Official 2015 Vizio 4K UHD M Series Thread - Page 465 - AVS Forum | Home Theater Discussions And Reviews
 11319Likes
post #13921 of 16411 Old 05-02-2016, 08:33 AM
wmarkw's Avatar
Quoted: 478 Post(s)
Liked: 240
Originally Posted by GorillaBot View Post
There is an equalizer in the audio menu that you can try but I doubt there is anything you can do that is going to make the internal speakers sound significantly better.
The majority of displays these days have small, crappy back-facing. They are not good to start with and wall mounting would just muffle them further (if you have an articulating wall mount you can try moving it further away from the wall).
The bigger sets (M60+) have significantly better sound, but even those are still not great. Did your old sony have front-facing speakers?
I think most people would get a soundbar in your situation but that obviously involves hooking up a component (keep in mind that many soundbars can also be wall mounted above or below the TV which would not cause any clutter, if that is your concern)!
Thank you for the reply. Any brand recommendations on a sound bar?
wmarkw is offline
post #13922 of 16411 Old 05-02-2016, 08:36 AM
Quoted: 282 Post(s)
Liked: 319
Originally Posted by JimShaw View Post
Does the M75-C1 have a 2.0 or a 3.0 USB port?
The specs on LG's web site doesn't indicate which. So my guess would be 2.0 or they would be advertising it. Am I correct?
LG?
I'm pretty sure it's a USB 2.0 port on the M's (USB 3.0 stick support seems to be hit and miss - some work, some don't).
GorillaBot is offline
post #13923 of 16411 Old 05-02-2016, 08:39 AM
Quoted: 282 Post(s)
Liked: 319
No sorry, I've got a 5.1 system myself so not so familiar with what soundbars are good...
Lot's of review on the net though and you can have a look at/ask in the soundbar subforum: https://www.avsforum.com/forum/195-soundbars/
post #13924 of 16411 Old 05-02-2016, 08:48 AM
JimShaw's Avatar
Quoted: 436 Post(s)
Liked: 480
LG?
That's my thinking also, thanks
8.3 Surround, protected by APC H15
Speakers: SpeakerCraft: 8 AIM8 Fives & 2 TIME Fives used as Wides
Woofers: SVS PB13-Ultra (1), HSU MBM-12 MK2 (2)
Sony XBR-75Z9D,. LG OLED55E6P
Oppo UHD-203 player, Denon X7200WA, Harmony 1100, Harmony Elite, 9 Noctua cooling fans
JimShaw is offline
post #13925 of 16411 Old 05-02-2016, 10:10 AM
jjthenovice's Avatar
Quoted: 135 Post(s)
Liked: 72
I am using the Vizio SB4051-C0 and am pleased with it. I had a Denon 890 with Cambridge Soundworks speakers (circa 1994) with 2 12" subs. The Vizio SB does a good job in place of the 5.1 system that I had. You might wait for the newer Vizio SB's that are coming out soon. The newer 5.1's Sub goes down to 30 Hz while the current one only goes to 50 hz. YMMV
Vizio M75-C1 Go Big or Go Home
jjthenovice is offline
post #13926 of 16411 Old 05-02-2016, 10:45 AM
Zellio2009's Avatar
Quoted: 23 Post(s)
Question to anyone here: Did they ever improve the motion blur on these with firmware updates or anything? Just wondering, as I can get one cheap for a monitor (Although I would prefer getting a 2016 p)
Zellio2009 is offline
post #13927 of 16411 Old 05-02-2016, 10:51 AM
Quoted: 282 Post(s)
Liked: 319
Yes, there was an improvement in motion handling in one of the early updates (I think it was 1.2.23UHD). I would say that motion blur on the M series is pretty decent for an LCD.
mpgxsvcd likes this.
post #13928 of 16411 Old 05-02-2016, 10:52 AM
videoguy60467's Avatar
Quoted: 174 Post(s)
Liked: 203
My take is that motion handling got better with the new firmware versions, but that 60 Hz panel models lost the control for Motion Blur, but retained the Judder control. I have no issues with the performance of my M55-C2
mpgxsvcd and GorillaBot like this.
videoguy60467 is offline
post #13929 of 16411 Old 05-02-2016, 10:56 AM
Zellio2009's Avatar
Quoted: 23 Post(s)
Would you guys say the motion blur is good enough for competitive fps on mouse and keyboard?
Rtings had it at 15.1 ms. About what was the end result?
Rtings has the 2016 p series at 10.2 ms
post #13930 of 16411 Old 05-02-2016, 12:53 PM
VBB
VBB's Avatar
Quoted: 1034 Post(s)
Liked: 883
Fairly sure it's 2.0, but why would that matter?
