samsung JU7100 - Page 291 - AVS Forum | Home Theater Discussions And Reviews
 4825Likes
post #8701 of 10362 Old 09-24-2016, 11:49 AM
muad'dib's Avatar
Quoted: 395 Post(s)
Liked: 108
Originally Posted by O.E. View Post
Do you have the latest update on Xbox? Try to Brute Force the update. I had a problem like this not too recent. Is your Xbox Display detecting everything as compatible? Such as 4K? HDR? 10-Bit Panel? etc
Yep. Had all the check marks in green as a go... ☺️
Sent from my LG-H812 using Tapatalk
muad'dib is offline
post #8702 of 10362 Old 09-24-2016, 02:38 PM
p5browne's Avatar
Quoted: 3994 Post(s)
Liked: 3169
Nice picture of the JU7100 here:
The 2015 Samsung UNJU7100 is one of a handful of TVs that have received an official upgrade to handle HDR.
https://www.cnet.com/how-to/can-i-upgrade-my-tv-to-hdr/
Re posted: Check your HDR here. First 2 downloads.
http://demo-uhd3d.com/categorie.php?cat=demouhd
tampa8 likes this.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #8703 of 10362 Old 09-24-2016, 05:45 PM
Lionheart of AVS
King Richard's Avatar
Quoted: 1797 Post(s)
Liked: 4367
Originally Posted by muad'dib View Post
So far I love how hdr Looks on these sets from my himedia q10pro player.
Except for some reason xbox one s.
Watched uhd Martian, and colors on skin tones looked dull, and overall image was dark..
Totally opposite I see from himedia hdr clips I tried..
Does this tv adapt to the different hdr modes it receives from sources?
Or is it set to one preset for all hdr?
Maybe xbox is sending wrong hdr preset command(gamma mode) to tv?
Originally Posted by jdm127x View Post
I'm having the same problem. Streaming anything HDR 4K through the XIS looks awful. I still stream through the tv because of this. UHD generally looks pretty good to me though.
For HDR playback, try >> THESE TV SETTINGS <<
Richard
stanhere likes this.
King Richard is offline
post #8704 of 10362 Old 09-25-2016, 03:58 AM
muad'dib's Avatar
Quoted: 395 Post(s)
Liked: 108
Richard
Thanks...
Have all the same settings, except did not try the gamma..
Cool.. Shall try when I get a chance..
King Richard likes this.
muad'dib is offline
post #8705 of 10362 Old 09-25-2016, 07:02 AM
wildgator25's Avatar
Quoted: 691 Post(s)
Liked: 506
Thanks...
One more, is your Xbox routed through an AVR or directly to the One Connect Mini?
wildgator25 is offline
post #8706 of 10362 Old 09-25-2016, 04:55 PM
muad'dib's Avatar
Quoted: 395 Post(s)
Liked: 108
Connect to the yamaha cxa5100 pre amp, then to Samsung one connect module.
I made sure that hdmi input was set to HDR colour input..
I tried several inputs to test....
On the yamaha, made sure to set its mode to 1.. Which allows HDR..
muad'dib is offline
post #8707 of 10362 Old 09-25-2016, 07:04 PM
Quoted: 691 Post(s)
Liked: 506
Tweaked Non JS Mod Calibration
New Calibration
Firmware 1461.2
i1 Display Pro profiled with i1 Pro 2
HCFR 3.4.2
Ted's Lightspace CMS Calibration BluRay via PS4
Samsung UN55JU7100 with TS01 Panel
BT 1886/Rec 709 Calibration
Resulting Gamma of 2.37
Grayscale DE Average 0.24/Max 0.44
Color Checker Skin Tone DE Average 0.93/Max 1.54
Primary and Secondary DE Average 0.42/Max 0.77
Black 0.07 cd/m2, White 165.187 cd/m2 (Both with Smart LED Off during Calibration)
** Adjustments Made in Service Menu 1st **
White Balance Offsets changed from 128/128/128 to 114/114/114
White Balance Gains changed from 123/128/130 to 123/128/139
Picture Mode: Movie (Can use CalDay or CalNight)
Backlight: 10
Contrast: 95
Brightness: 45
Sharpness: 25
Color: 50
Tint: G50/R50
Fit to Screen: On
Dynamic Contrast: Off
Black Tone: Off
Flesh Tone: 0
RGB Only Mode: Off
Gamma: -1
Color Tone: Warm2
Digital Clean View: Auto
MPEG Noise Filter: Auto
HDMI Black Level: Low
HDMI UHD Color: Off
Film Mode: Auto2
Auto Motion Plus: Clear
Smart LED: High
Color Space calibrated with 100% Saturation/75% Luminance patterns
Color Space: Custom
Red: 50/0/2
Green: 9/55/0
Blue: 0/4/52
Yellow: 52/51/1
Cyan: 7/52/52
Magenta: 47/1/53
2 Point:
R-Offset: -1
G-Offset: 18
B-Offset: -7
R-Gain: -1
G-Gain: 6
B-Gain: 3
10 Point:
10%: 35/50/7
20%: 21/19/3
30%: 6/-1/-2
40%: 13/0/7
50%: 11/1/-2
60%: 4/0/-6
70%: -6/-5/-7
80%: -1/-2/0
90%: 8/-4/-6
100%: 5/-2/-6
**** Updated 9/25/16 ****
Included are the graphs for HCFR. Note that I do not calibrate with Smart LED on. The graph for Gamma will be severely altered (down in the low % and up in the high %) when you turn Smart LED on AFTER calibrating, hence displaying in graph form exactly what the Smart LED function is for (darker Blacks and brighter Whites). Therefore, the cd/m2 would be lower at 0% and higher at 100% when you enable Smart LED after calibration.
