samsung JU7100 - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 4827Likes
post #631 of 10380 Old 04-03-2015, 01:30 PM
atc98092's Avatar
Quoted: 1387 Post(s)
Liked: 605
I have to disagree with a couple of comments in that review. First, I don't see hardly any color change when moving off axis. Mine is mounted in the bedroom, with the door on the side wall very close to the TV. I can step quite a ways into the hallway and the colors don't hardly change much at all. I do see contrast drop off, but nothing significant. Since I'd never be viewing it from this far off axis (well beyond 45 degrees), it's no factor. I'm looking at it right now at about 70 degrees off, and the HD TV channel looks perfectly viewable. It's an animated show (Dinosaur Train), but that shouldn't change its performance.
The other is the comment about the One Connect causing more clutter. Not really. If you currently have a bunch of HDMI cables going to the back of the set, then the clutter only moves to where the box is put. It doesn't change the clutter, but it does move it to a location that's probably easier to hide. For me, since I only run a single HDMI cable from the AV receiver to the TV, there's no change in clutter, as I still have the same number of cables going to the TV. If the One Connect Mini had every connection, rather than only some, then I could have cut my cable count drastically. Since the coax, USB 3.0 jack and Ethernet jack are still on the TV back, I still have the same number of cables. Still, it didn't change the amount of cable clutter. I just replaced the HDMI cable that went up the wall with the One Connect cable (which is a smaller cable, so there's that!).
HRPretzel likes this.
Dan
Samsung JU7100 and NU7100 4K TVs, Yamaha RX-V583, Nvidia Shield, a number of Roku players and TVs, Windows 10 media server with Serviio and Plex. Other players and TVs as well.
atc98092 is online now
post #632 of 10380 Old 04-03-2015, 01:39 PM
howardstern's Avatar
Quoted: 296 Post(s)
Liked: 86
Originally Posted by Chirosamsung View Post
You can't compare 7100 and 8500 or 9000 and 7500 for similar price since the 2015s don't have OCB and therefore aren't future proof like. 2014 counterparts
Why do you say the 2015 models are not "future proof like the 2014 counterparts?" The boxes clearly state "future ready" "will meet all UHD standards, connections, broadcast and next gen Blu-Ray through new one connect box."
These are no different than any other Samsung "future proof" TV. They just came with mini's rather than nothing at all like the 8550. People keep spreading this misinformation. When there is advancement, there will be a compatible new Evo-Kit that includes upgrades for processors, OS, contrast, motion etc. just like this year with last year's TV's. Even the connection on the minni to the TV is the exact same size as regular One-Connects.
Hey Now!
howardstern is offline
post #633 of 10380 Old 04-03-2015, 01:50 PM
dwishner's Avatar
Originally Posted by atc98092 View Post
1) Propriety cable. I can't address if it's the same interface that the full size One Connect Box uses, as I've never seen one.
2) Between 5-6 feet. I you prefer keeping it being the TV (wall mount and no way to run the new cable) I believe it can be adequately bundled without getting too bulky.
Personally, I wish Samsung had either put every connection on the OCB Mini or not used it at all. Since I only use one HDMI cable (to my AV receiver) I don't save anything there, and I still need to run the Ethernet, UHD USB cable and TV coax to the back of the set. So I still have 5 cables running up the wall (the OCB cable replaces the HDMI that isn't there anymore, and power). No advantage there for me. If the box had everything, then I'd only have two cables.
Thanks for the reply. I still fail to see any logic in having this external box. Disappointing that if I have more than a 7ft run from the TV to the media cabinet, then I'll need to mount the OCB mini by the TV.
So two more questions...
a) Is the OCB mini powered?
b) Are there mounting holes/brackets for the OCB Mini?
Thanks again!
dwishner is offline
post #634 of 10380 Old 04-03-2015, 01:53 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6677 Post(s)
Liked: 6673
Originally Posted by Ausdaddy View Post
Originally Posted by Cleveland Plasma View Post
JU7100 is not that much more $$$ than a 8550 in most cases, so you are right, if available it would make more sense since the 7100 has all the 4K advancements. However, the 8550 is a very good set and will probably just about tie a 7100 in overall performance to most users.
This is the comparison I'm trying to make. A 60HU8550 vs 55JU7100 at almost the same price. I can't decide whether I want to give up the size for the enhancements. Tough call.
^^Bigger is better. You can always add the one connect box down the road for the enhancements. ....
TheCrow1994 likes this.
Cleveland Plasma is offline
post #635 of 10380 Old 04-03-2015, 01:55 PM
venus933's Avatar
Quoted: 2365 Post(s)
Liked: 1942
Originally Posted by player002 View Post
horrible advice this set is better from reports thus far better blacks, motion and colour . They are pushing out FW last night One was pushed adding netflix and amazon. Be patient
First of all I didn't realize Salacak's issue was that he didn't wait for his television to update at the time of my post. I'm suggesting if you're stressing out waiting for the bugs to be worked out on the Amazon and Netflix apps one might be happier getting an established model. And no I don't know if the JU7100 has better blacks, motion and color than the HU8550 - not at this time. It should have better (effective) contrast than last year's H7100 thanks to the hardware dimming scheme but I don't know if it's better implemented than the one from the HU8550. Edit: I only suggested the HU8550 because it appears to be the most comparable model to the JU7100 from Samsung's 2014 line-up.
