Official Samsung UNxxH7150 / UNxxH7100AF Owners Thread - Page 124 - AVS Forum | Home Theater Discussions And Reviews
 443Likes
post #3691 of 5357 Old 02-10-2015, 10:43 AM
Phyto's Avatar
Is HDMI level set to Low normally? It gets turned off automatically when playing a blu-ray, bumping the brightness way up. I don't know of anyway to override this, but yeah it's a little irritating.
Originally Posted by vygnyr View Post
I also have this problem. When I watch a Blu-ray disc the picture setting is CAL-DAY but when I play a DVD or from a USB the picture setting changes to Standard - but it's not quite the same Standard setting as when I choose to use it, it has different configs.
Phyto is offline
post #3692 of 5357 Old 02-10-2015, 11:13 AM
ntalwar's Avatar
Quoted: 111 Post(s)
Liked: 39
I use the USB port on my Blu-ray player instead of on the TV in order to use the movie/cal modes.
ntalwar is offline
post #3693 of 5357 Old 02-10-2015, 11:33 AM
Quoted: 91 Post(s)
Liked: 9
I guess there is a reason why they call them "smart TV". Be careful out there
Samsung was asking its customers to self-censor their conversation when sitting in front of their own TV in their own home. An impression that was compounded by the lack of clarity about how exactly Samsung’s voice recognition feature worked — in terms of when and how it is switched into ‘listening’ mode (so when it’s sending your spoken words to the cloud for other companies to process).
In today’s blog, Samsung stresses that its SmartTVs “do not monitor living room conversations”, and has edited the wording of the policy to excise the offending Orwellian paragraph about sensitive info being snooped upon. Instead it now stresses that user agency is required to trigger the listening feature.
http://techcrunch.com/2015/02/10/sma...cy/#0dKN23:kQb
logitack is offline
post #3694 of 5357 Old 02-10-2015, 12:33 PM
Quoted: 23 Post(s)
Liked: 3
Has anyone had issues with the Smart TV apps closing randomly? I assume what is really happening is they crash, but there are no errors displayed. I primarily use the Plex app. The F8500 I returned did not have any issues with the smart apps like this.
MrTissues is offline
post #3695 of 5357 Old 02-10-2015, 12:44 PM
Holshot14's Avatar
Hello, have a 65 7150 and today noticed that my remote functions, volume mute menu etc, (both remotes) there is a significant delay until the action is accomplished depending on the button I pushed. I am running 2125, and I just noticed this today. I haven't done anything to the TV since last update? Any ideas?
Holshot14 is offline
post #3696 of 5357 Old 02-10-2015, 01:23 PM
mike81's Avatar
I was having this problem the first month or so I had the TV. One day I switched off the instant on feature and that seemed to fix it. The next day there was also a firmware update which may have had something to do with it working fine now.
mike81 is offline
post #3697 of 5357 Old 02-10-2015, 02:46 PM
merlin2375's Avatar
I am wondering if anyone knows where information can be found on the VESA mount on the 55" version. Is it centered on the back of the TV?
Thanks for any help!
merlin2375 is offline
post #3698 of 5357 Old 02-10-2015, 02:47 PM
mjlav's Avatar
What dimensions do you need? I just bought/mounted one.
mjlav is offline
post #3699 of 5357 Old 02-10-2015, 02:49 PM
merlin2375's Avatar
Thanks for the super fast reply. I know the 55" uses 400 x 400 VESA which is fine. I am just trying to figure out if I should center the mount on the wall and between the mantle and the ceiling to fit the TV. I would have thought that all VESA mounts would be centered on the back of the TV but now I realize that may not be the case.
Basically, is the vesa rectangle in the back perfectly centered left/right and top/bottom on the TV?
post #3700 of 5357 Old 02-10-2015, 02:51 PM
Quoted: 23 Post(s)
Liked: 3
Thank you, I'll give that a shot. Its weird, it used to not have this issue the first few days I used it but now it does.