Name:	Color Temperature 9.25.16.jpg
ID:	1684617   Click image for larger version
Name:	Gamma 9.25.16.jpg
ID:	1684625   Click image for larger version
Name:	Luminance 9.25.16.jpg
ID:	1684633   Click image for larger version
Name:	Near Black 9.25.16.jpg
ID:	1684641   Click image for larger version
Name:	RGB Levels 9.25.16.jpg
post #8708 of 10362 Old 09-25-2016, 07:37 PM
rossel21's Avatar
Hi, I recently just purchased the JU7100 55" for $699 total. It has a TS-01 panel and I really like the TV, however today I was able to purchase the JU7100 65" for $799 total but it has the IH-02 panel. I really like the 65" version but I'm just wondering how bad the IH-02 panel is comparatively. Thanks for the help
rossel21 is offline
post #8709 of 10362 Old 09-26-2016, 12:01 AM
kain0rer's Avatar
Quoted: 29 Post(s)
Netflix Stutter Settings
Hi there,
Can someone please share their AutoMotion Plus settings for the native Netflix app? Because Netflix stream at 24FPS via 60p I get an irritating stutter and for me soap opera is the lesser of two evils. I don't want to go overboard however and was wondering what everyone has had success with?
Cheers.
Marantz SR6006 Receiver | Studio 60 v.5 Fronts (Bi-Amped) | SVS PB-2000 | Sony KD-75X9400E 75" (Firmware: PKG6.2671.0070PAA) | Harmony Hub (Firmware: 4.14.123)
kain0rer is offline
post #8710 of 10362 Old 09-26-2016, 12:15 AM
L30Z3N's Avatar
Quoted: 60 Post(s)
Liked: 40
Originally Posted by kain0rer View Post
Hi there,
Cheers.
I use AutoMotion Plus Custom de-juder 1 blur 1
Try it and let me know...
L30Z3N is offline
post #8711 of 10362 Old 09-26-2016, 05:50 AM
Quoted: 691 Post(s)
Liked: 506
Hi there,
Cheers.
Clear has always worked best for me, on everything.
ml2517, kain0rer and King Richard like this.
post #8712 of 10362 Old 09-26-2016, 06:46 AM
MrRoy's Avatar
Quoted: 74 Post(s)
Liked: 42
It is a fine panel. There are a lot of us on this thread with that panel and are very happy with the tv.
MrRoy is offline
post #8713 of 10362 Old 09-26-2016, 07:16 AM
ml2517's Avatar
Quoted: 335 Post(s)
Liked: 154
Agreed, I have a TS01 and a IH02 and they are both fine.
ml2517 is offline
post #8714 of 10362 Old 09-27-2016, 08:57 AM
p5browne's Avatar
Liked: 3169
I guess I live too far North for Samsung's FW 1461.1 to find me? Of course, support says only 1460.4 is current!
1461.1 on my HU9000 + SEK-3500U - drastic calibration changes that I'm now trying to sort through. One being Gamma HAS to be on -1 to get the SM WBs Gains and Offsets, 2 Point Offsets, and 10 Point 30% to jibe. Also required was Gamma at -1 to calibrate the Standard Mode.
UN65KS9800 - Mine
p5browne is offline
post #8715 of 10362 Old 09-27-2016, 09:55 AM
jev7266's Avatar
Quoted: 76 Post(s)
Liked: 53
Does anyone have any inside info on exactly why some owners get notified about updates via the tv long after others? I'm not complaining because I've been on 1462 since about a week ago. But the update thing is just so bizzarre.
