Official 2015 Vizio 4K UHD M Series Thread - Page 279 - AVS Forum | Home Theater Discussions And Reviews
 11319Likes
post #8341 of 16418 Old 12-21-2015, 03:12 PM
dholmes54's Avatar
Quoted: 531 Post(s)
Liked: 145
Originally Posted by VBB View Post
That sounds like a resolution issue on the Yamaha. Maybe try a reset on the receiver or look at the picture options to see if it's set to passthrough or something similar. Why did you switch ports to begin with? Even if you don't use ARC, you can still have the AVR plugged into HDMI 1.
Thxs my eye sight sucks,is HDMI 1 non arc?
dholmes54 is offline
post #8342 of 16418 Old 12-21-2015, 03:21 PM
nate451's Avatar
Is your sharpness maybe set too high? That could cause moire effect.
Unfortunately no, my sharpness is at 10. I tried 0 and still the same. My feed is into hdmi 5 using an xbone with 1080p/60
nate451 is offline
post #8343 of 16418 Old 12-21-2015, 03:25 PM
VBB
VBB's Avatar
Quoted: 1034 Post(s)
Liked: 884
Originally Posted by jsevinsk View Post
When I'm watching a TV channel with a weak signal on my M60-C3, whenever there is even the slightest glitch in the signal, the info window pops up for a few seconds. This is quite distracting. Does anybody know how to turn this window off? Every other TV we've ever owned would pop up windows like this whenever you change channels or switch inputs, but never while you're in the middle of watching something, even if the signal is temporarily lost.
I don't believe there is any setting to turn this off.
Henry
LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2
NVIDIA GeForce GTX 960 | LAV Filters | madVR | MPC-HC | Plex | X-Rite i1Display Pro | DisplayCAL | HCFR
VBB is online now
post #8344 of 16418 Old 12-21-2015, 03:27 PM
VBB
VBB's Avatar
Liked: 884
HDMI 1 is the ARC port on the Vizio, but there is no downside to using it, even if you don't use ARC.
Henry
VBB is online now
post #8345 of 16418 Old 12-21-2015, 03:29 PM
VBB
VBB's Avatar
Liked: 884
So, what does this moire effect look like exactly? Have you tried HDMI 1-4 to see if they make a difference?
Henry
VBB is online now
post #8346 of 16418 Old 12-21-2015, 03:32 PM
VBB
VBB's Avatar
Liked: 884
Originally Posted by sweendog101 View Post
So tried this. It still is not working correctly. I when I turn the TV Speakers back to On, I get sound. Nothing coming from Sound Bar. Checked all inputs on sound bar and get nothing. Not sure what else I should try or if I should try a different HDMI input. I notice that I do get certain functions to work with TV remote so I can tell ARC is working but no sound...
What's the model of the sound bar? Maybe it's a setting or a switch. And I forgot, are we talking about OTA/TV apps only, or do you not get any sound from the bar, even from external devices? The TV only has one ARC-capable HDMI port. Have you tried switching the TV to PCM instead of Bitstream?
Henry
VBB is online now
post #8347 of 16418 Old 12-21-2015, 03:48 PM
VBB
VBB's Avatar
Liked: 884
Originally Posted by wetech View Post
Has anyone had luck getting 5.1 audio to passthrough via the TOSLINK output on the M60-C3? My receiver doesn't have HDMI, and is getting a stereo signal. TV is set to Speakers = Off, Bitstream. I'm sending DVD / Blu-Ray rips using PLEX on the new Apple TV. Audio is direct copies of the disc's DD or DTS soundtracks.
I think this is an issue with the Surround Sound setting in the Apple TV. Try changing it to "Dolby Surround" instead of "Auto".
Ian N likes this.
Henry
VBB is online now
post #8348 of 16418 Old 12-21-2015, 03:55 PM
dholmes54's Avatar
Quoted: 531 Post(s)
Liked: 145
Thxs VBB
post #8349 of 16418 Old 12-21-2015, 05:04 PM
ulao's Avatar
Quoted: 33 Post(s)
Help with audio and video.
Audio: I want to send my digital sound to my TV and then to my receiver. If I select audio out on the TV as PCM I get PCM stereo ( and the screen says I will get 3ch and suggests to use bitstream). Though BT sends no digital data? My source player sends only pass-thru or down-mix and neither helps. Is there no way to just pass the data from my HDMI input to the optical out?
Video:
I have yet to find someone that understands this except my wife and I. If it helps we have always had a plasma. We first saw this "3d effect" on a newLED in 2013. Its nearly impossible to explain but here are the ways we try to explain it.
1) The TV looks 3d
2) The images seem to stand out like there are images placed over the back ground
3) It's like the old 2d days of video games, where there were multiple planes that scrolled by.
4) Its like cartoonist
5) Like there is depth in the people and charters but scenery is is push back.
