----Well... I have an issue now guys.
Last night, I experienced that single line running across the TV as mentioned by some others on here earlier. As well as the top 1/5 of the screen updating late. This occurred right after I reset my Xbox One (all my video runs through my Xbox One). I tried a bunch of things, but turning the XBox One off then back on fixed it.
I got home from work and when I turned on my Xbox, the entire screen was messed up. Static, lines, color off, etc. I tried turning the Xbox on and off and the TV on and off and moving to HDMI 4, nothing. Eventually, rebooting the Xbox One did the trick.
Now, is this an issue with the TV or the Xbox? I believe I had heard some others in here having a similar issue. Then only thig that's changed recently is the TV, leading me to believe that's the issue.
If it is the TV, and its not something that's common... I'll have to get is replaced. The only question then is do I stick with the 55", or go bigger? (I couldn't go smaller at this point). I'm pretty sure any bigger would just be overkill though, and I am not sure about the lag times on the other TVs. And while the added viewing angle is nice, it won't matter for the next two years or so.
Also, with other people posting about their 55s with the exact same like leaking issues in the exact same areas, it makes me wonder if it is just common across the 55? Or if I could get lucky and have that fixed if its replaced.
Any suggestions? Does this seem like something bad enough to warrant a return?-----
Update. I was playing Madden on HDMI 4 and there was crazy "artifacts"? I am not sure of the correct term. Basically, the TV wasn't updating/refreshing quickly as objects moved on screen. This seems like another poor development....