If you think I should be patient then you may have me confused with someone else.
LG 65B8 - Primary
LG 55EG9100 - Bedroom
Sonos Playbase
MS Xbox One S (using strictly as a disk player)
venus933 is offline
post #636 of 10380 Old 04-03-2015, 01:58 PM
atc98092's Avatar
Liked: 605
Thanks again!
My length estimate may be short. An online review says it's 7 feet. I didn't really pay attention, so perhaps it's a bit longer than I thought!
1) any power it requires is fed by the cable to the TV. No additional power necessary
2) no brackets or keyhole slots. Wasn't designed for mounting. That said, you could probably use some self-sticking Velcro to attach it to the back of the set.
Dan
post #637 of 10380 Old 04-03-2015, 02:13 PM
david4455's Avatar
Quoted: 163 Post(s)
Liked: 57
Originally Posted by palermo22 View Post
I just checked their website - they have the same price for the 65" as everyone else: $2,799
Yes...you are correct. The link that I followed from Google said "Samsung UN65JU7100F - 65" LED Smart TV - 4K UHDTV (2160p)" but when it took me to the Adorama site it was for a 60".
I didn't notice it.
david4455 is offline
post #638 of 10380 Old 04-03-2015, 02:26 PM
fzara2000's Avatar
Quoted: 13 Post(s)
Amazon still doesn't have it in stock...sigh.
fzara2000 is offline
post #639 of 10380 Old 04-03-2015, 02:27 PM
madgrab's Avatar
Quoted: 16 Post(s)
Was anyone able to find out if this was a 10bit or 8bit panel.
I read in this thread CS confirmed 10bit but I have my doubts on that.
madgrab is offline
post #640 of 10380 Old 04-03-2015, 02:35 PM
test4echo101's Avatar
Quoted: 44 Post(s)
Liked: 40
we won't get it until may
Oh man....I have no patience....I got the cash and to sit another month or 2 is going to be tough..lol
Mpray1983- "User error due to sneeze or fart occurred during measurement"
test4echo101 is offline
post #641 of 10380 Old 04-03-2015, 02:51 PM
Quoted: 44 Post(s)
Liked: 40
Depends right?
Once you pay for the one connect box for the 65HU8550 you may be shelling out the same cash as a 65JU7100 with the mini.
I have no idea what the price is gonna be in Canada for 65JU7100 so it may very well be outside of my $4G's anyway.
We always pay to much over here damit.
post #642 of 10380 Old 04-03-2015, 02:54 PM
Liked: 0
I recently received my JU7500. I love it, my only issue is the red looks a little pinkish.
clash95 is offline
post #643 of 10380 Old 04-03-2015, 02:58 PM
Quoted: 44 Post(s)
Liked: 40
Thats what you get for watching 4k porn.
rlindo, chuckf1 and syscokid like this.
post #644 of 10380 Old 04-03-2015, 03:08 PM
syscokid's Avatar
Quoted: 54 Post(s)
Originally Posted by david4455 View Post
After months of research....I am close to buying a new TV.
I think I finally have gone from the HU8550 camp over to the JU7100. And as much as I would love to leap on the JS8500, for me, I just can't bring myself to pay $4000 for a TV.
This is exactly what I was going thru. I committed on the JU7100 earlier this week. It should be here by late next week.
syscokid is offline
post #645 of 10380 Old 04-03-2015, 03:22 PM
Liked: 0
I wish.
I had it very close once then I hosed it. I'm just getting use to the settings anyway.
clash95 is offline
post #646 of 10380 Old 04-03-2015, 03:35 PM
ray0414's Avatar
Quoted: 12679 Post(s)
Liked: 11914
According to a samsung dealer on the forums his paperwork says the 7100 and 7500 are both 8 bit panels. Only the SUHD line is 10 bits. He said he is positive of this.
madgrab likes this.
ray0414 is offline
post #647 of 10380 Old 04-03-2015, 03:38 PM
Liked: 0
Hi p0tempkin,
Please let me know how the 7100 does for you. I have a 65uf8500 that I'm loving but didn't compare it to the 7100 because of its unavailability. I'm really curious as to how the wide angle colors get whe you sit off at the side. Please report back. Thanks a bunch!!!
amorreale is offline
post #648 of 10380 Old 04-03-2015, 03:44 PM
palermo22's Avatar
Quoted: 158 Post(s)
Anyone have a handshake issue (I am assuming that is what it is). I was just watching some movie previews on the You Tube App - when I finished it went back to the last channel I was on - but there was no sound. After about 30 seconds and switching to another channel - I finally got sound.