TVs: Sony XBR65X930E (2017), v8.0.0 (6.6510) / Samsung UN50JU7100 (2015) w/ IA02 panel, sw v.1530.1
AVR: Yamaha RX-v581, sw v.2.65
Speakers 5.1.2: Polk Audio RM6750 (surround) + Pioneer SP-T22A-LR Atmos height
jev7266 is offline
post #8716 of 10362 Old 09-27-2016, 10:00 AM
Anderegg's Avatar
Quoted: 472 Post(s)
Liked: 270
p5, are you saying that firmware updates can change the sets baseline calibration?
I have been on 1462 since a week ago as well........my TV just auto updates itself, I never have a choice, it just shuts down and back on with a notice that it updated!
Paul
Anderegg is offline
post #8717 of 10362 Old 09-27-2016, 11:13 AM
p5browne's Avatar
Liked: 3169
Other members getting 1463
UN65KS9800 - Mine
p5browne is offline
post #8718 of 10362 Old 09-27-2016, 11:18 AM
demonscars's Avatar
Quoted: 44 Post(s)
Liked: 25
I have 1462 and I never even noticed it updated. Just went to check what I was on and it said 1462.
Just noticed a weird thing watching Easy on Netflix in UHD, the 4th episode is entirely subtitled and in a dark scene every time a subtitle popped up the entire screen would noticibly lighten. I guess that's smart LED?
demonscars is offline
post #8719 of 10362 Old 09-27-2016, 03:41 PM
p5browne's Avatar
Liked: 3169
Paul
Won't know until Samsung gives the update re the JU7100.
Their online updates are now next to useless, if not completely out of date! Once upon a time, within 2 weeks of a new update, it was posted and available to DIY. Apparently, not anymore!
UN65KS9800 - Mine
p5browne is offline
post #8720 of 10362 Old 09-27-2016, 04:16 PM
Liked: 0
Hey all!! this may seem like a dumb question but how did everyone receive the software upgrade... My JU7100 is at 1455 and states its up to date.. any help is much appreciated.
rhines4 is offline
post #8721 of 10362 Old 09-27-2016, 09:27 PM
Liked: 5
I had to update my firmware via USB, from 1455 to 1460.4. You can get the file from the Samsung website as well as the instructions on how to to do it.
ph1608sd is offline
post #8722 of 10362 Old 09-28-2016, 05:58 AM
Liked: 0
I have a question about thumbnails on the ju7100. When switching between sources on the tv, I cannot seem to turn off the thumbnails that pop up for each source, besides removing them individually. Is there a way to disable this feature? Also, are these thumbnails being stored somewhere long term? Thanks!
sammysammy is offline
post #8723 of 10362 Old 09-28-2016, 11:56 AM
Liked: 0
Great!!! thanks
rhines4 is offline
post #8724 of 10362 Old 09-28-2016, 11:58 AM
Quoted: 691 Post(s)
Liked: 506
You been looking at some naughty things on HDMI 2 haven't you?
Just kidding, I am not sure how to remove those either. It's normally a "snapshot" of the last image that was displayed prior to switching inputs.
post #8725 of 10362 Old 09-28-2016, 12:12 PM
Quoted: 12 Post(s)
Liked: 0
Hi
what are you settings for Xbox One S Slim for HDR ?
Its very dark here and dull ?
What can i do please help
Mats Sturtewagen is offline
post #8726 of 10362 Old 09-28-2016, 06:01 PM
muad'dib's Avatar
Quoted: 395 Post(s)
Liked: 108
Originally Posted by Mats Sturtewagen View Post
Hi
Glad I'm not the only one that has this same dull dark issue..
muad'dib is offline
post #8727 of 10362 Old 09-29-2016, 11:50 AM
Quoted: 12 Post(s)
Liked: 0
You have good settings for gaming without HDR ?
HDR sucks on this tv :s
post #8728 of 10362 Old 09-29-2016, 11:51 AM
Quoted: 59 Post(s)
Liked: 26
Hdr is perfectly fine with Forza here. It's fine with netflix too.
Verstuurd vanaf mijn SM-G930F met Tapatalk
Bouncernl90 is online now
post #8729 of 10362 Old 09-29-2016, 12:27 PM
muad'dib's Avatar
Quoted: 395 Post(s)
Liked: 108
With my himedia hdr media player, hdr Looks stunning.. Bright, vivid colors etc..
Have not tried a hdr game with xbox one s, mabye issue with just movies at this time..
muad'dib is offline
post #8730 of 10362 Old 09-29-2016, 02:51 PM
Quoted: 12 Post(s)
Liked: 0
What are you settings then ? Its very dark here and dull colours not bright
Reply LCD Flat Panel Displays
4k tv , JU7100 , samsumg , Samsung , uhd