EDIT: Wow, I just gave this a shot and everything is much more responsive. Plus, if you disable the Samsung Logo on boot, it is still very fast to turn on.
post #3701 of 5357 Old 02-10-2015, 03:02 PM
mjlav's Avatar
That I can't answer mounted. Top hole is about 6.5" from top frame and 16.25" from side frame. The rest you should be able to figure out from manual and 400x400 vesa
mjlav is offline
post #3702 of 5357 Old 02-10-2015, 03:30 PM
normk's Avatar
Hello, I came across 2 open box 60" samsung 7150 at my local best buy for 1244.00 each. The clerk said they were from atlanta and a docters office ordered them and decided they didn't need all of them and returned two. Is that a good price? Also one has hho1 on the box and the other gho1, I know they are both sharp panels, but is one better than the other? Thanks for any help.
normk is offline
post #3703 of 5357 Old 02-10-2015, 03:47 PM
Quoted: 91 Post(s)
Liked: 9
a new set from
BB is $1499.99
cruthfield is $1499.99
amazon is $1497.99
is your open box price reasonable....you decide
I have a 60 incher, but the panel is a gho2 and is excellent PQ
logitack is offline
post #3704 of 5357 Old 02-10-2015, 04:43 PM
jtaylor11's Avatar
Quoted: 68 Post(s)
Liked: 50
Hooked up my Roku via HDMI4 using Z-Mad Standard settings and looks awesome! I may just say hell with the streaming via SmartHub if I can't figure out the altered pictures settings.
-JT
Samsung 65H7150
Denon X1100w 5.2
Polk M60II Towers | CS2 Center | OWM3 Rears
SVS PB-2000 x2
jtaylor11 is offline
post #3705 of 5357 Old 02-10-2015, 05:02 PM
joshrlevy's Avatar
Hello, I have the 60H7100 paired with a Denon X2100. I have a few bluray 3d .mkv formatted movies downloaded to an external hard drive and have no issues playing them when directly connected to my tv's usb interface and displaying perfect 3d images. What my issue is when it passes the audio (arc) to my Denon receiver using the tv audio input setting it always outputs the audio format in PIIx encoding instead of dolby digital/dts or anything better. I am almost certain this audio encoding should be at least dolby digital format. Does this tv not support that audio format setting or is it a setting i need to make on either the tv or reciver to enable this? In the past using my laptop as a dnla and passing .mkv via my ps3 i have no issues outputting digital/dts but i like directly connecting to tv to reduce bandwith issues playing movies as well as instant fast forward/rewind etc.
Samsung 60 Inch LED H7100 3d
Denon X2100 In Command
Sony PS3
Energy Take Classic 5.1
joshrlevy is offline
post #3706 of 5357 Old 02-10-2015, 07:11 PM
milkk's Avatar
Quoted: 86 Post(s)
Liked: 33
I play some movies the same way and I get DTS or DD when playing them via usb drive in the smarthub. By default it plays PCM so I always have to go into sound settings and change it to DTS when the movie is starting. Go into your sound settings - menu - sound - additional settings - audio format.
joshrlevy likes this.
Samsung UN60H7150AF/Xbox One
Denon AVR-S710W
SVS Prime Bookshelves - SVS Prime Center - SVS PB-1000 - Onkyo SKH-410
milkk is offline
post #3707 of 5357 Old 02-10-2015, 07:46 PM
joshrlevy's Avatar
Thank you soo much, I actually just tried that prior to seeing this and that did the trick!! Appreciate the quick response. Now if only it would decode any higher :-)
Sony PS3
post #3708 of 5357 Old 02-10-2015, 07:49 PM
Tylerger's Avatar
Quoted: 42 Post(s)
Liked: 3
Hello, I have the 65 7150. Anyone know what "Cinema Black" does?
Everyone is entitled to my opinion.
