015, 08:27 PM
Liked: 3
Originally Posted by Yoshimi View Post
Guys, sorry if these questions have been answered earlier:
1. I know the TV comes with an "adaptable bar." Has that been updated yet? I bought the set over a year ago.
2. Is anyone else having problems accessing Netflix/Amazon on the Smart Hub? I used to have no problem, but, neither has worked for at least a month.
Hello,
For the past three days my Netflix and Amazon has not worked on my HU8700FXZA. I tried turning off the tv then the power strip/surge protector which had worked in the past, but not this time around. So finally in a slight disgust I called Netflix and asked them about the problem. The solution was as simple as logging out of Netflix, turning off the tv, turning off the power to the tv, then unplug the WIFI router for a minute, repowering the router and wait for it to boot up properly, then turn on the power to the tv, turn on the tv, and log back into Netflix. Eureka, for me the problem was solved! I sure hope your problem is as easy, but then again you may have already figured this out on your own.
Ken
keneke007 is offline
post #9395 of 10272 Old 12-30-2015, 08:28 PM
Liked: 3
Cool May be your solution?
Hello,
Ken
post #9396 of 10272 Old 12-30-2015, 09:16 PM
mx6bfast's Avatar
I had the HU and the JS thread open and accidentally posted in this one. I have a JS, just posted in the correct thread, sorry.
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #9397 of 10272 Old 01-01-2016, 02:57 AM
flamjam's Avatar
Quoted: 95 Post(s)
Liked: 41
Is that the 78HU 9000 a 10 bit panel?
flamjam is offline
post #9398 of 10272 Old 01-01-2016, 04:52 PM
mikegaudiello's Avatar
Quoted: 186 Post(s)
Liked: 33
If I hook up the original OCB to update the firmware, should I bother calibrating it using Peter's settings or is updating the firmware enough? Should I do the sek backup first on my dad's TV (borrowing his OCB)? Do I need to back up both tvs?
mikegaudiello is offline
post #9399 of 10272 Old 01-02-2016, 08:32 AM
p5browne's Avatar
Liked: 3140
When re-installing the Original OCB, just do the FW update.
Since you won't be watching it, except to maybe checkout that the FW did improve the PQ, don't worry about calibrating it.
I do so because I post the settings for those without the SEK-3500U.
When FW updating is done, power down, pull plug, Power On on the Remote, to kill residual electricity. Swap OCBs.
No Original OCB backups required.
Plug back in, and Power up.
Good idea to do an Evolution Kit Backup on the 3500 before you start, to replace old OCB values, with your current 3500 ones.
mikegaudiello likes this.
UN65KS9800 - Mine
p5browne is offline
post #9400 of 10272 Old 01-03-2016, 10:30 PM
Iceberg86300's Avatar
Quoted: 87 Post(s)
Liked: 54
I think the adc settings are what is really different from the factory.
Standard procedure is to run ADC calibration and then set white balance after any kind of electronic parts swap.
At least that's what service manuals say to do for the ones I got my hands on.
Small changes in WB seem to back this, but I'm not going to ask anyone to go into ADC to really check things out considering the greater than average chance of making things purple.
EDIT: Let me change that to main/display boards and panel changes. On my ES6500 that blew a power supply board the tech didn't do squat except make sure things looked OK. That's not saying that any more should be done, but even the so called techs here in So Cal don't really do much besides change parts and screw crap up.
Way back when, I lost 2 display boards on an old CRT rear projection TV. That thing took ~4+ hours just to align the crts electronically & the A-holes just hit auto align, which was never correct.
Also, I wouldn't be surprised one bit of each panel had a chip in it holding info from the manufacturer/lot/etc, that is pulled when the correct panel/TV type is selected on the main/display board and figured into the ADC algorithm.
Steve
Iceberg86300 is offline
post #9401 of 10272 Old 01-04-2016, 06:16 AM
Liked: 5171
Any feedback? No one has had their set calibrated?
John
jrref is offline
post #9402 of 10272 Old 01-04-2016, 07:14 AM
grizzledbiker's Avatar
Quoted: 2886 Post(s)
Liked: 1331
Nope. Had a tune up scheduled. But canceled it after punching in Peter's great Aug.18 settings and subsequently getting the calman home express package.
55HU9000 TS01
jrref likes this.
grizzledbiker is offline
post #9403 of 10272 Old 01-04-2016, 07:16 AM
Liked: 1331
Iceberg86300 - what is "ADC"?