Henry
LG OLED65C7P | VIZIO M70-C3 | Denon AVR-X3500H | Elac Uni-Fi | Elac Debut 2.0 SUB3030
NVIDIA GeForce GTX 960 | LAV Filters | madVR | MPC-HC | Plex | X-Rite i1Display Pro | DisplayCAL | HCFR
VBB is offline
post #13931 of 16411 Old 05-02-2016, 01:10 PM
Quoted: 47 Post(s)
Liked: 24
@VBB - I would go the other way. I am fairly certain the USB will be 3.0. RTings says 3.0 in comments, 4k.com says 3.0, and the port is Blue on mine - which typically indicates 3.0.
VBB and JimShaw like this.
darrellr is offline
post #13932 of 16411 Old 05-02-2016, 01:16 PM
mpgxsvcd's Avatar
Quoted: 2958 Post(s)
Liked: 2617
Wink
That pixel lag number doesn't tell the whole story. The way the Vizio Pixels pulse enables to have much less motion blur than all of the Sony TVs do. The Vizio is excellent at 1080p @ 120 FPS for gaming with clear action enabled. You need the 60" or larger for true 1080p @ 120 FPS though.
GorillaBot likes this.
mpgxsvcd is offline
post #13933 of 16411 Old 05-02-2016, 01:34 PM
VBB
VBB's Avatar
Liked: 883
On the 2015 M? Even better then Still begs the question why it matters...
GorillaBot and darrellr like this.
Henry
VBB is offline
post #13934 of 16411 Old 05-02-2016, 01:54 PM
Quoted: 47 Post(s)
Liked: 24
That one I cannot answer. You would think it would be something they would point out on their specs if it was indeed 3.0.
darrellr is offline
post #13935 of 16411 Old 05-02-2016, 02:26 PM
Zellio2009's Avatar
Quoted: 23 Post(s)
I'm not really all that concerned about 120hz. I prefer 4k. I only get around 30+ fps on new games anyway (But at maxed settings, I have a nice pc).
I would be going from a dell p2715q, not a Sony tv. It has like 8 ms refresh rate (I think...) but I've read mixed things about the input lag. From what I can tell the input lag is lower on the vizio.
The better contrast and deeper blacks would help me out alot.
post #13936 of 16411 Old 05-02-2016, 02:36 PM
JimShaw's Avatar
Quoted: 436 Post(s)
Liked: 480
I run a lot of 4K demo material through the USB 3.0 on my set and I don't think it would be the same through a 2.0.
I wanted my neighbor see how Pioneer Demo material would look on her M75
JimShaw is offline
post #13937 of 16411 Old 05-02-2016, 02:38 PM
JimShaw's Avatar
Quoted: 436 Post(s)
Liked: 480
Then maybe it is 3.0. I guess I will have to head to my neighbor's home and see
JimShaw is offline
post #13938 of 16411 Old 05-02-2016, 03:02 PM
Quoted: 282 Post(s)
Liked: 319
I've tried 4K videos via USB without any issue (don't remember if it was a USB 3.0 stick or not though). I wouldn't use the USB port for regular viewing, though. The media player interface leaves a lot to be desired!
VBB and toonj64 like this.
post #13939 of 16411 Old 05-02-2016, 03:10 PM
JimShaw's Avatar
Quoted: 436 Post(s)
Liked: 480
Just for running LG, Samsung, Pioneer 4K Demo material
JimShaw is offline
post #13940 of 16411 Old 05-02-2016, 03:42 PM
VBB
VBB's Avatar
Liked: 883
Jim, it shouldn't matter if the port is 2.0 or 3.0. That's really only important when you're transferring a bunch of files from a drive to a computer or vice versa. Playback from USB should be fast enough with 2.0, regardless of the material.
JimShaw, toonj64 and GorillaBot like this.
Henry
VBB is offline
post #13941 of 16411 Old 05-02-2016, 03:50 PM
JimShaw's Avatar
Quoted: 436 Post(s)
Liked: 480
I didn't know that. That was very informative and helpful, thanks.
Then, I'm good to go. Once again, thanks
JimShaw is offline
post #13942 of 16411 Old 05-02-2016, 04:20 PM
Freeze Time's Avatar
Quoted: 422 Post(s)
Liked: 58
Originally Posted by Birddoggin View Post
I don't think it is your "fault" any more than it is mine or the tens of thousands of people who bought and continue to buy non HDR TVs. There is no public information campaign I know about to inform people of the virtues of HDR and the pitfalls of non HDR TVs.
I too feel completely bamboozled about this. I'm also beyond surprised that more people aren't up in arms on this board. To me, the lack of reaction means one or more of the following:
1. People have LOTS of disposable income, so they just don't care.
2. People who bought a 2015 M series are ignoring the fact they just took it on the chin.
3. Maybe, just maybe, some of the posters on this board are shill reviewers who hyped up the M series to the detriment of those of us who fell for their rhetoric.