Tylerger is offline
post #3709 of 5357 Old 02-10-2015, 08:18 PM
Leavenfish's Avatar
Quoted: 39 Post(s)
Which makes me wonder about anyone who calibrates using their Blu-ray player as the source...and thinks that all the regular TV they watch is going to look like their calibrated source would indicate it should. Just my thought...as I watch ATT Uverse 98% of the time and Blu-ray movies the rest.
Leavenfish is offline
post #3710 of 5357 Old 02-11-2015, 04:22 AM
merlin2375's Avatar
Thanks, based on that the mount is centered left/right but is not centered top to bottom.
Anyone mount one of these and have to offset the height of the mount of a bit?
Edit: Based on measures above, seems like it the mount would be about 15/16" lower from the top as compared to from the bottom.
post #3711 of 5357 Old 02-11-2015, 08:49 AM
ntalwar's Avatar
Quoted: 111 Post(s)
Liked: 39
If both sources are outputting at 16-235, the levels should match. I would probably use different ports/calibrations for sources with Full RGB(0-255) and 16-235. Some blu-ray players also have internal picture settings - those should be reset to default values to ensure a better match with other sources.
ntalwar is offline
post #3712 of 5357 Old 02-11-2015, 09:13 AM
dohanotoha's Avatar
Quoted: 39 Post(s)
I only watch hd channels with my hd box. If I use a calibration bluray disc, are the settings not going to be accurate or optimized ?
Does calibration from bluray work only with bluray content ?
dohanotoha is offline
post #3713 of 5357 Old 02-11-2015, 09:50 AM
Quoted: 91 Post(s)
Liked: 9
are the STB and BR using the same port? I am assuming no, so have you calibrated for each port?
logitack is offline
post #3714 of 5357 Old 02-11-2015, 10:17 AM
ntalwar's Avatar
Quoted: 111 Post(s)
Liked: 39
Generally, the settings will match both sources if they are both set at video level.
This post gives more detail: https://www.avsforum.com/forum/139-di...l#post21538325
ntalwar is offline
post #3715 of 5357 Old 02-11-2015, 01:38 PM
Monahans65's Avatar
Liked: 1
Yeah just ordered it. Samsung 65H7150 and a Samsung F5900 Blu Ray. I bet this TV has a perfect panel in it. LOL Being a new member to this forum I thank you all for your input to this site. This is the place for sure to get input from experts.
Monahans65 is offline
post #3716 of 5357 Old 02-11-2015, 01:40 PM
Quoted: 17 Post(s)
Liked: 1
Got a new 65" 7100 from costco after buzzing problem with first one, no buzzing on this one and much better uniformity which was a plus, but one thing I'm noticing is the finish, reflections are distorted and the best way i can describe the finishes "weird effect" is how air looks near a hot jet engine, heres a pic , is this normal part of the finish is mine a defect?
Simon620 is offline
post #3717 of 5357 Old 02-11-2015, 01:42 PM
jtaylor11's Avatar
Quoted: 68 Post(s)
Liked: 50
Mine looks like that. Doesn't seem to affect PQ though.
-JT
Samsung 65H7150
Denon X1100w 5.2
SVS PB-2000 x2
post #3718 of 5357 Old 02-11-2015, 02:18 PM
dohanotoha's Avatar
Quoted: 39 Post(s)
I still haven't opened the tv yet. Waiting for the new apartment to be ready. I can use the same port for both to ensure both are calibrated the same. If I understood what you meant right !
post #3719 of 5357 Old 02-11-2015, 02:18 PM
dohanotoha's Avatar
Quoted: 39 Post(s)
Thanks a lot.
post #3720 of 5357 Old 02-11-2015, 02:26 PM
Quoted: 17 Post(s)
Liked: 1
-JT
I first noticed it in an area of the TV that was black while watching a movie.. the first TV with the buzzing problem hasnt been picked yet so when I can get someones help I guess ill try to move it to see if thats what all the TV's are like
Simon620 is offline
Reply LCD Flat Panel Displays
cinemanow , UNxxH7150