55HU9000 TS01
post #9404 of 10272 Old 01-04-2016, 09:05 AM
p5browne's Avatar
Liked: 3140
55HU9000 TS01
There are 2 items in the service Menu: ADC and ADC Results. On non 4K sets, the Pattern is set to Checkerboard and the ADC run to get the ADC Results. In the 4K sets, the Checkerboard Pattern has been deleted, so the ADC test can't be performed. So, it's best to write down the ADC Results for Future Reference. I've tried an external Checkerboard pattern and it didn't end so well. The 4K up scaling messed up the Pattern.
Iceberg86300 likes this.
UN65KS9800 - Mine
p5browne is offline
post #9405 of 10272 Old 01-05-2016, 05:31 AM
Lionheart of AVS
King Richard's Avatar
Quoted: 1796 Post(s)
Liked: 4366
In case some of you missed it:
The UHD Alliance (UHDA) – a global consortium comprising some of the biggest names in the consumer electronics industry (members) – has published the minimum specifications that define a premium Ultra High-Definition (UHD) experience for consumers in the home.
Products and services which meet the performance metrics will be eligible to license a “Ultra HD Premium” logo from the UHDA for promotional and marketing purposes.
“ULTRA HD PREMIUM” Logo
“ULTRA HD PREMIUM” logo is trademark of the UHD Alliance, Inc.
Announced last night at the UHD Alliance’s press conference at the Consumer Electronics Show (CES) 2016 in Las Vegas, here are the required specifications for a television to receive the “Ultra HD Premium” logo:
UHD Alliance Technical Specifications Overview
The UHD Alliance has developed three specifications to support the next-generation premium home entertainment experience.
The three specifications cover the entertainment ecosystem in the following categories:
  • Devices (currently, television displays, with other devices under consideration)
  • Distribution
  • Content
A high level overview of each technical specification can be found below.
Please join the UHD Alliance for full access to all technical and test specifications.
Devices
The UHD Alliance supports various display technologies and consequently, have defined combinations of parameters to ensure a premium experience across a wide range of devices.
In order to receive the UHD Alliance Premium Logo, the device must meet or exceed the following specifications:
  • Image Resolution: 3840x2160
  • Color Bit Depth: 10-bit signal
  • Color Palette (Wide Color Gamut)
    • Signal Input: BT.2020 color representation
    • Display Reproduction: More than 90% of P3 colors
  • High Dynamic Range
    • SMPTE ST2084 EOTF
    • A combination of peak brightness and black level either:
      • More than 1000 nits peak brightness and less than 0.05 nits black level or
      • More than 540 nits peak brightness and less than 0.0005 nits black level
Distribution
Any distribution channel delivering the UHD Alliance content must support:
  • Color Bit Depth: Minimum 10-bit signal
  • Color: BT.2020 color representation
  • High Dynamic Range: SMPTE ST2084 EOTF
Content Master
The UHD Alliance Content Master must meet the following requirements:
The UHD Alliance recommends the following mastering display specifications:
  • Display Reproduction: Minimum 100% of P3 colors
  • Peak Brightness: More than 1000 nits
  • Black Level: Less than 0.03 nits
The UHD Alliance technical specifications prioritize image quality and recommend support for next-generation audio.
UHD Alliance.org
King Richard is offline
post #9406 of 10272 Old 01-05-2016, 06:39 AM
Liked: 1331
Without going into unnecessary details:
Samsung Electronics Receives UHD Alliance Premium Certification for its 2016 SUHD TVs | SAMSUNG NEWSROOM
http://news.samsung.com/global/samsu...s-2016-suhd-tv
55HU9000 TS01
post #9407 of 10272 Old 01-05-2016, 07:05 AM
Liked: 5171
UHD Alliance Premium Certification awarded to Samsung’s entire 2016 SUHD TV lineup - SamMobile
http://www.sammobile.com/2016/01/05/...uhd-tv-lineup/
55HU9000 TS01
I guess it's time to get a new TV when they come out or maybe we can figure out how to change the HU9000's settings to make it a 2016 model? lol
What was the peak brightness on the HU9000 again? I know someone posted it but I forgot what it was. I thought it was somewhere in the 400 nit range?
I'm really glad that the HDR specs are finally moving along.