I mean, seriously, almost 14000 glowing reviews and compliments about the M series, influencing many of us to buy a TV. Then suddenly oops, sucks for you if you bought a 2015 M series. You should have known to buy a TV with HDR and WCG, dummy.
But hey, just plunk down another $1800-3500 and we promise you'll have a great TV this time. (wink wink)
I was told up and down that the M55 I bought was a good purchase and not to worry about HDR. I am fine with it though(lack of HDR) because I only paid $400 after a price match and a $75 promotional credit from Amazon.
Freeze Time is offline
post #13943 of 16411 Old 05-02-2016, 05:46 PM
bigsnyder's Avatar
Hey all. I picked up the VIZIO M50-C1 with the close out deal going on at Walmart. I've been out of the game as my last purchase was back in 2010/11 but i couldnt pass up this deal and wanted to get back into the 4K game. TV is gorgeous and I'm coming from a 2010 46" Sony XBR 240Hz 1080p. I left the HDMI 5 port alone as I believe this for 4K equipment only so I used ports 2-3-4 for Direct TV-Bluray-Chromecast. My only complaint so far is the sound. This is a bedroom tv which I wall mounted so i'm not going to hook up any components to it. It sounds very very muffled. I know not to expect much from tv speakers but these are horrid and my wife is wanting to go back to our sony. Any tips on making the sound better? EQ settings? TIA.
Too piggy back on Gorillabot's reply, here is what I did:
-Turn surround sound off
-Use the flat or center for more emphasis on the dialog, (experiment with the presets or adjust manually)
Modern flat screens just can't live up audio wise to what the older sets could do, and thats true with most brands.
wmarkw likes this.
bigsnyder is offline
post #13944 of 16411 Old 05-02-2016, 05:57 PM
wmarkw's Avatar
Quoted: 478 Post(s)
Liked: 240
Thanks ya'll. I just went and bought VIZIO 29 2ch Sound Bar SB2920C6 at Walmart for $80. Like i said its our bedroom tv and this will work perfectly. I didnt wall mount yet but the TV recognized the bar right away which made for easy set up. Hooked it up with the coax-digital cable into my direct tv genie box. Easy. And it sounds really good. My wife is happy but keeps harping about the Sony lol. Yes good tv but this one even a "vizio" is night and day better.
wmarkw is offline
post #13945 of 16411 Old 05-02-2016, 06:22 PM
Birddoggin's Avatar
Quoted: 69 Post(s)
Would you be fine with it if you paid full price or close to full price, as I suspect many people did?
Birddoggin is offline
post #13946 of 16411 Old 05-02-2016, 07:24 PM
Quoted: 24 Post(s)
Liked: 3
I'm fine with mine, except for the fact the firmware hasn't updated yet. It's a very good product as I wait for 8k to mature. BTW, you can play HDR on these units if you really want to; just missing the full spectrum.
mx5boffin is offline
post #13947 of 16411 Old 05-02-2016, 08:04 PM
Quoted: 422 Post(s)
Liked: 58
I would have done a lot of research if I was going to spend full price on a TV and it would have meant I was comfortable with my purchase. The only reason I even bought a 4KTV was because of the insane deal I got.
post #13948 of 16411 Old 05-02-2016, 08:42 PM
HVAC Guru's Avatar
Quoted: 162 Post(s)
Liked: 121
Little late to the party here, been busy with the audio side of things lately.
Getting bent out of shape about technology advancing is wasted energy, it's part of the risk involved with buying new gear. There's always something better next year. Something that's more refined, or has more advancements over the previous generation.
Now I know your coming from a plasma, and LCD's are kind of a step back for you, but for anyone who has had an older LCD, the M series is a good TV, and will be a good TV for a long time. I think it has a good reputation because of the features and picture quality at it's price point. We have a number of different LCD's in the house, direct lit, edge lit, and the M60 with FALD, it's hands down the best picture in the house. Yeah, it's not the long hauler I thought it was going to be, but I got a good TV at a good price. I think a lot of people on here would agree with that statement.
jaseman, toonj64 and lucacow like this.
HVAC Guru is offline
post #13949 of 16411 Old 05-02-2016, 10:21 PM
Zellio2009's Avatar
Quoted: 23 Post(s)
You'd need a really high end plasma for that. I have 3 plasmas and the m43-c1 I have is rather nice. In some ways beat them.
Now let's be honest, the plasmas still had some gray in their blacks, you needed a really high end plasma for 'infinite black'. That right there makes these really nice unless you got one of the best plasmas out there.
toonj64 likes this.
post #13950 of 16411 Old 05-02-2016, 10:23 PM
Zellio2009's Avatar
Quoted: 23 Post(s)
I dunno why some people even try sound on tvs, they were never all that good, you need a sound system.
toonj64 likes this.
Reply LCD Flat Panel Displays