Anyone else have a similar issue?
palermo22 is offline
post #649 of 10380 Old 04-03-2015, 03:52 PM
ml2517's Avatar
Quoted: 337 Post(s)
Liked: 154
Yeah I've had similar sound issue like that on both my DirecTv and YouTube and I'm using the built in TV speakers. But it is rare.
ml2517 is offline
post #650 of 10380 Old 04-03-2015, 03:57 PM
roller11's Avatar
Quoted: 646 Post(s)
Liked: 101
This is a hot topic and we need more info. Do you have any links to what exactly the 2015 OCB is suppose to do? Given the number of different TVs and levels of tech/features/performance, it would be nice if I could read up on this rather than the Samsung propaganda machine spouting "upgrade to 2015". If there is even just one single 2014 > 2015 feature, however insignifacant, that is actually upgraded, then S can justify their claim.
roller11 is offline
post #651 of 10380 Old 04-03-2015, 04:30 PM
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
I have to tell you the little 4k I've wathed on YouTube looks amazing, the side viewing does loose contrast a bit. It gets a bit brighter I'm running some test on ghosting I was watching malefacent and I saw some ghosting trails, on a certain part. But then again it was a downloaded copy not the on disc. My other concern is sometimes i see gray or lighter spots on dark areas if you look at the picture you can kind of see it.
The input lag on gaming is very good, I use game mode of course. I use the xbox one and on the first person shooter I see no problems, and I love being able to raise the volume on my reciever with the remote to the tv!! Just trying to make sure there's no issues with my panel, I see the use of lottery panel and having the luck to get certain panels. Thanks in advance
ID:	644985   Click image for larger version
Joe879 is offline
post #652 of 10380 Old 04-03-2015, 04:33 PM
carageuw's Avatar
Quoted: 72 Post(s)
Liked: 27
I was just checking the availability of the 40JU7100 on Amazon Prime,
and it says ready to ship in 26-47 days...wait, what?
carageuw is offline
post #653 of 10380 Old 04-03-2015, 05:52 PM
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
Should I turn on the hdmi uhd color for hdmi on all the ports?
Joe879 is offline
post #654 of 10380 Old 04-03-2015, 06:17 PM
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
How would you guys think the ju7100 tv will match up against the sonyXBR55X900C?
I read in a review that the off viewing angles is much better then 95% of the led out there. If that's true then that would be awesome.
Joe879 is offline
post #655 of 10380 Old 04-03-2015, 06:34 PM
Salacak's Avatar
Quoted: 374 Post(s)
Liked: 92
Some pictures from 65JU7500 from Directv with iphone taken pictures
madgrab and ray0414 like this.
Salacak is offline
post #656 of 10380 Old 04-03-2015, 07:33 PM
ray0414's Avatar
Liked: 11914
not sure how close you have followed the 2015 OCB talk. but what we KNOW it will have is
1.tizen
2. octa-core processor
3. new remote
4. VP9
5. additional HDMI 2.0/HDCP 2.2 compared to last year.
based on what happened with the 2014 OCB upgrade, it is expected it will have whatever chip the 2015 tvs have. there have been a few members here who have talked with official samsung reps who were at best buy, and they also told them that the new OCB will be for all HU series tvs, and will add purcolor to the tvs that didnt have it and will have a whole new picture processor. multiple reps have told members here that there will be a dramatic picture change for the better. and all HU series tvs, and the F9000 will share the same box, the sek-3500u is what its called
link for new OCB (sek-3500u)
http://www.pcnation.com/web/details.asp?item=YU2811
video of samsung rep talking about new OCB
82Q90R*75Q9FN(RIP)*55C8OLED*Galaxy Note10+*Ub820 fed into Oppo 203*XB1X*4k DenonX4200
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
ray0414 is offline
post #657 of 10380 Old 04-03-2015, 08:09 PM
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
Can you take a couple pics from the side? And do you get any of the images like on my pics
Joe879 is offline
post #658 of 10380 Old 04-03-2015, 09:35 PM
roller11's Avatar
Quoted: 646 Post(s)
Liked: 101
1.tizen
3. new remote
4. VP9
https://www.youtube.com/watch?v=9WzrQpRKKWc
How do we know the sek-3500 supports VP9?
roller11 is offline
post #659 of 10380 Old 04-03-2015, 09:43 PM
ray0414's Avatar
Liked: 11914
i believe VP9 is linked in with tizen. this is a feature that will be included 100%. just like with the 2014 OCB upgrade, the F9000 got a whole bunch of new "things it could do", like netflix 4k was added with its new brains. I believe the F9000 originally couldnt stream anything in 4k, this ability was upgraded via OCB.
ray0414 is offline
post #660 of 10380 Old 04-03-2015, 11:33 PM
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
So this is what the tv looks like when paused at a black screen. Is this normal??
ID:	645425   Click image for larger version
ID:	645433   Click image for larger version
Joe879 is offline
Reply LCD Flat Panel Displays
4k tv , JU7100 , samsumg , Samsung , uhd