John
jrref is offline
post #9408 of 10272 Old 01-05-2016, 08:32 AM
Liked: 1331
post #9409 of 10272 Old 01-05-2016, 03:06 PM
Liked: 1331
Samsung Reveals Spectacular 2016 SUHD TV Lineup to Begin a New Decade of Global TV Leadership | SAMSUNG NEWSROOM
http://news.samsung.com/global/samsu...-tv-leadership
55HU9000 TS01
post #9410 of 10272 Old 01-05-2016, 03:21 PM
Liked: 1331
Samsung KS9500 series: Release Date, Price and Specs - CNET
http://www.cnet.com/products/samsung-ks9500-series/
55HU9000 TS01
post #9411 of 10272 Old 01-05-2016, 03:22 PM
Liked: 1331
Samsung CES 2016 press conference
http://live.cnet.com/Event/Samsung_C...26Theme%3D4563
55HU9000 TS01
post #9412 of 10272 Old 01-05-2016, 03:37 PM
Liked: 1331
post #9413 of 10272 Old 01-05-2016, 09:01 PM
p5browne's Avatar
Liked: 3140
How soon until we get to test CES 2016 4K Demo Material?
UN65KS9800 - Mine
p5browne is offline
post #9414 of 10272 Old 01-06-2016, 02:53 AM
flamjam's Avatar
Quoted: 95 Post(s)
Liked: 41
Anyone know if the 78HU9000 is a 10 bit panel?
flamjam is offline
post #9415 of 10272 Old 01-06-2016, 06:15 AM
CyberScott's Avatar
Quoted: 118 Post(s)
Liked: 147
Yes, it is a 10 bit panel.
Samsung UN65HU9000FXZA (TS01) with SEK-3500U/ZA Evolution Kit
Onkyo TX-RZ1100 rocking 7.2.4 Atmos goodness!
LG OLED55C6P
Denon AVR-X6300H also rocking 7.2.4 Atmos goodness!
CyberScott is offline
post #9416 of 10272 Old 01-06-2016, 06:22 AM
Liked: 5171
All these 2016 sets look really cool and i'm sure just like last year, this year's sets will have an even better picture and at 1000 nits, probably perfect for home use, but I also believe that we need to see is what HDR standard Netflix and other's are going to support and provide content in the near term. LG supports Dolby Vision and Samsung the open HDR standard. I believe that this will be the determining factor, in consumer near term purchases. Especially if Netflix and other streaming services and Blu-Rays support only Dolby Vision. Maybe in the long term the sets will support both standards but I think if they were, they would support them now or announce that they will. We will have to see what develops over the next couple of months.
John
jrref is offline
post #9417 of 10272 Old 01-06-2016, 07:06 AM
ahro's Avatar
Quoted: 2033 Post(s)
Liked: 4130
Not worth it.
korsjs likes this.
HENRY
78HU9000, 10 BIT, TS-01; NEW 3500 OCB, WD PASSPORT HDD
ONKYO TX-NR646 ATMOS RECEIVER
ISCAN MINI, UHD 30 PACK. SAMSUNG BJ7500 BLU RAY PLAYER
USB 3.0 4 PORT HOT SWITCHABLE HUB, ROKU 4,SAMSUNG K-8500 BRP
ahro is offline
post #9418 of 10272 Old 01-06-2016, 09:07 AM
Liked: 5171
Originally Posted by ahro View Post
Not worth it.
Henry, can you tell us why it wasn't worth it? What did you visually see? Pro's? Con's?
I remember you had you set professionally calibrated a while back.
John
jrref is offline
post #9419 of 10272 Old 01-06-2016, 01:43 PM
Liked: 1331
Having a frequent problem now ever since last self installed USB update. TV quite often refuses to shut off. Today for the 2nd time in a week, I've had to pull the plug. Note: this is only a problem with the 3500 and not the OCB.
55HU9000 TS01
post #9420 of 10272 Old 01-06-2016, 03:03 PM
CPTuell's Avatar
Quoted: 213 Post(s)
Liked: 88
55HU9000 TS01
Mine will occasionally just shut it's self off and then back on for no reason. The sound also cuts out sometime. If I reboot the Denon the sound stays off, but if I turn either the TV or the DirecTV STB off and back on it returns. May have to get back there and swap out the HDMI cables.
CPTuell
" I'm a man, I can change, If I have to......I guess." Words to live by. From the Red Green Show...The Man's Prayer
LG OLED65C9PUA & Samsung UN65HU9000/SEK3500/US02,DirecTv HR-54 Genie w/4K MiniGenie, Denon AVR-X3300W, Roku Ultra 4K/HDR, Chromecast Ultra 4K/HDR, Sony UBP-X800
CPTuell is offline
Reply LCD Flat Panel Displays