If anyone knows what I'm talking about, is there any way to turn this off? I saw LED TVs on display at best buy that both were LED and some didn't have this strange effect. If you do not understand what I mean its ok, most people can't see it but it bugs the h3ll out of us.
ulao is offline
post #8350 of 16418 Old 12-21-2015, 05:11 PM
rjhseven's Avatar
Quoted: 637 Post(s)
Liked: 103
was going to buy Vizio M60-E3. Was advertised on main Vizio page for $999 so I decided to pull trigger yesterday at mignight. Clicked to buy and it was listed at $1199. Went though that process several times and kept seeing $999 but then $1199 when I clicked to buy. After emailing Vizio customer service and through Facebook Messenger was told "they were updating prices" basically tough luck.
It was on main page for at least an hour at lower price. So anyone thinking of buying one, beware. They are not trustworthy.
Memphis Tiger Fan-Sports enthusiast
rjhseven is offline
post #8351 of 16418 Old 12-21-2015, 05:19 PM
VBB
VBB's Avatar
Liked: 884
Video: I have yet to find someone that understands this except my wife and I. If it helps we have always had a plasma. We first saw this "3d effect" on a newLED in 2013. Its nearly impossible to explain but here are the ways we try to explain it.
1) The TV looks 3d
What is your source player? PCM on the Vizio, as you've already figured out, is stereo only. Bitstreaming should pass up to 5.1 DD and DTS, but your source might not be sending that.
For the "3D" effect issue, see if enabling Game Low Latency makes a difference. That's turns off most of the processing features. Also make sure you don't have any of the noise-reducing settings turned on.
Henry
VBB is online now
post #8352 of 16418 Old 12-21-2015, 05:31 PM
ulao's Avatar
Quoted: 33 Post(s)
Hi, source player does put out PCM, I have seen it but out pure codecs with pass-thru. I believes the down-mix is PCM.
I just turned off the reduction stuff per a guide I found and will try the GLL its off right now.
*************EDIT:
GLL didn't seem to help but I think the reduction was it.
It looks now like things are not as "smooth" scrolling, maybe this was some new feature to make better moving pictures? Either way, one of these setting fixed it.
Backlight= 72
Brightness= 30
Contrast = 50
Color = 59
Sharpness = 35
More Picture Settings:
Black Detail = Medium
Active LED Zones = On
Reduce Judder = 2
Reduce Motion Blur = 0
Clear Action = Off
Reduce Noise (Both) = 0
Game Low Latency = Off
Film Mode Auto
Color Space = RGB(My computer and Blu-ray player also are set to output RGB)
Gamma = 1.8 or 2.0 depending on content.
Also what is the latest firmware I have 1.2.24-UHD
VBB likes this.
ulao is offline
post #8353 of 16418 Old 12-21-2015, 05:33 PM
Liked: 0
Hello,
I just bought M60-C3 from Costco. I noticed a white flashing line at the top of the screen. The timing is random, and it appears for a millisecond. I didn't find anything similar in this thread. Is this something I can fix in the settings? Or I should just go to Costco for replacement.
Xbox One is connected to HDMI 1. The same line appears watching youtube from Vizios apps. It's just one small thing that bothers me.
2BIG4U is offline
post #8354 of 16418 Old 12-21-2015, 05:40 PM
Quoted: 151 Post(s)
Liked: 61
Meh--I paid 1150 for the 65" M series. Wait another month and you will see the 60 for under 900.
Gdog2015 is offline
post #8355 of 16418 Old 12-21-2015, 05:41 PM
Quoted: 151 Post(s)
Liked: 61
Meh--I paid 1150 for the 65" M series. Wait another month and you will see the 60 for under 900. I got mine right around black friday.
rjhseven likes this.
Gdog2015 is offline
post #8356 of 16418 Old 12-21-2015, 06:12 PM
videoguy60467's Avatar
Quoted: 175 Post(s)
Liked: 203
Originally Posted by 2BIG4U View Post
Hello,
Start by doing a full system reset.
If the issue persists, try this:
MENU
MORE PICTURE
Picture size and position
Picture Position
OK
Then Arrow up a couple of clicks. (May take several)
Press OK
See if that solves the issue.
videoguy60467 is offline
post #8357 of 16418 Old 12-21-2015, 06:18 PM
blackangst's Avatar
Quoted: 125 Post(s)
Liked: 107
*************EDIT:
Backlight= 72
Brightness= 30
Contrast = 50
Color = 59
Sharpness = 35
Reduce Judder = 2
Clear Action = Off
Film Mode Auto
You dont have the newest firmware. Be patient, it'll update automatically. Theres no way to force it. It has solved many issues people were having.
blackangst is offline
post #8358 of 16418 Old 12-21-2015, 06:27 PM
memphissheik's Avatar
Liked: 3
4K content on a USB stick has to be encoded to HEVC .265 got the Vizio to play. You should be able to re-encode the video with Handbrake I believe.
Well alright, I'm going to try that out now.
Thanks!!
memphissheik is offline
post #8359 of 16418 Old 12-21-2015, 06:28 PM
guitarguy316's Avatar
Quoted: 2128 Post(s)
Liked: 803
I know I'm being pesky but, should I set ps4 to rgb and Xbox one to 24bits/rgb?
guitarguy316 is offline
post #8360 of 16418 Old 12-21-2015, 06:43 PM
Ph8te's Avatar
Quoted: 6731 Post(s)
Liked: 6580
Are you feeding anything into the Xbone? Or are games where you are seeing this moiré? I know some people have reported PQ issues when trying to feed their cable/satellite/etc through the Xbone and their issues usually clear up when you bypass it.
Sent from nowhere
Ph8te is online now
post #8361 of 16418 Old 12-21-2015, 07:12 PM
rransi's Avatar
I got Vizio M70-C3 about a month back and very pleased with it so far. One annoying issue that I cannot figure out. I have set the video output to TV (using HDMI 1 port on the TV) via my receiver (Onkyo SR 706). Intermittently, the sound from the source kind of backfeeds into the the TV for few seconds. For example, when I am watching some TV show using the headphones connected to the receiver, I can hear the sound coming through the TV as well. It lasts 5-10 seconds. Very weird. Does anyone know what the issue may be? The "TV Speakers" setting under Audio settings is set to "Off".
rransi is offline
post #8362 of 16418 Old 12-21-2015, 07:13 PM
VBB
VBB's Avatar
Liked: 884
Nothing wrong with doing that. I have my PC and TV set to RGB. 24-bit is your safest bet, as I don't believe the Vizios do deep color and/or xvYCC.
Henry
VBB is online now
post #8363 of 16418 Old 12-21-2015, 07:27 PM
natrone06's Avatar
Quoted: 25 Post(s)
Liked: 37
Video:
1) The TV looks 3d
B) Pretty sure you are just talking about The SOE. Just turn Reduce judder to 0.
natrone06 is offline
post #8364 of 16418 Old 12-21-2015, 08:08 PM
Liked: 0
MENU
MORE PICTURE
Picture Position
OK
Press OK
I probably forgot to mention that line appears about 2-2.5 inches from the top. Positioning the picture won't help in this case.
2BIG4U is offline
post #8365 of 16418 Old 12-21-2015, 08:13 PM
Ph8te's Avatar
Liked: 6580
Do you have GLL enabled? If so turn it off and see if that resolves the issue.
Sent from nowhere
Ph8te is online now
post #8366 of 16418 Old 12-21-2015, 08:29 PM
Liked: 0
Sent from nowhere
GLL is disabled
2BIG4U is offline
post #8367 of 16418 Old 12-21-2015, 08:38 PM
Liked: 1
Plug one end to HDMI 1 on your TV and plug the other end into the ARC capable output on your AVR.
If you run optical from the R4 and HDMI to the TV then you are limited to 5.1 I believe (DD/DTS only). You would get 4K streaming as long as the R4 is plugged into HDMI 2 or 5 (assuming 1 is taken by your AVR).
Sent from nowhere
Hey, followup question
I would want my Roku 4 plugged into HDMI 5 correct? Because the R4 supports 4k @ 60z and hdmi-5 is the only input that allows 60z? Thanks!
Beamer-JLD is offline
post #8368 of 16418 Old 12-22-2015, 02:32 AM
MYNAMEHERE's Avatar
Hi all. I just purchased the M50-C1. I will be feeding it from a Tivo HD and a PS3 via HDMI feed through a Denon AVR-S510BT. The output on the Denon is HDMI 2.2 4K/60Hz. Since I will not be feeding it any 4K material, can I use any of the HDMI ports on the TV? Also is the toslink the only way to get sound from the TV when using the apps to the receiver? Thanks.
If 4 out of 5 people SUFFER from diarrhea, does that mean the other 1 ENJOYS it?
MYNAMEHERE is offline
post #8369 of 16418 Old 12-22-2015, 05:04 AM
ulao's Avatar
Quoted: 33 Post(s)
Yes I was just coming back here as it hit me last night that I read someone talking about the soap opera effect when I was researching my TV. It just occurred to me that this would fit that description then I read your post. So that is most certainly it. I'll try 0 instead of 2. thx.
Also a note on the audio. I now am running plex ( I assume the plex server is sending 5.1 ) and selecting bitstream is still silent. I'll double check that the streaming content is 5.1 but either way I'd expect it to at-least send some signal. What type of signal does it send if not PCM?
ulao is offline
post #8370 of 16418 Old 12-22-2015, 06:08 AM
Quoted: 2988 Post(s)
Liked: 2832
I agree he can get the 65" for the price of the 60" anytime ,Just keep an eye to the sales.
losservatore is offline
Reply LCD Flat Panel Displays
